03EN151044(50/35)
03EN151044(50/35)
    MICROTHERM(麦柯泰姆)
03EN151044(50/35) 数据手册
Thermal cut-out Thermostat  27 28 29 R Applications - Household appliances - Electronics - Machinery Benefits - Up to 100,000 cycles - Various terminals on-hand - Small tolerances and hysteresis available - Response temperatures from 0°C up to 260°C Technical data control type ratings 11EN 03EN 52N 60EN1) 05EN 15N function automatic manual version normally closed / normally open normally closed rated current at 250 Vac ( cos φ 0,95 ) VDE switching cycles max. temperature Ta ( steps in 5 K ) UL 16 A 16 A 16 A 10 A 16 A 16 A 16 A 10,000 10,000 10,000 100,000 3,000 6,000 3,000 150 °C 150 °C 40 °C ... 250 °C 150 °C 10 A __ 10 A 16 A 10 A 6,000 6,000 6,000 150 °C 250 °C 150 °C 150 °C rated current at 240 Vac ( cos φ 1,0 ) 150 °C 10 A 10 A 230 °C2) switching cycles 100,000 100,000 100,000 __ max. temperature Ta ( steps in 5 K ) 150 °C 150 °C 230 °C __ tolerance Ta 100°C: ± 4 K / Ta >140°C: ± 5 K contact resistance < 30 mΩ hysteresis / reset temperature Ta 100°C: 15 K ± 5 K / Ta >140°C: 20 K ± 5 K degrees of protection provided by enclosures (EN 60529) I, II VDE certifications EN 60730-1 / -2-9 UL873 / UL60730-1A / -2-9 4) UL (E43273 / E201152) C22.2 No. 24 3) CSA no certification 2) type 55H up to 260°C Standard types type R28 11EN nc 1 customer-specific IP00 ( 60EN IP54 ) suitable for use in protection class 1) 23EN 3) different ratings 4) type 15N illustration drawing dimensions ( mm ) technical description no code 3 standard dielectric strength 2,000 Vac terminals 6.3 x 0.8, housing thermosetting plastic 9mm, moving bracket small, cap aluminium terminals 6.3 x 0.8, housing thermosetting plastic 12mm, moving bracket small, cap aluminium R28 03EN 1 3 standard dielectric strength 2,000 Vac R28 52N 1 3 standard dielectric strength 2,000 Vac terminals 6.3 x 0.8, housing ceramic 12mm, moving bracket small, cap aluminium 1 manual dielectric strength 1,800 Vac terminals 6.3 x 0.8, housing thermosetting plastic, moving bracket small, cap aluminium, reset pin 1 manual dielectric strength 1,800 Vac terminals 6.3 x 0.8, housing ceramic, moving bracket small, cap aluminium, reset pin ceramic R29 23EN 1 manual dielectric strength 2,000 Vac R28 60EN 1 R27 05EN R27 15N 3 tight against humidity dielectric strength 1,800 Vac terminals 6.3 x 0.8, housing thermosetting plastic, moving bracket small, cap aluminium, reset pin lead wire 1.25mm2, housing thermosetting plastic, fix bracket, cap aluminium, degree of protection IP54 Fixings illustration drawing dimensions ( mm ) technical description code used in type 4 R27, R28, R29 moving bracket, small 3 R27, R28, R29 moving bracket S R27, R28, R29 stud of M5 x 6 brass, SW17 (also other variations available) B (+A) R27, R28, R29 fix bracket possible angles: 0 / 45 / 90 / 135 deg execution of drawing: 135 deg Terminals code used in type illustration drawing dimensions ( mm ) technical description R27, R28, R29 terminals 4.8 x 0.5 brass nickel plated up to Ta max. 150°C >150°C steel nickel plated also available: angle 45 / 90 deg R27, R28, R29 terminals 4.8 x 0.8 brass nickel plated up to Ta max.150°C also available: angle 90 deg brass: 03 (0 deg) brass: 09 (45 deg) brass: 04 (90 deg) steel: 93 (0 deg) steel: 94 (90 deg) R27, R28, R29 terminals 6.3 x 0.8 brass nickel plated up to Ta max. 150°C >150°C steel nickel plated also available: angle 45 / 90 deg 00 R27, R28 solder terminals Ta max. 140°C 41 (0 deg) 42 (90 deg) R27, R28, R29 solder terminals, nickel plated, also available: angle 90 deg Ta max. 140°C SA R27, R28 PCB terminals solder terminals Ta max. 140°C brass: 05 (0 deg) brass: 10 (45 deg) brass: 06 (90 deg) steel: 95 (0 deg) brass: 45 (0 deg) brass: 46 (90 deg) Caps Cap Code 1 in standard execution (Ta 50°C – 199°C), material aluminium Cap Code T (Ta 0°C – 50°C and Ta ≥ 200°C and all normally open types), material aluminium Deviations from standard controls (caps, terminals, fixings) on request. Especially for electronic applications with voltage 6…120 Vac / 6…30 Vdc and current 10…100 mA, there are switches with crossbar- contacts available. Controls as single operation device (SOD) up to 150°C and reset temperature minus 35°C are available (type 81ES). Ordering and marking example Ordering example R28 03 E N 1 Marking example 5 T 03 4 50±3 40±4 reset temperature response temperature fixing code A100 norm. closed (B norm. open) response temperature 03EN XXXX type manufacture code XXXX date of manufacture terminal code cap code housing material (2 ceramic / 5 plastic) contact execution (1 normally closed / 3 normally open) type of contact (N normal contact / P low current) European version RoHS compliant base type product Microtherm type Representation office: Microtherm GmbH Täschenwaldstraße 3 P.O. Box 1208 D-75112 Pforzheim Fon: +49 (0)7231 787-0 Fax : +49 (0)7231 787-155 E-Mail: info@microtherm.de Internet: www.microtherm.de 03.2014-HB Technical subject to change without notice Deviations from standard controls on request.
03EN151044(50/35) 价格&库存
很抱歉,暂时无法提供与“03EN151044(50/35)”相匹配的价格&库存,您可以联系我们找货
