TSMA3Z12A
TSMA3Z12A
    DOWO(东沃电子)
    SMA(DO-214AC)
    齐纳/稳压二极管 12V SMA(DO-214AC)
TSMA3Z12A 数据手册
TSMA3ZxxA Series Surface Mount Silicon Zener Diodes Zener Voltage 3.3 ~ 200 V 3.0 Watt Power Dissipation DO214AC(SMA) Features ● Glass passivated chip ● Built-in strain relief ● Low inductance ● AEC-Q101 qualified ● High peak reverse power dissipation ● Low reverse leakage ● For use in stabilizing and clipping with high power rating ● RoHS compliant Mechanical Data ● Case: DO214AC Molded plastic ● Lead: Solderable per MIL-STD-750, method 2026 ● Epoxy: UL 94V-0 rate flame retardant Unit: inch(mm) ● Polarity: Color band denotes cathode end ● Mounting position: Any Parameter Symbols Value Unit DC Power dissipation at TL = 75 °C PD 3.0 W Maximum forward voltage at if=200mA VF 1.2 V Junction temperature range TJ,TSTG -55 to +150 ℃ Storage temperature range TJ,TSTG -55 to +150 ℃ (1) Note: (1)TL=Lead temperature at 3/8'' (9.5mm)from body Rev.Z1.00 Date:2020/03/01 www.dowosemi.cn 1/3 TSMA3ZxxA Series Ratings and Characteristics Curves (TA=25℃ unless otherwise noted) Rev.Z1.00 Date:2020/03/01 www.dowosemi.cn 2/3 TSMA3ZxxA Series Part Number Nominal Zener Voltage @IT Device Marking C d Code Maximum Zener Impedance IZT(mA) ZZT MAX.(Ω) @IZT ZZK MAX.(Ω) @IZK Maximum Reverse Leakage Current Maximum DC Zener Current IZK(mA) IR(uA) @VR VR(V) IZM(mA) VZ AVE.(V) VZ MIN.(V) VZ MAX.(V) TSMA3Z5 SMA3Z5.1A 1A TSMA3Z5.6A 3H0 3H1 3H2 3H3 3H4 3H5 3H6 3.3 3.6 3.9 4.3 4.7 5 1 5.1 5.6 3.14 3.42 3.71 4.09 4.47 4 85 4.85 5.32 3.47 3.78 4.10 4.52 4.94 5 36 5.36 5.88 227.3 208.3 192.0 174.0 160.0 147 0 147.0 134.0 10.0 9.0 4.5 4.5 4.0 35 3.5 2.5 500 500 400 400 500 550 600 1.00 1.00 1.00 1.00 1.00 1 00 1.00 1.00 100 100 100 50 50 10 0 10.0 10.0 1.0 1.0 1.0 1.0 1.0 10 1.0 2.0 817.0 749.0 691.0 627.0 573.0 528 0 528.0 481.0 TSMA3Z6.2A TSMA3Z6.8A TSMA3Z7.5A 3A0 3A1 3A2 6.2 6.8 7.5 5.89 6.46 7.13 6.51 7.14 7.88 121.0 110.0 100.0 1.5 2.0 2.0 700 700 700 1.00 1.00 0.50 10.0 10.0 10.0 3.0 4.0 5.0 435.0 393.0 360.0 TSMA3Z8.2A TSMA3Z9.1A 3A3 3A4 3A5 8.2 9.1 10.0 7.79 8.65 9.50 8.61 9.56 10.50 91.0 82.0 75.0 2.3 2.5 3.5 700 700 700 0.50 0.50 0.25 10.0 10.0 10.0 6.0 7.0 7.6 330.0 297.0 270.0 TSMA3Z11A TSMA3Z12A TSMA3Z13A TSMA3Z14A TSMA3Z15A 3A6 3A7 11.0 12.0 10.45 11.40 11.55 12.60 68.0 63.0 4.0 4.5 700 700 0.25 0.25 0.5 0.5 8.4 9.1 225.0 246.0 3A8 3A9 3B0 13.0 14.0 15.0 12.35 13.30 14.25 13.65 14.70 15.75 58.0 53.0 50.0 4.5 5.0 5.5 700 700 700 0.25 0.25 0.25 0.5 0.5 0.5 9.9 10.6 11.4 208.0 193.0 180.0 TSMA3Z16A TSMA3Z17A TSMA3Z18A TSMA3Z19A 3B1 3B2 3B3 3B4 16.0 17.0 18.0 19.0 15.20 16.15 17.10 18.05 16.80 17.85 18.90 19.95 47.0 44.0 42.0 40.0 5.5 6.0 6.0 7.0 700 750 750 750 0.25 0.25 0.25 0.25 0.5 0.5 0.5 0.5 12.2 13.0 13.7 14.4 169.0 159.0 150.0 142.0 TSMA3Z20A TSMA3Z22A TSMA3Z24A TSMA3Z27A 3B5 3B6 3B7 3B8 20.0 22.0 24.0 27.0 19.00 20.90 22.80 25.65 21.00 23.10 25.20 28.35 37.0 34.0 31.0 28.0 7.0 8.0 9.0 10.0 750 750 750 750 0.25 0.25 0.25 0.25 0.5 0.5 0.5 0.5 15.2 16.7 18.2 20.6 135.0 123.0 112.0 100.0 TSMA3Z30A 3B9 3C0 3C1 3C2 30.0 33 0 33.0 36.0 39.0 28.50 31 35 31.35 34.20 37.05 31.50 34 65 34.65 25.0 23 0 23.0 16.0 20 0 20.0 1000 1000 0.5 0 5 0.5 22.5 25 1 25.1 90.0 82 0 82.0 37.80 40.95 21.0 19.0 22.0 28.0 1000 1000 0.25 0 25 0.25 0.25 0.25 0.5 0.5 27.4 29.7 75.0 69.0 3C3 3C4 43.0 47.0 40.85 44.65 45.15 49.35 17.0 16.0 33.0 38.0 1500 1500 0.25 0.25 0.5 0.5 32.7 35.6 63.0 57.0 TSMA3Z51A TSMA3Z56A 3C5 3C6 51.0 56.0 48.45 53.20 53.55 58.80 15.0 13.0 45.0 50.0 1500 2000 0.25 0.25 0.5 0.5 38.8 42.6 53.0 48.0 TSMA3Z62A TSMA3Z68A TSMA3Z75A 3C7 3C8 62.0 62 0 68.0 58 58.90 90 64.60 65 65.10 10 71.40 12 12.0 0 11.0 55 55.0 0 70.0 2000 2000 0 0.25 25 0.25 0 0.5 5 0.5 47.1 47 1 51.7 44 44.0 0 40.0 3C9 3F0 3F1 3F2 3F3 75.0 82.0 91.0 100.0 110.0 71.25 77.90 86.45 95.00 104.50 78.75 86.10 95.55 105.00 115.50 10.0 9.1 8.2 7.5 6.8 85.0 95.0 115.0 160.0 225.0 2000 3000 3000 3000 4000 0.25 0.25 0.25 0.25 0.25 0.5 0.5 0.5 0.5 0.5 56.0 62.2 69.2 76.0 83.6 36.0 33.0 30.0 27.0 25.0 3F4 3F5 3F6 3F7 3F8 120.0 130.0 140.0 150.0 160.0 114.00 123.50 133.00 142.50 152.00 126.00 136.50 147.00 157.50 168.00 6.3 5.8 5.3 5.0 4.7 300.0 375.0 475.0 550.0 625.0 4500 5000 5000 6000 6500 0.25 0.25 0.25 0.25 0.25 0.5 0.5 0.5 0.5 0.5 91.2 98.8 106.4 114.0 121.6 22.0 21.0 19.0 18.0 17.0 3F9 3G1 3G2 3G3 170.0 180.0 190.0 200.0 161.50 171.00 180.50 190.00 178.50 189.00 199.50 210.00 4.4 4.2 4.0 3.7 650.0 700.0 800.0 875.0 7000 7000 8000 8000 0.25 0.25 0.25 0.25 0.5 0.5 0.5 0.5 130.4 136.8 144.8 152.0 16.0 15.0 14.0 13.0 TSMA3Z3.3A TSMA3Z3.6A TSMA3Z3.9A TSMA3Z4.3A TSMA3Z4.7A TSMA3Z10A TSMA3Z33A TSMA3Z36A TSMA3Z39A TSMA3Z43A TSMA3Z47A TSMA3Z82A TSMA3Z91A TSMA3Z100A TSMA3Z110A TSMA3Z120A TSMA3Z130A TSMA3Z140A TSMA3Z150A TSMA3Z160A TSMA3Z170A TSMA3Z180A TSMA3Z190A TSMA3Z200A Rev.Z1.00 Date:2020/03/01 www.dowosemi.cn 3/3
TSMA3Z12A 价格&库存
很抱歉,暂时无法提供与“TSMA3Z12A”相匹配的价格&库存,您可以联系我们找货
