AW37030D300DNR
AW37030D300DNR
    AWINIC(艾为)
    DFN-4-EP(1x1)
    线性稳压器/LDO 输入1.4V~5.5V 输出3V DFN4_1X1MM_EP
AW37030D300DNR 数据手册
AW37030YXXX Apr. 2023 V2.0 300 mA High Performance Low-Dropout Linear Regulator General Description ⚫ Input voltage range: 1.4V to 5.5V ⚫ Fixed outputs of 1.1V, 1.2V, 1.5V, 1.55V,1.8V, 2.5V, 2.8V, 2.85V, 2.9V, 2.95V, 3.0V, 3.1V, 3.3V ⚫ Rated output current: 300mA AW37030YXXX is a low dropout voltage regulator featuring low ON resistance, high PSRR, low Noise, good load/line transient response and smooth softstart. ⚫ Quiescent current: typical 50A ⚫ Typical 0.1A shutdown current ⚫ Typical 310mV dropout voltage tia l Features en AW37030YXXX integrates current limit, short circuit protection, thermal shutdown, sufficiently protecting IC from being damaged. AW37030YXXX is designed to work with a 1F or more input ceramic capacitor and a 1F or more output ceramic capacitor. The low power dissipation and good dynamic response make AW37030YXXX very suitable for hand-held communication equipment. Tiny package makes high density mounting of the IC on boards possible. (IOUT=300mA, 1.8V output) Power supply rejection ratio: typical 90dB (IOUT=30mA, freq=1kHz, 1.8V output) ⚫ Noise: typical 33Vrms (IOUT=30mA, BW=10Hz to 100kHz, 1.8V output) ⚫ Built-in output short protection: typical 120mA when output short to ground ⚫ DFN 1mmX1mmX0.37mm-4L package and SOT 23-5L package Applications Battery-powered equipment Smart phone STB aw ini Digital camera cC on fid ⚫ Typical Application Circuit VIN 1.4V to 5.5V IN CIN 1μF ON OUT AW37030YXXX VOUT 1.1V, 1.2V, 1.5V,1.55V, 1.8V, 2.5V, 2.8V, 2.85V, 2.9V, 2.95V, 3.0V, 3.1V, 3.3V COUT 1μF GND CE OFF www.awinic.com 1 © 2023 Shanghai Awinic Technology Co., Ltd. All Rights Reserved AW37030YXXX Apr. 2023 V2.0 Pin Configuration And Top Mark DFN 1mmX1mm-4L AW37030YXXXDNR Marking (Top View) AW37030YXXXDNR (Top View) 1 tia l 4 X X Y IN OUT fid CE GND 3 XX –AW37030YXXXDNR Y –Production Tracing Code on 2 en 5 EXP SOT 23-5L aw ini NC OUT cC AW37030YXXXSTR Marking (Top View) 5 4 IN GND CE XXXX YYYY 1 2 3 XXXX – AW37030YXXXSTR YYYY – Production Tracing Code www.awinic.com 2 © 2023 Shanghai Awinic Technology Co., Ltd. All Rights Reserved AW37030YXXX Apr. 2023 V2.0 Pin Definition DFN 1mmX1mm-4L NAME DESCRIPTION 1 OUT Regulated output voltage pin. Put a 1F or more ceramic capacitor at the output pin. 2 GND Ground. 3 CE Chip enable pin. Built-in 140nA pull-down current. (High Active) 4 IN Input supply pin. Put a 1F or more bypass capacitor at the power supply. 5 EXP tia l No. en Expose pad should be tied to ground plane for better power dissipation. SOT 23-5L No. NAME 1 IN 2 GND 3 CE Chip enable pin. Built-in 140nA pull-down current. (High Active) 4 NC Not connected. 5 OUT on Ground. fid Input supply pin. Put a 1F or more bypass capacitor at the power supply. Regulated output voltage pin. Put a 1F or more ceramic capacitor at the output pin. cC Name Rule DESCRIPTION aw ini AW37 030 Y XXX ZZZ Package DNR: DFN 1mmX1mmX0.37mm-4L STR: SOT 23-5L Output Voltage E.g. 180: Output Voltage 1.8V Auto-discharge Function D: Available B: Not available Rated Current 030: Rated Current 300mA www.awinic.com 3 © 2023 Shanghai Awinic Technology Co., Ltd. All Rights Reserved AW37030YXXX Apr. 2023 V2.0 Functional Block Diagram AW37030YXXX IN Enable Logic l Thermal Shutdown tia CE Driver with Current Limit& Short Circuit Protection and Load Transient Accelerating en Voltage Reference Soft-Start OUT on fid EA cC GND Auto Discharge aw ini Typical Application Circuits VIN 1.4V to 5.5V IN CIN 1μF ON OUT VOUT 1.1V, 1.2V, 1.5V,1.55V, 1.8V, 2.5V, 2.8V, 2.85V, 2.9V, 2.95V, 3.0V, 3.1V, 3.3V AW37030YXXX COUT 1μF GND CE OFF AW37030YXXX Application Circuit Notice for typical application circuits: Capacitance of CIN and COUT should be 1F or more. www.awinic.com 4 © 2023 Shanghai Awinic Technology Co., Ltd. All Rights Reserved AW37030YXXX Apr. 2023 V2.0 Ordering Information Temperature Package Marking Moisture Sensitivity Level Environmental Information Delivery Form AW37030D110DNR -40°C~85°C DFN 1mmX1mm-4L VE MSL1 ROHS+HF 3000 units/ Tape and Reel AW37030D120DNR -40°C~85°C DFN 1mmX1mm-4L SE MSL1 ROHS+HF 3000 units/ Tape and Reel AW37030D150DNR -40°C~85°C DFN 1mmX1mm-4L CR MSL1 ROHS+HF 3000 units/ Tape and Reel AW37030D155DNR -40°C~85°C DFN 1mmX1mm-4L ZK ROHS+HF 3000 units/ Tape and Reel AW37030D180DNR -40°C~85°C DFN 1mmX1mm-4L AW37030D250DNR -40°C~85°C DFN 1mmX1mm-4L AW37030D280DNR -40°C~85°C DFN 1mmX1mm-4L AW37030D285DNR -40°C~85°C AW37030D290DNR -40°C~85°C en tia l Part Number fid MSL1 MSL1 ROHS+HF 3000 units/ Tape and Reel J4 MSL1 ROHS+HF 3000 units/ Tape and Reel ZJ MSL1 ROHS+HF 3000 units/ Tape and Reel DFN 1mmX1mm-4L 2V MSL1 ROHS+HF 3000 units/ Tape and Reel DFN 1mmX1mm-4L HH MSL1 ROHS+HF 3000 units/ Tape and Reel aw ini cC on HL AW37030D295DNR -40°C~85°C DFN 1mmX1mm-4L C2 MSL1 ROHS+HF 3000 units/ Tape and Reel AW37030D300DNR -40°C~85°C DFN 1mmX1mm-4L VA MSL1 ROHS+HF 3000 units/ Tape and Reel AW37030D310DNR -40°C~85°C DFN 1mmX1mm-4L RJ MSL1 ROHS+HF 3000 units/ Tape and Reel AW37030D330DNR -40°C~85°C DFN 1mmX1mm-4L PP MSL1 ROHS+HF 3000 units/ Tape and Reel AW37030D110STR -40°C~85°C SOT 23-5L 75PY MSL3 ROHS+HF 3000 units/ Tape and Reel www.awinic.com 5 © 2023 Shanghai Awinic Technology Co., Ltd. All Rights Reserved AW37030YXXX Apr. 2023 V2.0 Ordering Information (Continued) Temperature Package Marking Moisture Sensitivity Level Environmental Information Delivery Form AW37030D120STR -40°C~85°C SOT 23-5L VGML MSL3 ROHS+HF 3000 units/ Tape and Reel AW37030D150STR -40°C~85°C SOT 23-5L ZUM4 MSL3 ROHS+HF 3000 units/ Tape and Reel AW37030D180STR -40°C~85°C SOT 23-5L 5HGC MSL3 ROHS+HF 3000 units/ Tape and Reel AW37030D250STR -40°C~85°C SOT 23-5L K2FA ROHS+HF 3000 units/ Tape and Reel AW37030D280STR -40°C~85°C SOT 23-5L AW37030D285STR -40°C~85°C SOT 23-5L AW37030D290STR -40°C~85°C SOT 23-5L AW37030D300STR -40°C~85°C AW37030D310STR -40°C~85°C www.awinic.com en fid ROHS+HF 3000 units/ Tape and Reel TKRW MSL3 ROHS+HF 3000 units/ Tape and Reel 6QN0 MSL3 ROHS+HF 3000 units/ Tape and Reel SOT 23-5L N02F MSL3 ROHS+HF 3000 units/ Tape and Reel SOT 23-5L 2JSX MSL3 ROHS+HF 3000 units/ Tape and Reel BB3G MSL3 ROHS+HF 3000 units/ Tape and Reel on MSL3 cC -40°C~85°C MSL3 JGLU aw ini AW37030D330STR tia l Part Number SOT 23-5L 6 © 2023 Shanghai Awinic Technology Co., Ltd. All Rights Reserved AW37030YXXX Apr. 2023 V2.0 Absolute Maximum Ratings(NOTE1) RANGE Input voltage range -0.3V to 6.5V Enable control voltage range -0.3V to 6.5V Output voltage range -0.3V to VIN+0.3V, max. 6.5V Maximum operating junction temperature TJ_MAX 150°C Operating free-air temperature range -40°C to 125°C tia Recommended operating junction temperature TJ_REC l PARAMETERS -40°C to 85°C Storage temperature TSTG -65°C to 150°C 260°C en Lead temperature (soldering 10 seconds) DFN 1mmX1mm-4L 215.4°C/W SOT 23-5L 177.4°C/W Junction-to-case(top) thermal ( ) resistance RθJC(top) NOTE2 DFN 1mmX1mm-4L 161.85°C/W SOT 23-5L 102.1°C/W Junction-to-board thermal resistance ( ) RθJB NOTE2 DFN 1mmX1mm-4L 156.4°C/W SOT 23-5L 42.7°C/W Junction-to-top characterization ( ) parameter ψJT NOTE2 DFN 1mmX1mm-4L 17.3°C/W SOT 23-5L 13.5°C/W DFN 1mmX1mm-4L 170.4°C/W SOT 23-5L 39.4°C/W on cC Junction-to-board characterization ( ) parameter ψJB NOTE2 fid Junction-to-ambient thermal ( ) resistance RθJA NOTE2 Junction-to-case(bottom) thermal ( ) resistance RθJC(bot) NOTE2 DFN 1mmX1mm-4L 118°C/W SOT 23-5L 31.2°C/W Maximum power consumption DFN 1mmX1mm-4L 464mW TA=25°C, TJ_REC=125°C SOT 23-5L 564mW HBM (Human body model)(NOTE3) aw ini ESD CDM(Charged device model) (NOTE4) ±2kV ±1.5kV +IT:200mA Latch-Up(NOTE5) - IT:-200mA NOTE1: Conditions out of those ranges listed in "absolute maximum ratings" may cause permanent damages to the device. In spite of the limits above, functional operation conditions of the device should within the ranges listed in "recommended operating conditions". Exposure to absolute-maximum-rated conditions for prolonged periods may affect device reliability. NOTE2: Thermal resistances follow JEDEC 2S2P standards, and is usually highly dependent on PCB layout. Exceptionally, RθJC(top) of DFN 1mmX1mm-4L Package follows SEMI standard G43-87. NOTE3: All pins. Test Condition: ESDA/JEDEC JS-001-2017. NOTE4: All pins. Test Condition: ESDA/JEDEC JS-002-2018. NOTE5: Test Condition: JESD78E. www.awinic.com 7 © 2023 Shanghai Awinic Technology Co., Ltd. All Rights Reserved AW37030YXXX Apr. 2023 V2.0 Electrical Characteristics VIN=VOUT(SET)+1V, VCE>1V, IOUT=1mA, CIN=COUT=1F, TA=25°C (unless otherwise noted) TEST CONDITION MIN TYP MAX UNIT 1.4 5.5 V Input Voltage Range VOUT_ACC Output Voltage Accuracy TA=25°C -1 1 -40°C ≤TA≤85°C -2 2 LOADReg Load Regulation 1mA≤IOUT≤300mA LINEReg Line Regulation VOUT(SET)+0.5V≤VIN ≤5.5V l VIN tia PARAMETER 1 20 mV 1 5 mV 680 884 VOUT(SET)=1.2V 576 749 VOUT(SET)=1.8V 310 403 VOUT(SET)=2.5V 203 264 VOUT(SET)=2.8V 184 239 VOUT(SET)=3.0V 175 228 VOUT(SET)=3.3V 158 205 VCE1V, IOUT=1mA, CIN=COUT=1F, TA=25°C, In Typical Application Circuit, unless otherwise noted. 200 350 175 300 150 200 150 -40℃ 25℃ 85℃ 100 50 100 75 50 -40℃ 25℃ 85℃ 25 0 0 0 50 100 150 200 250 300 50 100 150 200 250 300 IOUT (mA) Dropout Voltage vs Output Current AW37030D110 AW37030D180 120 110 100 90 80 70 60 50 40 30 20 10 0 PSRR (dB) cC on 120 110 100 90 80 70 60 50 40 30 20 10 0 0 fid IOUT (mA) Dropout Voltage vs Output Current IOUT=30mA IOUT=150mA 0.01 0.1 1 10 100 1000 aw ini PSRR (dB) 125 en 250 tia 400 l AW37030D330 Vdropout (mV) Vdropout (mV) AW37030D180 IOUT=30mA IOUT=150mA 0.01 0.1 PSRR vs Frequency PSRR vs Frequency 0.1 1 10 100 AW37030D110 1 1000 Freq (kHz) 0.1 0.01 IOUT=1mA 0.001 10 100 1000 10000 100000 Freq (Hz) PSRR vs Frequency www.awinic.com 1000 10 Noise(μV/√Hz) PSRR (dB) 100 Freq (kHz) IOUT=30mA 0.01 10 Freq (kHz) AW37030D330 120 110 100 90 80 70 60 50 40 30 20 10 0 1 Output Spectral Noise Density 11 © 2023 Shanghai Awinic Technology Co., Ltd. All Rights Reserved AW37030YXXX Apr. 2023 V2.0 Typical Characteristics (Continued) VIN=VOUT(SET)+1V, VCE>1V, IOUT=1mA, CIN=COUT=1F, TA=25°C, In Typical Application Circuit, unless otherwise noted. 10 1 1 0.01 IOUT=1mA IOUT=10mA IOUT=150mA 0.001 0.1 0.01 en 0.1 tia 10 l AW37030D330 Noise(μV/√Hz) Noise(μV/√Hz) AW37030D180 IOUT=1mA IOUT=10mA IOUT=150mA 0.001 100 1000 10000 100000 Freq (Hz) Output Spectral Noise Density AW37030D110 100 1000 cC 2.8V3.8V VOUT=1.1V aw ini VOUT=1.8V VIN: 1V/div VOUT: 20mV/div Time(50us/div) Input Transient Response AW37030D110 Time(50us/div) Input Transient Response AW37030D330 IOUT=30mA, tr=tf=10us 4.3V5.3V VIN=2.1V, tr=tf=1us VOUT=1.1V VOUT=3.3V VIN: 2V/div VOUT: 20mV/div 50mA100mA VOUT: 20mV/div IOUT: 50mA/div Time(50us/div) Input Transient Response www.awinic.com 100000 IOUT=30mA, tr=tf=10us 2.1V3.1V VIN: 1V/div VOUT: 20mV/div 10000 Freq (Hz) Output Spectral Noise Density AW37030D180 on IOUT=30mA, tr=tf=10us 10 fid 10 Time(50us/div) Load Transient Response 12 © 2023 Shanghai Awinic Technology Co., Ltd. All Rights Reserved AW37030YXXX Apr. 2023 V2.0 Typical Characteristics (Continued) VIN=VOUT(SET)+1V, VCE>1V, IOUT=1mA, CIN=COUT=1F, TA=25°C, In Typical Application Circuit, unless otherwise noted. AW37030D110 AW37030D180 VIN=2.8V, tr=tf=1us VIN=2.1V, tr=tf=1us tia l VOUT=1.1V VOUT: 20mV/div IOUT: 50mA/div VOUT: 100mV/div IOUT: 200mA/div Time(50us/div) Load Transient Response AW37030D330 fid Time(50us/div) Load Transient Response AW37030D180 VIN=4.3V, tr=tf=1us on VIN=2.8V, tr=tf=1us cC VOUT=1.8V VOUT=3.3V 50mA100mA 1mA300mA aw ini VOUT: 100mV/div IOUT: 200mA/div Time(50us/div) Load Transient Response AW37030D330 VOUT: 20mV/div IOUT: 50mA/div Time(50us/div) Load Transient Response AW37030D110 VIN=4.3V, tr=tf=1us VIN=2.1V, IOUT=0mA VOUT=3.3V VCE=0V2.1V 1mA300mA VOUT: 100mV/div IOUT: 200mA/div VOUT=1.1V VOUT: 1V/div VCE: 2V/div Time(50us/div) Load Transient Response www.awinic.com 50mA100mA en 1mA300mA VOUT=1.8V Time(100us/div) Turn On&Off Speed with CE pin 13 © 2023 Shanghai Awinic Technology Co., Ltd. All Rights Reserved AW37030YXXX Apr. 2023 V2.0 Typical Characteristics (Continued) VIN=VOUT(SET)+1V, VCE>1V, IOUT=1mA, CIN=COUT=1F, TA=25°C, In Typical Application Circuit, unless otherwise noted. AW37030D110 AW37030D110 VIN=2.1V, IOUT=300mA VIN=2.1V, IOUT=30mA VCE=0V2.1V tia l VCE=0V2.1V VOUT: 1V/div VCE: 2V/div Time(100us/div) Turn On&Off Speed with CE pin AW37030D180 VIN=2.8V, IOUT=30mA on VIN=2.8V, IOUT=0mA Time(100us/div) Turn On&Off Speed with CE pin AW37030D180 fid VOUT: 1V/div VCE: 2V/div cC VCE=0V2.8V VCE=0V2.8V VOUT=1.8V aw ini VOUT: 1V/div VCE: 2V/div Time(100us/div) Turn On&Off Speed with CE pin AW37030D180 VIN=2.8V, IOUT=300mA VOUT=1.8V VOUT: 1V/div VCE: 2V/div Time(100us/div) Turn On&Off Speed with CE pin AW37030D330 VIN=4.3V, IOUT=0mA VCE=0V2.8V VCE=0V4.3V VOUT=1.8V VOUT=3.3V VOUT: 2V/div VCE: 5V/div VOUT: 1V/div VCE: 2V/div Time(100us/div) Turn On&Off Speed with CE pin www.awinic.com VOUT=1.1V en VOUT=1.1V 14 Time(100us/div) Turn On&Off Speed with CE pin © 2023 Shanghai Awinic Technology Co., Ltd. All Rights Reserved AW37030YXXX Apr. 2023 V2.0 Typical Characteristics (Continued) VIN=VOUT(SET)+1V, VCE>1V, IOUT=1mA, CIN=COUT=1F, TA=25°C, In Typical Application Circuit, unless otherwise noted. AW37030D330 AW37030D330 VIN=4.3V, IOUT=30mA VIN=4.3V, IOUT=300mA VCE=0V4.3V tia l VCE=0V4.3V VOUT: 2V/div VCE: 5V/div VOUT=3.3V en VOUT=3.3V VOUT: 2V/div VCE: 5V/div fid Time(100us/div) Turn On&Off Speed with CE pin aw ini cC on Time(100us/div) Turn On&Off Speed with CE pin www.awinic.com 15 © 2023 Shanghai Awinic Technology Co., Ltd. All Rights Reserved AW37030YXXX Apr. 2023 V2.0 Detailed Functional Description tia l AW37030YXXX is a low dropout voltage regulator. After powered on, with CE pin assertion, feedback voltage signal from the integrated resistor network and a voltage related to the voltage reference are transmit to positive input terminal and negative input terminal of an error amplifier (EA) respectively. The output signal of EA is used to control the open-state of power MOSFET. After soft-start, feedback voltage signal compares with the established reference voltage, making output voltage stable and accurate. AW37030YXXX integrates function of load transient accelerating, making LDO obtain excellent dynamic load transient response performance. Enable Operation AW37030YXXX uses CE pin to realize enable operation. Applying proper value of voltage to CE pin can make IC enable/disable. en If the voltage of CE pin is less than 0.4V, AW37030YXXX is guaranteed to be disabled. In this state, function modules of IC and power MOSFET are turned off. And the auto discharge function is enabled making output discharge through a on-state NMOSFET to Ground. In disable state, AW37030YXXX only consumes a typical 10nA current. fid If the voltage of CE pin is more than 1V, AW37030YXXX is guaranteed to be enabled. In this state, the auto discharge function is disabled, and AW37030YXXX regulates output voltage to the designed value of voltage. on A 140nA pull down current to Ground is built-in at CE pin, making sure that the IC is disabled when CE pin floats. If Enable function is not required, CE pin should be connected directly to IN pin. Output Current Limit AW37030YXXX integrates output current limit function, protecting IC from excessive current. cC When the load is excessively heavy, AW37030YXXX limits the current flowing through the IC to a typical 500mA current. This value is specially designed, so that IC is protected properly and the output capability of 300mA is not influenced either. aw ini Meanwhile, AW37030YXXX integrates a 120mA fold-back current limit function, lowering the system dissipation when output overload or short to Ground. Thermal Shutdown AW37030YXXX integrates thermal shutdown function, protect IC from excessively high temperature. When the chip temperature exceeds 160°C, AW37030YXXX detects it as an over-temperature event, triggering thermal shutdown, which will turn off the main function module, including power MOSFET. This inhibits increase of chip’s temperature. IC would keep the protection-state on until the chip’s temperature falls below to 130°C. At this moment, the over-temperature protection-state is released, IC resumes to work again.The hysteresis avoids IC’s turning off and on frequently around the the Thermal Shutdown threshold. Auto Discharge AW37030YXXX makes output voltage discharge quickly when in CE disable state or thermal shutdown state, benefit from integrating auto discharge function. Auto discharge function is implemented by integrated a NMOSFET of typical 130Ω Rdson route from Output to Ground, and the route is get through in CE disable state or thermal shutdown state. This feature prevents residual charge voltage on the output capacitor, which may impact proper power up of the system connected to the converter. It should be noted that auto discharge function is optional according to different specs. www.awinic.com 16 © 2023 Shanghai Awinic Technology Co., Ltd. All Rights Reserved AW37030YXXX Apr. 2023 V2.0 Application Information Power Dissipation and Device Operation The permissible power dissipation is dependent on the ambient temperature TA and the junction-to-ambient thermal resistance RθJA. l The absolute maximum allowable power dissipation for the device in a given package can be calculated using Equation below, where TJ_MAX = 150°C : tia PDMAX_ABS = (TJ_MAX – TA) / RθJA The recommended maximum allowable power dissipation for the device in a given package can be calculated using Equation below, where TJ_REC = 125°C : PDMAX_REC = (TJ_REC – TA) / RθJA en The actual power being dissipated in the device can be represented by Equation below: PDACT = (VIN – VOUT) × IOUT fid These equations above establish the relationship between the maximum power dissipation allowed due to thermal consideration, the voltage drop across the device, and the continuous current capability of the device. The graphs of Power Dissipation vs. Ambient Temperature are showed below : AW37030YXXXDNR 600 AW37030YXXXSTR 800 PDMAX_REC PDMAX_ABS on PDMAX_REC PDMAX_ABS 500 700 300 200 100 0 0 20 40 60 80 100 120 140 aw ini -40 -20 PD (mW) 500 cC PD (mW) 600 400 400 300 200 100 0 -40 -20 0 20 40 60 80 100 120 140 TA (°C) TA (°C) Power Dissipation vs. Ambient Temperature Power Dissipation vs. Ambient Temperature The above graphs show the maximum power dissipation of the respective package at TJ_REC = 125°C and TJ_MAX = 150°C. Operating the device in the region between PDMAX_REC and PDMAX_ABS might have a negative influence on its lifetime. Capacitors Selection IN pin: Input Capacitor CIN AW37030YXXX advises to use a 1F or more X5R or X7R ceramic capacitor at IN pin as shown in Typical Application Circuit. OUT pin: Output Capacitor COUT AW37030YXXX advises to use a 1F or more X5R or X7R ceramic capacitor at OUT pin as shown in Typical Application Circuit. www.awinic.com 17 © 2023 Shanghai Awinic Technology Co., Ltd. All Rights Reserved AW37030YXXX Apr. 2023 V2.0 Recommended Components List Component PART No. DESCRIPTION MFR TYP. UNIT CIN GRM155R61A105KE15 10V, X5R, 0402 MURATA 1 F COUT GRM155R61A105KE15 10V, X5R, 0402 MURATA 1 F tia l PCB Layout Consideration en The performance of a power source circuit using this device is highly dependent on a peripheral circuit. To obtain the optimal performance, a peripheral component or the device mounted on PCB should not exceed its rated voltage, rated current or rated power. When designing a peripheral circuit, guidelines below for PCB layout of AW37030YXXX should be obeyed: fid 1. All peripheral components should be placed as close to the chip as possible. CIN and COUT should be close to IN and OUT pins respectively. Avoid connecting device and chip pins with two different layers of copper, use the same layer of copper instead. 2. IN and OUT pin are the large current input and output of the chip, make IN, OUT, and meanwhile GND lines sufficient. on 3. The connection lines between the planes of CIN or COUT and respective chip pin should be as short and wide as possible, to reduce noise and EMI interference, or it may cause noise pickup or unstable operation. aw ini cC 4. The exposed plane of chip and GND pins must be connected to the large-area ground layer of PCB directly, meanwhile place sufficient vias below the exposed plane. Thus we can decrease the thermal resistor on the board to optimize heat-diffusion performance. www.awinic.com 18 © 2023 Shanghai Awinic Technology Co., Ltd. All Rights Reserved AW37030YXXX Apr. 2023 V2.0 Tape And Reel Information DFN 1mmX1mm-4L TAPE DIMENSIONS REEL DIMENSIONS P1 P0 P2 K0 tia l W D1 B0 A0 en Cavity fid A0:Dimension designed to accommodate the component width B0:Dimension designed to accommodate the component length K0:Dimension designed to accommodate the component thickness W:Overall width of the carrier tape P0:Pitch between successive cavity centers and sprocket hole P1:Pitch between successive cavity centers P2:Pitch between sprocket hole D1:Reel Diameter D0:Reel Width on D0 QUADRANT ASSIGNMENTS FOR PIN 1 ORIENTATION IN TAPE cC Pin 1 Q1 Q2 Q1 Q2 Q1 Q2 Q1 Q2 Q3 Q4 Q3 Q4 Q3 Q4 Q3 Q4 Sprocket Holes User Direction of Feed Pocket Quadrants aw ini Note:The above picture is for reference only. Please refer to the value in the table below for the actual size DIMENSIONS AND PIN1 ORIENTATION D1 (mm) D0 (mm) A0 (mm) B0 (mm) K0 (mm) P0 (mm) P1 (mm) P2 (mm) 178 8.4 1.14 1.17 0.56 2 4 4 W Pin1 Quadrant (mm) 8 Q1 All dimensions are nominal www.awinic.com 19 © 2023 Shanghai Awinic Technology Co., Ltd. All Rights Reserved AW37030YXXX Apr. 2023 V2.0 SOT 23-5L TAPE DIMENSIONS REEL DIMENSIONS P1 P0 P2 K0 W tia l B0 D1 A0 en Cavity fid A0:Dimension designed to accommodate the component width B0:Dimension designed to accommodate the component length K0:Dimension designed to accommodate the component thickness W:Overall width of the carrier tape P0:Pitch between successive cavity centers and sprocket hole P1:Pitch between successive cavity centers P2:Pitch between sprocket hole D1:Reel Diameter D0:Reel Width D0 Pin 1 Q2 Q1 Q2 cC Q1 on QUADRANT ASSIGNMENTS FOR PIN 1 ORIENTATION IN TAPE Q3 Q4 Q3 Q4 Sprocket Holes Q1 Q2 Q1 Q2 Q3 Q4 Q3 Q4 User Direction of Feed Pocket Quadrants aw ini Note:The above picture is for reference only. Please refer to the value in the table below for the actual size DIMENSIONS AND PIN1 ORIENTATION D1 (mm) D0 (mm) A0 (mm) B0 (mm) K0 (mm) P0 (mm) P1 (mm) P2 (mm) 178 8.4 3.3 3.2 1.4 2 4 4 W Pin1 Quadrant (mm) 8 Q3 All dimensions are nominal www.awinic.com 20 © 2023 Shanghai Awinic Technology Co., Ltd. All Rights Reserved AW37030YXXX Apr. 2023 V2.0 Package Description DFN 1mmX1mm-4L 1.00±0.05 Top View fid en 1.00±0.05 tia l PIN1 CORNER 3 aw ini 1 cC 0.12 REF 2 2X0.65 TYP on 4X0.06 REF MAX 0.05 4X(0.22±0.05) SYMM 4 0.37±0.03 SYMM 4X(0.25±0.05) Bottom View Side View Unit:mm www.awinic.com 21 © 2023 Shanghai Awinic Technology Co., Ltd. All Rights Reserved AW37030YXXX Apr. 2023 V2.0 SOT 23-5L MAX1.25 1.62±0.1 1 5 3 4 PKG tia on 2.8±0.2 fid 5X(0.36~0.50) en 0.59 REF 2.926±0.1 SYMM 2 1.90 TYP 2X0.95 TYP cC 0~0.15 1.00~1.20 Side View Top View aw ini l 0.81REF Pin 1 0.14~0.20 0°~8° 0.35~0.60 Side View Unit: mm www.awinic.com 22 © 2023 Shanghai Awinic Technology Co., Ltd. All Rights Reserved AW37030YXXX Apr. 2023 V2.0 Land Pattern Data DFN 1mmX1mm-4L 2X0.95 TYP 4X0.29 TYP SYMM en 3 2 l tia 4 1 2X0.65 TYP 4X0.22 TYP 4X(0.06) SYMM 0.05 MIN ALL AROUND SOLDER MASK OPENING SOLDER MASK OPENING cC 0.05 MAX ALL AROUND on fid 4X0.45 TYP METAL UNDER SOLDER MASK METAL aw ini NON SOLDER MASK DEFINED www.awinic.com SOLDER MASK DEFINED UNIT : 23 mm © 2023 Shanghai Awinic Technology Co., Ltd. All Rights Reserved AW37030YXXX Apr. 2023 V2.0 SOT 23-5L 5X0.80 TYP 1 5X0.60 TYP 5 tia l 2X0.95 TYP 2 2.50 REF en SYMM 3 PKG fid 4 cC 0.05 MAX All AROUND on 3.20 REF SOLDER MASK OPENING aw ini METAL NON SOLDER MASK DEFINED www.awinic.com 0.05 MIN All AROUND SOLDER MASK OPENING METAL UNDER SOLDER MASK SOLDER MASK DEFINED Unit:mm 24 © 2023 Shanghai Awinic Technology Co., Ltd. All Rights Reserved AW37030YXXX Apr. 2023 V2.0 Reflow Note cC Ramp-up rate(TSmax to TP) on fid en tia l Reflow Spec 3°C/second max. Preheat temperature(Tsmin to Tsmax) 150°C to 200°C Preheat time(ts) 60 – 180 seconds aw ini Time above TL , 217°C(tL) 60 – 150 seconds Peak temperature(TP) 260°C Time within 5°C of peak temperature(tP) 20 – 40 seconds Ramp-down rate 6°C/second max. Time 25°C to peak temperature 8 minutes max. www.awinic.com 25 © 2023 Shanghai Awinic Technology Co., Ltd. All Rights Reserved AW37030YXXX Apr. 2023 V2.0 Revision History Nov. 2020 V1.2 Jan. 2021 V1.3 Jan. 2021 V1.4 Mar. 2021 V1.5 Apr. 2021 V1.6 Jul. 2021 V1.7 Oct. 2021 V1.8 Aug. 2022 V1.9 Mar. 2023 V2.0 Apr. 2023 Add Maximum power consumption and Inrush Current Add test waves of 1.2V; Add name rule; Add VOUT of 1.1V and 1.5V; Add wave of Output Spectral Noise Density Add SOT 23-5L package Add VOUT of 2.85V and 3.1V; Remove test waves of 1.2V and add electical characteristics of 1.1V l V1.1 Officially released VOUT_ACC at TA=25℃ change to ±1%; LOADREG MAX change to 20mV; IQ MAX change to 100A Add VOUT of 1.2V and 2.5V tia Jan. 2020 en V1.0 Change Record Replenish Thermal Metric parameters; Add VOUT of 2.9V 2.95V; Add graphs of Power Dissipation vs. Ambient Temperature; Add reflow curve; Add max of Vdropout Update Tape And Reel Information of DFN 1mmX1mm-4L and SOT 23-5L packages; Update Package Description of SOT 23-5L package Update DFN 1mmX1mm-4L package description, Remove one of the Side Views(P21); DFN 1mmX1mm-4L package add VOUT of 1.55V(P1 P4 P5) fid Date Update Tape And Reel Information of DFN 1mmX1mm-4L package(P19); aw ini cC on Version www.awinic.com 26 © 2023 Shanghai Awinic Technology Co., Ltd. All Rights Reserved AW37030YXXX Apr. 2023 V2.0 Disclaimer All trademarks are the property of their respective owners. Information in this document is believed to be accurate and reliable. However, Shanghai AWINIC Technology Co., Ltd (AWINIC Technology) does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. tia l AWINIC Technology reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. Customers shall obtain the latest relevant information before placing orders and shall verify that such information is current and complete. This document supersedes and replaces all information supplied prior to the publication hereof. en AWINIC Technology products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an AWINIC Technology product can reasonably be expected to result in personal injury, death or severe property or environmental damage. AWINIC Technology accepts no liability for inclusion and/or use of AWINIC Technology products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. fid Applications that are described herein for any of these products are for illustrative purposes only. AWINIC Technology makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. on All products are sold subject to the general terms and conditions of commercial sale supplied at the time of order acknowledgement. Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. cC Reproduction of AWINIC information in AWINIC data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. AWINIC is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. aw ini Resale of AWINIC components or services with statements different from or beyond the parameters stated by AWINIC for that component or service voids all express and any implied warranties for the associated AWINIC component or service and is an unfair and deceptive business practice. AWINIC is not responsible or liable for any such statements. www.awinic.com 27 © 2023 Shanghai Awinic Technology Co., Ltd. All Rights Reserved
AW37030D300DNR 价格&库存
很抱歉,暂时无法提供与“AW37030D300DNR”相匹配的价格&库存,您可以联系我们找货
