XT Series
Features
· Endurance : 105℃ 2000H
· Designed for reflow soldering
· Designed for surface mounting on high-density PCB
Marking color:Black
· RoHS 2.0 compliant
· 219 SVHC & REACH compliant
Specifications
Category temp. range
–55℃ to +105℃
Capacitance tolerance
±20% (120 Hz / +20 ℃)
Leakage current
I ≦ 0.01 CV or 3 μA whichever is greater (after 2 minutes)
Tan δ
Please see the attached characteristics list
Characteristics at low
temperature
Rated voltage(V)
6.3
10
16
25
35
50
63
100
Z (-25 ℃) / Z (+20 ℃)
4
4
3
2
2
2
2
3
Z (-55 ℃) / Z (+20 ℃)
12
8
6
4
3
3
3
4
Impedance ratio
at 120 Hz
After applying rated working voltage for 2000 hours at +105 ℃ ± 2 ℃, and then being stabilized at +20 ℃,
capacitors shall meet the following limits.
φD ≦ 6.3mm:Within ±25% of the initial value
Capacitance change
Endurance
φD ≧ 8mm:Within ±20% of the initial value
φD ≦ 6.3mm:Less than 300% of the initial value
φD ≧ 8mm:Less than 200% of the initial value
Dissipation factor (tan δ)
Leakage current
Within the initial limit
After storage for 1000 h at +105 ℃ ± 2 ℃ with no voltage applied and then being stabilized at +20 ℃,
Shelf life
capacitors shall meet the limits specified in endurance.
After reflow soldering and then being stabilized at +20 ℃, capacitors shall meet the following limits.
Resistance to
Capacitance change
Within ±10% of the initial value
soldering heat
Leakage current
Frequency correction
factor for ripple current
Frequency
50Hz
120Hz
1kHz
10kHz≦
C ≦ 1000μF
0.7
1.0
1.2
1.3
C > 1000μF
0.8
1.0
1.1
1.2
Marking:
φD ≦ 10mm
Dimensions
φD ≧ 12.5mm
Unit:mm
φD
L
A
B
C
W
P±0.2
4
5.7±0.3
4.3
4.3
5.1
0.5~0.8
1.0
5
5.7±0.3
5.3
5.3
6.1
0.5~0.8
1.3
6.3
5.7±0.3
6.6
6.6
7.3
0.5~0.8
2.2
6.3
7.7±0.3
6.6
6.6
7.3
0.5~0.8
2.2
8
6.5±0.5
8.3
8.3
9.2
0.7~1.2
3.1
8
10.5±0.5
8.3
8.3
9.2
0.7~1.2
3.1
10
7.7±0.3
10.3
10.3
11.2
0.7~1.2
4.4
10
10.5±0.5
10.3
10.3
11.2
0.7~1.2
4.4
10
13±0.5
10.3
10.3
11.2
0.7~1.2
4.4
12.5
13.5±0.5
13.0
13.0
14.0
1.0~1.4
4.4
12.5
16±0.5
13.0
13.0
14.0
1.0~1.4
4.4
Dimensions:
Part Number System:
XT series
16V
220μF
±20 %
6.3φX7.7L
XT
1C
221
M
0607
Case Size
Series name
Rated voltage
Capacitance
Characteristics list
Case size
Specification
Taping&Reel
Rated
Capacitance
voltage
(±20%)
øD
L
(V)
(μF)
(mm)
(mm)
22
4
5.7
22
0.35
XT0J220M0406
2000
33
5
5.7
34
0.35
XT0J330M0506
1000
47
5
5.7
38
0.35
XT0J470M0506
1000
5
5.7
45
0.35
XT0J101M0506
1000
6.3
5.7
69
0.35
XT0J101M0606
1000
6.3
5.7
95
0.35
XT0J221M0606
1000
6.3
7.7
120
0.35
XT0J221M0607
1000
6.3
7.7
105
0.35
XT0J331M0607
1000
8
6.5
120
0.35
XT0J331M0806
1000
100
220
6.3
330
470
current①
tan δ ②
Part Number ③
MPQ
(pcs/reel)
(mA rms)
8
10.5
230
0.35
XT0J331M0810
500
6.3
7.7
120
0.35
XT0J471M0607
1000
8
10.5
230
0.35
XT0J471M0810
500
1000
10
10.5
315
0.37
XT0J102M1010
500
2200
12.5
13.5
620
0.42
XT0J222M1313
200
22
4
5.7
23
0.24
XT1A220M0406
2000
4
5.7
25
0.24
XT1A330M0406
2000
5
5.7
35
0.24
XT1A330M0506
1000
5
5.7
38
0.24
XT1A470M0506
1000
5
5.7
45
0.24
XT1A101M0506
1000
6.3
5.7
69
0.24
XT1A101M0606
1000
6.3
5.7
80
0.24
XT1A151M0606
1000
6.3
5.7
80
0.24
XT1A221M0606
1000
6.3
7.7
120
0.24
XT1A221M0607
1000
8
6.5
120
0.24
XT1A221M0806
1000
6.3
7.7
125
0.24
XT1A331M0607
1000
8
10.5
290
0.24
XT1A331M0810
500
33
47
100
150
10
Rated ripple
220
330
8
10.5
290
0.24
XT1A471M0810
500
10
7.7
290
0.24
XT1A471M1007
500
1000
10
10.5
400
0.26
XT1A102M1010
500
2200
12.5
13.5
680
0.38
XT1A222M1313
200
10
4
5.7
XT1C100M0406
2000
4
5.7
22
0.20
XT1C220M0406
2000
5
5.7
30
0.20
XT1C220M0506
1000
5
5.7
35
0.20
XT1C330M0506
1000
6.3
5.7
45
0.20
XT1C330M0606
1000
5
5.7
39
0.20
XT1C470M0506
1000
6.3
5.7
55
0.20
XT1C470M0606
1000
6.3
5.7
70
0.20
XT1C101M0606
1000
8
6.5
120
0.20
XT1C101M0806
1000
6.3
7.7
120
0.20
XT1C221M0607
1000
8
6.5
120
0.20
XT1C221M0806
1000
8
10.5
220
0.20
XT1C221M0810
500
470
22
33
47
100
16
220
330
470
1000
① Rated ripple current (120Hz / +105℃)
8
10.5
220
0.20
XT1C331M0810
500
10
7.7
200
0.20
XT1C331M1007
500
8
10.5
250
0.20
XT1C471M0810
500
10
10.5
340
0.20
XT1C471M1010
500
10
10.5
340
0.22
XT1C102M1010
500
10
13
390
0.22
XT1C102M1013
400
12.5
13.5
500
0.32
XT1C102M1313
200
② tan δ (120Hz / +20℃)
※ Please refer to the page of reflow conditions for reflow profile.
③ For plastic reel packaging,the Part Number is appended with "PR" at the end.
Case size
Specification
Taping&Reel
Rated
Capacitance
voltage
(±20%)
øD
L
(V)
(μF)
(mm)
(mm)
4.7
4
5.7
17
0.18
XT1E4R7M0406
2000
4
5.7
XT1E100M0406
2000
5
5.7
27
0.18
XT1E100M0506
1000
10
Part Number ③
MPQ
(pcs/reel)
(mA rms)
5.7
30
0.18
XT1E220M0506
1000
5.7
44
0.18
XT1E220M0606
1000
5
5.7
35
0.18
XT1E330M0506
1000
6.3
5.7
46
0.18
XT1E330M0606
1000
6.3
5.7
48
0.18
XT1E470M0606
1000
8
6.5
79
0.18
XT1E470M0806
1000
6.3
7.7
100
0.18
XT1E101M0607
1000
8
6.5
100
0.18
XT1E101M0806
1000
8
10.5
150
0.18
XT1E101M0810
500
8
10.5
200
0.18
XT1E221M0810
500
10
7.7
190
0.18
XT1E221M1007
500
8
10.5
220
0.18
XT1E331M0810
500
10
10.5
240
0.18
XT1E331M1010
500
470
10
10.5
280
0.18
XT1E471M1010
500
1000
12.5
13.5
580
0.30
XT1E102M1313
200
4.7
4
5.7
17
0.16
XT1V4R7M0406
2000
4
5.7
17
0.16
XT1V100M0406
2000
5
5.7
25
0.16
XT1V100M0506
1000
5
5.7
30
0.16
XT1V220M0506
1000
6.3
5.7
44
0.16
XT1V220M0606
1000
6.3
5.7
46
0.16
XT1V330M0606
1000
8
6.5
76
0.16
XT1V330M0806
1000
6.3
5.7
50
0.16
XT1V470M0606
1000
6.3
7.7
80
0.16
XT1V470M0607
1000
8
6.5
80
0.16
XT1V470M0806
1000
47
25
100
220
330
10
22
33
47
35
6.3
7.7
85
0.16
XT1V101M0607
1000
8
10.5
150
0.16
XT1V101M0810
500
10
7.7
160
0.16
XT1V101M1007
500
8
10.5
185
0.16
XT1V151M0810
500
8
10.5
220
0.16
XT1V221M0810
500
10
10.5
250
0.16
XT1V221M1010
500
10
10.5
300
0.16
XT1V331M1010
500
10
13
330
0.16
XT1V331M1013
400
10
10.5
310
0.16
XT1V471M1010
500
10
13
375
0.16
XT1V471M1013
400
12.5
13.5
520
0.22
XT1V471M1313
200
1
4
5.7
8
0.14
XT1H010M0406
2000
2.2
4
5.7
12
0.14
XT1H2R2M0406
2000
3.3
4
5.7
14
0.14
XT1H3R3M0406
2000
4
5.7
14
0.14
XT1H4R7M0406
2000
5
5.7
XT1H4R7M0506
1000
100
150
220
330
470
4.7
10
22
33
47
5
5.7
XT1H100M0506
1000
6.3
5.7
32
0.14
XT1H100M0606
1000
6.3
5.7
38
0.14
XT1H220M0606
1000
6.3
7.7
50
0.14
XT1H220M0607
1000
8
6.5
70
0.14
XT1H220M0806
1000
6.3
7.7
60
0.14
XT1H330M0607
1000
8
6.5
70
0.14
XT1H330M0806
1000
6.3
7.7
63
0.14
XT1H470M0607
1000
8
6.5
85
0.14
XT1H470M0806
1000
8
10.5
100
0.14
XT1H470M0810
500
8
10.5
160
0.14
XT1H101M0810
500
10
7.7
180
0.14
XT1H101M1007
500
10
10.5
160
0.14
XT1H101M1010
500
10
10.5
230
0.14
XT1H221M1010
500
10
13
300
0.14
XT1H221M1013
400
330
12.5
13.5
420
0.18
XT1H331M1313
200
1
4
5.7
8
0.14
XT1J010M0406
2000
2.2
4
5.7
11
0.14
XT1J2R2M0406
2000
5
5.7
14
0.14
XT1J3R3M0506
1000
6.3
5.7
30
0.14
XT1J3R3M0606
1000
6.3
5.7
25
0.14
XT1J4R7M0606
1000
6.3
5.7
24
0.14
XT1J100M0606
1000
8
6.5
25
0.14
XT1J100M0806
1000
6.3
7.7
49
0.14
XT1J220M0607
1000
8
6.5
55
0.14
XT1J220M0806
1000
8
10.5
98
0.14
XT1J220M0810
500
8
10.5
112
0.14
XT1J330M0810
500
8
10.5
119
0.14
XT1J470M0810
500
10
10.5
160
0.14
XT1J470M1010
500
10
10.5
196
0.14
XT1J101M1010
500
10
13
210
0.14
XT1J101M1013
400
12.5
13.5
270
0.16
XT1J101M1313
200
220
12.5
13.5
470
0.16
XT1J221M1313
200
5
5.7
15
0.14
XT2A4R7M0506
1000
4.7
6.3
5.7
21
0.14
XT2A4R7M0606
1000
6.3
7.7
35
0.14
XT2A4R7M0607
1000
6.3
7.7
35
0.14
XT2A100M0607
1000
8
10.5
80
0.14
XT2A100M0810
500
8
10.5
90
0.14
XT2A220M0810
500
10
10.5
130
0.14
XT2A220M1010
500
10
10.5
130
0.14
XT2A330M1010
500
10
10.5
140
0.14
XT2A470M1010
500
10
13
160
0.14
XT2A470M1013
400
12.5
13.5
250
0.16
XT2A470M1313
200
12.5
13.5
380
0.16
XT2A101M1313
200
100
220
3.3
4.7
10
22
33
47
100
10
100
tan δ ②
5
33
63
current①
6.3
22
50
Rated ripple
22
33
47
100
很抱歉,暂时无法提供与“XT1V331M1010”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.56604
- 50+0.44283
- 150+0.38116
- 500+0.32515
- 2500+0.28821
- 5000+0.26974
