BZT52C5V6S
BZT52C5V6S
    ELECSUPER(静芯微)
    SOD-323
    耗散功率:0.2W 齐纳电压:5.6V 稳压范围:5.2~6V 最大齐纳 阻抗:40Ω 最大反向 电流:1UA 最大正向 电压:0.9V
BZT52C5V6S 数据手册
BZT52CxxS SERIES Rev-1.1 www.elecsuper.com SuperDiode – 200mW SOD-323 Plastic-Encapsulate Zener Diode 1. Features 2. Mechanical Data ⚫ Low zener impedance ⚫ SOD-323 Small Outline Plastic Package ⚫ Power dissipation of 200mW ⚫ Polarity: Color band denotes cathode end ⚫ High stability and high reliability ⚫ Mounting Position: Any 3. Marking and Circuit Marking 1 Circuit 2 1 Marking 2 4. Specification Absolute Maximum Rating & Thermal Characteristics Ratings at 25 ℃ ambient temperature unless otherwise specified. Parameters Symbol Value Unit Forward voltage @IF=10mA VF 0.9 2) V Power dissipation PD 200 1) mW Storage temperature range TS -65~150 ℃ 1) Device mounted on ceramic PCB: 7.6mm x 9.4mm x 0.87mm with pad areas 25mm² 2) Short duration test pulse used to minimize self-heating effect 3) f=1KHz Electrical Characteristics (At TA = 25℃ unless otherwise specified) Maximum Maximum Zener Zener Voltage Range Typical Reverse Impedance Test Temperature Current Device Zzt Vz@Izt WY Nom(V) Min(V) Max(V) mA 2.0 1.8 2.15 5 Copyright© ElecSuper Incorporated IZTC Zzk Izt @Izt BZT52C2V0S Current coefficent Marking @IZTC=mV/℃ Izk IR VR mA uA V Min Max mA 1.0 100.0 1.0 -3.5 0.0 5 @Izk Ω 150 Contact Us 600 1 / 6 BZT52CxxS SERIES Rev-1.1 www.elecsuper.com BZT52C2V4S WX 2.4 2.2 2.6 5 100 600 1.0 50.0 1.0 -3.5 0.0 5 BZT52C2V7S W1 2.7 2.5 2.9 5 100 600 1.0 20.0 1.0 -3.5 0.0 5 BZT52C3V0S W2 3.0 2.8 3.2 5 95 600 1.0 10.0 1.0 -3.5 0.0 5 BZT52C3V3S W3 3.3 3.1 3.5 5 95 600 1.0 5.0 1.0 -3.5 0.0 5 BZT52C3V6S W4 3.6 3.4 3.8 5 90 600 1.0 5.0 1.0 -3.5 0.0 5 BZT52C3V9S W5 3.9 3.7 4.1 5 90 600 1.0 3.0 1.0 -3.5 0.0 5 BZT52C4V3S W6 4.3 4.0 4.6 5 90 600 1.0 3.0 1.0 -3.5 0.0 5 BZT52C4V7S W7 4.7 4.4 5.0 5 80 500 1.0 3.0 2.0 -3.5 0.2 5 BZT52C5V1S W8 5.1 4.8 5.4 5 60 480 1.0 2.0 2.0 -2.7 1.2 5 BZT52C5V6S W9 5.6 5.2 6.0 5 40 400 1.0 1.0 2.0 -2.0 2.5 5 BZT52C6V2S WA 6.2 5.8 6.6 5 10 150 1.0 3.0 4.0 0.4 3.7 5 BZT52C6V8S WB 6.8 6.4 7.2 5 15 80 1.0 2.0 4.0 1.2 4.5 5 BZT52C7V5S WC 7.5 7.0 7.9 5 15 80 1.0 1.0 5.0 2.5 5.3 5 BZT52C8V2S WD 8.2 7.7 8.7 5 15 80 1.0 0.7 5.0 3.2 6.2 5 BZT52C9V1S WE 9.1 8.5 9.6 5 15 100 1.0 0.5 6.0 3.8 7.0 5 BZT52C10S WF 10.0 9.4 10.6 5 20 150 1.0 0.2 7.0 4.5 8.0 5 BZT52C11S WG 11.0 10.4 11.6 5 20 150 1.0 0.1 8.0 5.4 9.0 5 BZT52C12S WH 12.0 11.4 12.7 5 25 150 1.0 0.1 8.0 6.0 10.0 5 BZT52C13S WI 13.0 12.4 14.1 5 30 170 1.0 0.1 8.0 7.0 11.0 5 BZT52C15S WJ 15.0 13.8 15.6 5 30 200 1.0 0.1 10.5 9.2 13.0 5 BZT52C16S WK 16.0 15.3 17.1 5 40 200 1.0 0.1 11.2 10.4 14.0 5 BZT52C18S WL 18.0 16.8 19.1 5 45 225 1.0 0.1 12.6 12.4 16.0 5 BZT52C20S WM 20.0 18.8 21.2 5 55 225 1.0 0.1 14.0 14.4 18.0 5 BZT52C22S WN 22.0 20.8 23.3 5 55 250 1.0 0.1 15.4 16.4 20.0 5 BZT52C24S WO 24.0 22.8 25.6 5 70 250 1.0 0.1 16.8 18.4 22.0 5 BZT52C27S WP 27.0 25.1 28.9 2 80 300 0.5 0.1 18.9 21.4 25.3 2 BZT52C30S WQ 30.0 28.0 32.0 2 80 300 0.5 0.1 21.0 24.4 29.4 2 BZT52C33S WR 33.0 31.0 35.0 2 80 325 0.5 0.1 23.1 27.4 33.4 2 BZT52C36S WS 36.0 34.0 38.0 2 90 350 0.5 0.1 25.2 30.4 37.4 2 BZT52C39S WT 39.0 37.0 41.0 2 130 350 0.5 0.1 27.3 33.4 41.2 2 BZT52C43S WU 43.0 40.0 46.0 2 100 700 1.0 0.1 32.0 10.0 12.0 5 BZT52C47S WV 47.0 44.0 50.0 2 100 750 1.0 0.1 35.0 10.0 12.0 5 BZT52C51S WW 51.0 48.0 54.0 2 100 750 1.0 0.1 38.0 10.0 12.0 5 BZT52C56S XW 56.0 52.0 60.0 2 135 700 1.0 0.1 39.0 10.0 12.0 5 BZT52C62S 6E 62.0 58.0 66.0 2 200 1000 1.0 0.2 47.0 10.0 12.0 5 BZT52C68S 6F 68.0 64.0 72.0 2 250 1000 1.0 0.2 52.0 10.0 12.0 5 BZT52C75S 6H 75.0 70.0 79.0 2 300 1000 1.0 0.2 57.0 10.0 12.0 5 Copyright© ElecSuper Incorporated Contact Us 2 / 6 BZT52CxxS SERIES Rev-1.1 www.elecsuper.com 5. Typical Characteristic Copyright© ElecSuper Incorporated Contact Us 3 / 6 BZT52CxxS SERIES Rev-1.1 Copyright© ElecSuper Incorporated Contact Us www.elecsuper.com 4 / 6 BZT52CxxS SERIES Rev-1.1 www.elecsuper.com 6. Dimension and Patterns (SOD-323) E A b D E1 A2 A1 c L L1 θ Symbol A A1 A2 b c D Min. 0.000 0.800 0.250 0.080 1.200 Max. 1.000 0.100 0.900 0.350 0.150 1.400 Symbol E E1 L L1 θ Units: mm Max. 1.800 2.750 Min. 1.600 2.550 0.475REF 0.250 0° 0.400 8° Note: 1. Controlling dimension: in millimeters 2. General tolerance: ±0.05mm 3. The pad layout is for reference only 4. Unit: mm Copyright© ElecSuper Incorporated Contact Us 5 / 6 BZT52CxxS SERIES Rev-1.1 www.elecsuper.com DISCLAIMER ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application; (2) designing, validating and testing your application; (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products. Copyright© ElecSuper Incorporated Contact Us 6 / 6
BZT52C5V6S 价格&库存
很抱歉,暂时无法提供与“BZT52C5V6S”相匹配的价格&库存,您可以联系我们找货
BZT52C5V6S
  • 5+0.10746
  • 50+0.08176
  • 150+0.06750
  • 500+0.05897
  • 3000+0.05152
  • 6000+0.04752
库存:458
