500450
500450
    MUXLAB
500450 数据手册
HDMI Mono Extender Kit 500450 Overview The HDMI Mono Extender Kit (500450) allows HDMI equipment to be connected up to 330 ft (100 m) @ 1080p Deep Color via one (1) Cat 5e/6 unshielded twisted pair cables in a point-topoint configuration. The kit comes with one (1) Transmitter and one (1) Receiver as well as an IR Emitter (500998) and IR Sensor (500999) for remote control applications. Applications Commercial and residential AV systems, classroom projector systems, digital signage, boardroom systems, collaborative PC systems, medical information systems. Specifications Environment Devices Transmission Bandwidth Signals Connectors Max. Distance* *Based on a maximum length of 6.6 ft (2m) of HDMI cable per end RJ45 Pin Configuration Reverse Polarity Sensitive Use EIA/TIA 568 A or B, straightthrough wiring. Cable Power Supply Power Consumption Temperature Enclosure Dimensions Weight Compliance Warranty Order Information © MuxLab Inc. 2010 Key Features HDMI 1.3a Up to 330 ft (100m) at all resolutions up to 1080p Deep Color via single Cat5e/6 Supports IR remote source control Includes IR Emitter and IR Sensor HDMI 1.3a DVD, plasma, projectors, monitors, TV, PC, laptops, servers supporting HDMI Transparent to the user 340 MHz HDMI 1.3a One (1) HDMI receptacle. One (1) RJ45S for Cat5e/6 unshielded or shielded twisted pair. 3.5mm jacks for IR emitter and IR Sensor HDMI cables not included. 480i/p: Cat 5e/6: 330 ft (100 m) 720p, 1080i: Cat 5e/6: 330 ft (100 m) 1080p: Cat 5e/6: 330 ft (100 m) 1080p Deep Color: Cat 5e/6: 330 ft (100 m) When installed in an electrically noisy environment, STP cable must be used. Also, cross-connection reduces the effective distance depending on the grade of twisted cable used. RJ45 Pin 1 (R) Pin 2 (T) Pin 3 (R) Pin 6 (T) Pin 4 (R) Pin 5 (T) Pin 7 (R) Pin 8 (T) One (1) Cat5e/6 or better twisted pair cable required. Two (2) 110-240V/12VDC power supply with interchangeable blades included Transmitter: 1.8W Receiver: 3.6W Operating: 0º to 55º C. Storage:-20º to 85º C. Humidity: up to 95% non-condensing. Cast aluminum 4.50” x 3.00” x 1.25” (11.4 x 7.6 x 3.2 cm) 2.0 lb (0.9 kg) Regulatory: FCC, CE, RoHS Flammability: 94V0 2 years 500450 HDMI Mono Extender Kit (includes, Tx, Rx, IR-Emitter, IR Sensor, 2x PSU) HDMI Mono Extender Kit HDMI Mono Extender Kit 500450 __________________________________________________________________________________ Typical Application Rear panels © MuxLab Inc. 2010 HDMI Mono Extender Kit MuxLab Inc. 8495 Dalton Road, Mount Royal, Quebec, Canada, H4T 1V5 Tel: (514) 905 0588 Fax: (514) 905 0589 Toll Free:1 877 689-5228 E-mail: videoease@muxlab.com URL:www.muxlab.com
500450 价格&库存
很抱歉,暂时无法提供与“500450”相匹配的价格&库存,您可以联系我们找货
