ER14250
ER14250
    EVE(亿纬锂能)
ER14250 数据手册
T echnical Specification ENERGY VERY ENDURE ER14250 Lithium-thionyl Chloride (Li-SOCl2) Battery International size reference: 1/2AA ELECTRICAL CHARACTERISTICS (typical values for cells stored for one year or less, at 25 C) Nominal capacity 1.20Ah (At 0.5 mA, +25 C, 2.0V cut off. The capacity restored by the cell varies according to current drain, temperature and cut off voltage.) Nominal voltage 3.6V Non-restricted for transport 15mA Maximum recommended continuous current (To get 50% of the nominal capacity at +25 C with 2.0V cut off. Higher currents possible, consult EVE.) Pulse capability: 50 50 MAIN APPLICATIONS Storage (recommended) 30 C max (for more severe condition consult EVE) Operating temperature range -60 C / +85 C (Operation at temperatur e different from ambient may lead to reduced capacit y and lower voltage plateau readings .) Typical weight 10g WARNING: Fire, explosion and severe burn hazard. Do not recharge, crush, disassemble, heat above 100 C, incinerate, or expose contents to water. Note: Any representations in this data sheet concerning performance are for informational purpose only and are not construed as warranties, either expressed or implied, of future performance. ER14250 1.DISCHARGE CHARACTERISTICS@+25 C 2. VOLTAGE VS. TEMPERATURE AVAILABLE TERMINATIONS Suffix-/S Suffix-/P Suffix-/T Suffix-/2PT Suffix-/3PT/3TP Standard Axial Pins Solder Tabs Radial Pins Radial Pins View available terminations 3. CAPACITY VS. CURRENT 4. STORAGE CHARACTERISTICS EVE ENERGY CO., LTD. Address.:EVE Industrial Park, XiKeng Industrial zone, Huihuan Town, Huizhou, Guangdong, China Operator: (86-752)260 6966 Fax: (86-752)260 6033 http:// www.evebattery.com Email: sales@evebattery.com Latest version can be downloaded from the EVE website Liu May 2010
ER14250 价格&库存
很抱歉,暂时无法提供与“ER14250”相匹配的价格&库存,您可以联系我们找货
