A3S2-2.75
A3S2-2.75
    AIMCO
A3S2-2.75 数据手册
BITS AND NUT SETTERS Encajes de Apretamiento AIMCO has assembled the most complete package of commonly used screwdriver bits and nut setters in the industry. Our goal is to supply you with the highest quality bits and nut setters for all your fastener needs. If you’re in the electronics, aerospace or general industry, AIMCO has the bits and nut setters to fit your needs. Most items are available in both American and Japanese industrial standards to properly fit your fasteners. POWER BIT POINT POWER GROOVE BODY SHANK INSERT BIT SNAP RING NOTCH POINT BODY NUT SETTER BODY POWER GROOVE HEX Phillips® Slotted Torx® Supadriv® Square Recess Allen Head Torx® Tamper Resistant Pozidriv® Torq-Set® Tri-Wing® Made to order specials are available upon request. PHILLIPS POWER BITS ® Puntas Phillips® L Part No. A3S0-2 A3S1-2 A3S1-2.75 A3S1-3 A3S1-3.5 A3S1-4 A3S1-6 A3S2-1.2 A3S2-1.6 A3S2-2 A3S2-2.75 A3S2-3 A3S2-3.5 A3S2-4 A3S2-4.7 A3S2-4.75 A3S2-6 A3S2-8 A3S2-10 A3S2-12 A3S3-2 A3S3-2.75 A3S3-3 A3S3-3.5 A3S3-4 A3S3-4.7 A3S3-6 A3S3-8 A3S3-10 A3S3-12 Point Size mm Length in 0 1 1 1 1 1 1 2 2 2 2 2 2 2 2 2 2 2 2 2 3 3 3 3 3 3 3 3 3 3 50 50 70 75 90 100 150 30 40 50 70 75 90 100 120 125 150 200 250 300 50 70 75 90 100 120 150 200 250 300 1.969 1.969 2.756 2.953 3.543 3.938 5.906 1.181 1.574 1.969 2.756 2.953 3.543 3.938 4.724 4.921 5.906 7.874 9.842 11.811 1.969 2.756 2.953 3.543 3.938 4.724 5.906 7.874 9.842 11.811 SLOTTED POWER BITS Puntas Agujereadas Screw Size mm in Blade Thickness Blade Width A3M8-2 A3M8-2.75 A3M8-3 A3M10-2 A3M10-2.75 A3M10-3 A3M12-2 A3M12-2.75 A3M12-3 8 8 8 10 10 10 12 12 12 50 70 75 50 70 75 50 70 75 1.969 2.756 2.953 1.969 2.756 2.953 1.969 2.756 2.953 .042 .042 .042 .046 .046 .046 .050 .050 .050 0.275 0.275 0.275 0.312 0.312 0.312 0.360 0.360 0.360 Reduced Diameter Part No. Screw Size mm in Blade Thickness Blade Width Puntas Ranurados Con Diametro Reducido A3MT1-2 A3MT1-3 A3MT3-2 A3MT3-3 A3MT4-2 A3MT4-2.75 A3MT4-3 A3MT5-2 A3MT5-2.75 A3MT5-3 A3MT6-2 A3MT6-2.75 A3MT6-3 1 1 3 3 4 4 4 5 5 5 6 6 6 50 75 50 75 50 70 75 50 70 75 50 70 75 1.969 2.953 1.969 2.953 1.969 2.756 2.953 1.969 2.756 2.953 1.969 2.756 2.953 .022 .022 .030 .030 .034 .034 .034 .036 .036 .036 .038 .038 .038 0.122 0.122 0.154 0.154 0.188 0.188 0.188 0.250 0.250 0.250 0.250 0.250 0.250 L L Part No. Length Length SLOTTED INSERT BITS Insertos Ranurados Part No. L A38M2-1 A38M2-1.5 A38M3-1 A38M3-1.5 A38M4-1 A38M4-1.5 A38M5-1 A38M6-1 A38M6-1.5 A38M8-1 A38M8-1.5 A38M10-1 A38M10-1.5 A38M12-1.5 A38M14-1.5 TORX POWER BITS Part No. ® Puntas Torx® L For additional Torx Power Bits see pg. 63 A3T6-2 A3T7-2 A3T7-2.75 A3T7-3.5 A3T7-6 A3T8-2 A3T8-2.75 A3T8-3.5 A3T8-6 A3T9-2 A3T9-2.75 A3T9-3.5 A3T9-6 A3T10-2 A3T10-2.75 A3T10-3.5 A3T10-6 Screw Size mm Length in Blade Thickness Blade Width 2 2 3 3 4 4 5 6 6 8 8 10 10 12 14 25 38 25 38 25 38 25 25 38 25 38 25 38 38 38 0.984 1.496 0.984 1.496 0.984 1.496 0.984 0.984 1.496 0.984 1.496 0.984 1.496 1.496 1.496 0.026 0.026 0.030 0.030 0.030 0.034 0.036 0.040 0.040 0.042 0.042 0.046 0.046 0.050 0.550 0.281 0.138 0.154 0.154 0.170 0.188 0.219 0.219 0.218 0.250 0.250 0.281 0.281 0.297 0.344 Torx Size mm Length in T6 T7 T7 T7 T7 T8 T8 T8 T8 T9 T9 T9 T9 T10 T10 T10 T10 50 50 70 90 150 50 70 90 150 50 70 90 150 50 70 90 150 1.969 1.969 2.756 3.543 5.906 1.969 2.756 3.543 5.906 1.969 2.756 3.543 5.906 1.969 2.756 3.543 5.906 TORX POWER BITS ® Puntas Torx® L TAMPER RESISTANT Torx® (Extra Resistencia) L Part No. Torx Size mm in A3T15-2 A3T15-2.75 A3T15-3.5 A3T15-6 A3T20-2 A3T20-2.75 A3T20-3.5 A3T20-6 A3T25-2 A3T25-2.75 A3T25-3.5 A3T25-6 A3T27-2 A3T27-2.75 A3T27-3.5 A3T27-6 A3T30-2 A3T30-2.75 A3T30-3.5 A3T30-6 A3T40-2 A3T40-2.75 A3T40-3.5 A3T40-6 T15 T15 T15 T15 T20 T20 T20 T20 T25 T25 T25 T25 T27 T27 T27 T27 T30 T30 T30 T30 T40 T40 T40 T40 50 70 90 150 50 70 90 150 50 70 90 150 50 70 90 150 50 70 90 150 50 70 90 150 1.969 2.756 3.543 5.906 1.969 2.756 3.543 5.906 1.969 2.756 3.543 5.906 1.969 2.756 3.543 5.906 1.969 2.756 3.543 5.906 1.969 2.756 3.543 5.906 Part No. Torx Size mm in T10 T15 T20 T25 50 50 50 50 1.969 1.969 1.969 1.969 A3T10-2TR A3T15-2TR A3T20-2TR A3T25-2TR Torx® is a registered trademark of the Camcar Division of Textron. Length Length
A3S2-2.75 价格&库存
很抱歉,暂时无法提供与“A3S2-2.75”相匹配的价格&库存,您可以联系我们找货
