2119.85
2119.85
    AEMC
2119.85 数据手册
Special product features ▼ H R E MEN RE SI ST C E MEA SU AN HI G LE LTA G C TA B TS TEST VO LE MEGOHMMETERS 5000V Digital/Analog Model 6505 Contributes to the safety of electrical installations and equipment ES SE SPECIFICATIONS NS TO L AT I O Φ CU MAT I C TIO CA L RA MODEL INSULATION TESTS Test Voltage/Range 500V 1000V 2500V 5000V User Programmable Test Short Circuit Current Accuracy 10kΩ to 40GΩ 40GΩ to 10TΩ DAR (1 min/30 sec) PI (10 min/1 min & user programmable) Capacitance Measurement Leakage Current Measurement Programmable Run Time R(t) Discharge After Test Discharge Voltage Display Voltage Test/Safety Check Voltage Warning Indicator Test Inhibition* Guard Terminal 6505 30kΩ to 2000GΩ (2TΩ) 100kΩ to 4000GΩ (4TΩ) 100kΩ to 10,000GΩ (10TΩ) 300kΩ to 10,000GΩ (10TΩ) 40 to 1000V: 10V increments 1000 to 5100V: 100V increments 25V Yes >25V Yes ELECTRICAL Power Source One 9.6V NiMH battery pack (included); Line power: 85 to 256Vac (50/60Hz) *Inhibit voltage is selectable at 3, 10 or 20% of test voltage PRODUCT INCLUDES Extra large classic tool bag, three color-coded leads, one blue jumper lead for use with guard terminal, three alligator clips (600V CAT IV), US 115V power cord, rechargeable battery pack and user manual. IP 53 Rated FEATURES • True Megohmmeter® • Simple operation • Test voltage selections of 500V, 1000V, 2500V and 5000V • Insulation measurements from 30kΩ to 10TΩ (10,000GΩ) • Adjustable and programmable test voltage (40 to 5100V) • Automatic calculation of DAR and PI values • Direct measurement and display of Capacitance and Leakage Current • Display resistance, test voltage and run time • Programmable test run times and PI ratio times • Automatic test inhibition (if live sample >25V) • Automatic discharge and display of discharge voltage • Large backlight LCD dual-display with time, voltage and measurements shown • Rugged, dual wall, weatherproof field case • Designed and built to IEC safety standards • EN 61010-1, 1000V CAT III CATALOG NO. DESCRIPTION 2130.18 Megohmmeter Model 6505 (Digital, with Analog Bargraph, Backlight, 500V, 1000V, 2500V, 5000V, Auto DAR/PI) Accessories (Optional) 2119.76 2119.77 2119.85 2119.86 2119.87  Lead – Set of 3, Color-coded 10ft 5kV Safety w/3 Color-coded Alligator Clips (1000V CAT IV) 15A for use with Megohmmeter Models 5050/5060/5070/6505 Lead – Replacement, Set of 3, Color-coded 6ft 5kV safety for Megohmmeter Model 6505 Lead – Set of 3, Color-coded 10ft 5kV Safety with Integral Hippo Clips, and jumper lead for use with Megohmmeter Model 6505 (replacement for 5050/5060/5070) Lead – Set of 3, Color-coded 25ft 5kV Safety with Integral Hippo Clips for use with Megohmmeter Models 5050/5060/5070/6505 [Jumper lead not included] Lead – Set of 3, Color-coded 45ft 5kV Safety with Integral Hippo Clips for use with Megohmmeter Models 5050/5060/5070/6505 [Jumper lead not included] Technical Assistance (800) 343-1391 AU
2119.85 价格&库存
很抱歉,暂时无法提供与“2119.85”相匹配的价格&库存,您可以联系我们找货
