4320-1016
4320-1016
    PRESSMASTER
4320-1016 数据手册
Product Embla RA SBC Embla RA SBC is a self adjusting stripping and cutting tool, 0.02-10 mm²/AWG 34-8, Straight blade. Pistol grip provides stress free comfort, particularly when operating parallel to a table or workbench. Tool-less interchangeable stripping cassettes allow a wide and diverse stripping capacity Widest stripping capacity of any tool of its type Durable, integrated wire cutting capability Cutting capacity: Flexible wires, 10 mm²/8 AWG. Rigid wires, 1.5 mm² /16 AWG Fine adjustability for thin or thick insulation, without damage to wire conductors At the end of the stripping function, the stripping blades open and remain open to facilitate easy and snag free wire removal from the tool Ergonomic: strong, durable, and comfortable ergonomic design Replacement stripping cassettes and cutting blades available. Reliable: Frame and mechanism life span exceeds 150,000 cycles (tested with 1.5 mm²/AWG 16 PVC cable). Pressmaster AB P.O. Box 3, Industrivägen SE-796 21 Älvdalen, Sweden Tel: +46 (0)251-451 00 info@pressmaster.se www.pressmaster.com TECHNICAL DATA Length: 144 mm/5.67" Width: 23 mm/0.9" Height: 168 mm/6.61" Weight: 165 gr/0.37 lb Wire size: 0.02-10 mm2 / AWG 34-8 Stripping dimensions mm/mm2: 3-18 mm/adjustable Stripping dimensions inch/AWG: 0.12-0.71''/adjustable Cable: PVC Description: Self-adjusting cutting and stripping tool for electrical installation and equipment wires in PVC insulation. Life span, cycles: 150,000 (tested with 1.5 mm²/AWG 16 PVC cable) All three cassettes (grey, red and blue) are available as separate items. Pressmaster AB P.O. Box 3, Industrivägen SE-796 21 Älvdalen, Sweden Tel: +46 (0)251-451 00 info@pressmaster.se www.pressmaster.com
4320-1016 价格&库存
很抱歉,暂时无法提供与“4320-1016”相匹配的价格&库存,您可以联系我们找货
