323064
323064
    STANNOL
323064 数据手册
Wenn’s ums Löten geht When it’s about soldering Quand il s’agit du soudage Technical Data Sheet STANNOL® FLOWTIN® TSC New Lead-Free Solder Alloy for Electronic Application • Eutectic Solder (melting point at 217°C) • Good wetting performance ® • Fine grain and smooth surface better than ECOLOY TSC (Sn95.5Ag3.8Cu0.7) ® • Reduced dissolution of substrate metal compared to ECOLOY TSC • Easy disposal – no lead containing waste Application ® ® STANNOL FLOWTIN TSC was designed to eliminate the use of lead containing solders in electric and ® electronics manufacturing. Like with ECOLOY TSC solder it is necessary to adjust machine settings, temperature profiles, and other parameters to the requirements of a lead free process. But there is nothing to ® ® do when switching from ECOLOY TSC to FLOWTIN TSC, all settings and parameters remain the same. The properties of the solder joints are at least comparable or even better than tin lead. ® The physical properties of FLOWTIN TSC do not change compared to common tin/silver/copper solder. But ® ® there are differences between ECOLOY TSC and FLOWTIN TSC with micro additives. • • • The solder joint solidifies as fine grain metal; therefore the surface is shinier The dissolution of substrate metal is reduced The service life of solder is extended baths due to lower copper enrichment Product Range ® ® STANNOL FLOWTIN TSC is available as solder bars and solder wire 2,00 FLOWTIN TSC 0.1 µm/sec 1,80 1,60 y = -0,0002x + 1,6739 Durchmesser/mm 1,40 1,20 1,00 0,80 0,60 0,40 y = -0,001x + 1,7197 ECOLOY TSC 0.5 µm/sec 0,20 0,00 0 500 1000 1500 2000 2500 3000 time/ sec ® Radial dissolution of copper wire in FLOWTIN TSC solder bath @300°C The above values are typical and represent no form of specification. The Data Sheet serves for information purposes. Any verbal or written advise is not binding for the company, whether such information originates from the company offices or from a sales representative. This is also in respect of any protection rights of third parties, and does not release the customer from the responsibility of verifying the products of the company for suitability of use for the intended process or purpose. Should any liability on the part of the company arise, the company will only indemnify for loss or damage to the same extent as for defects in quality. TDB_ME_FLOWTIN_TSC_EN.doc Page 1 of 2 Issue: 24.04.06 STANNOL GmbH Oskarstraße 3-7 • 42283 Wuppertal • Tel. +49 (0)202-585-0 • Telefax +49 (0)202-585111 • E-Mail info@stannol.de • Web www.stannol.de Wenn’s ums Löten geht When it’s about soldering Quand il s’agit du soudage Physical and Mechanical Properties of ECOLOY® and FLOWTIN ® solders compared with Sn63Pb37: ® Properties Melting Point /°C electrical Conductivity %IACS electrical resistivity / µΩ Ω cm Brinell Hardness, HB Density /g cm -3 Tensile strength, (20°C) / N mm 2 at 0.004 s 1 Shear rate Shear Strength N mm 2 at 0.1mm 1, 20°C at 0.1mm 1, 100°C Creep Resistance* N mm 20°C 100°C ® ® S-Sn63Pb37 STANNOL ECOLOY TSC (Sn95,5Ag3,8Cu0,7) STANNOL ® ECOLOY TS (S-Sn96Ag4) STANNOL ® ECOLOY TC (S-Sn99Cu1) STANNOL ® FLOWTIN TSC 183 217 221 227 217 11.9 13 14 - - 14.5 13 12.3 - - 17 15 15 - - 8.4 7.5 7.5 7.3 7.5 40 48 58 48 - 23 14 27 17 27 17 23 16 27 16 3.3 1.0 13.0 5.0 13.7 5.0 13.7 5.0 13 5.0 ® -2 Recommended Conditions of Use Wave soldering ® The recommended operation conditions for wave soldering are the same like normal ECOLOY TSC solders, since the melting point remains the same. Purity Like Sn95.5Ag3.8Cu0.7 according to DIN EN 61190-1-3 and DIN EN 29453 / ISO 9453, but with micro-additive
323064 价格&库存
很抱歉,暂时无法提供与“323064”相匹配的价格&库存,您可以联系我们找货
