180521
180521
    MOUNTZ
180521 数据手册
C F D E B A Tool Balancers These durable, compact tool balancers provide easy handling for operators that work with tools for long, continuous hours. The tool balancers allow tools to be positioned over the work station for comfortable operation and can be used with pneumatic, electric or hydraulic tools. ZERO GRAVITY TOOL BALANCERS RETRACTOR TOOL BALANCERS Provides gravity defying - true balance . Compact & robust. Easy external tensioning adjustment. 360 top swivel. No tension build-up to cause worker fatigue. Aircraft stranded steel cable. Provision for safety cable. Permanent lubrication (for MZ-6 through MZ-264 models). Safety lock (for MZ-33 through MZ-264 models). Lightweight & compact. Easy to adjust tension by using handle. Adjustable cable stop. 360 top swivel. Provision for safety cable. Model Item # MZ-3A 180500 180501 MZ-6 180502 MZ-11 180503 MZ-20 180504 B MZ-33 180505 MZ-48 180506 MZ-66 180507 MZ-88 180508 MZ-110 180509 MZ-132 180510 MZ-154 180511 MZ-198 180532 MZ-231 180533 MZ-264 180534 A MZ-3B in. Stroke m. 19 39 51 51 51 51 59 59 59 59 59 59 82 82 82 0.5 1 1.3 1.3 1.3 1.3 1.5 1.5 1.5 1.5 1.5 1.5 2.1 2.1 2.1 Weight Capacity kg. lbs. Weight lbs. 1.1 - 3.3 1.1 - 3.3 2.2 - 6.6 5.5 - 11 10 - 20 19.8 - 33 33 - 48.4 48 - 66 66 - 88 88 - 110 110 - 132 132 - 154 154 - 198 187 - 231 220 - 264 0.5 1.1 3 3.3 7.5 8.4 15.9 16.8 21.6 23 25.6 26 59.5 63.9 66.1 0.5 - 1.5 0.5 - 1.5 1-3 2.5 - 5 4.5 - 9 9 - 15 15 - 22 22 - 30 30 - 40 40 - 50 50 - 60 60 - 70 70 - 90 85 - 105 100 - 200 Model C MJ-3 MR-3 D MR-6 MR-11 Item # in. Stroke m. 180521 180515 180516 180517 59 79 79 79 1.5 2 2 2 Weight Capacity kg. lbs. 1.1 - 3.3 1.1 - 3.3 2.2 - 6.6 5.5 - 11 0.5 - 1.5 0.5 - 1.5 1-3 2.5 - 5 Weight lbs. 0.7 1.1 1.5 2 HOSE REEL TOOL BALANCERS Designed for small pneumatic tools. Integrating air hose & support cable keep work area clean. Easy to adjust tension by using handle. Provision for safety cable. 1/4" NPT Connector. Model E MH-3 MH-6 MH-11 Item # in. Stroke m. 180512 180513 180514 51 51 51 1.3 1.3 1.3 Weight Capacity kg. lbs. 1.1 - 3.3 2.2 - 6.6 5.5 - 11 0.5 - 1.5 1-3 2.5 - 5 Weight lbs. 1.1 2.2 2.9 TOOL POSITIONER BALANCER Lightweight & small. Tool will remain at whatever level or position left in. Tool Balancers 01.42 F Model Item # in. Stroke m. Mini 31 180029 60 1.5 Weight Capacity kg. lbs. 1 - 12 0.4 - 5.6 Weight lbs. .75 Follow Mountz Keep informed about our torque tool products, events and industry news. Select your favorite social media site to catch the latest news from Mountz.
180521 价格&库存
很抱歉,暂时无法提供与“180521”相匹配的价格&库存,您可以联系我们找货
