050/LT/B2
050/LT/B2
    OXLEY
050/LT/B2 数据手册
Snale Snaplox Series Knurled/Barbed Retention Non Plated Through Hole Connectors with Ball Socket [Key Characteristics Functionality • Self retaining interference fit • For single & double sided PCBs • Low insertion force • Unique retention mechanism Resilient • Gold plated • -55 to +125° C Adaptable • Various lengths • Bespoke designs available The use of Snale Pins has been widely established in the commercial and military electronics market worldwide as the definitive terminal pin for use with non-plated through hole PCB’s and chassis. The Snaplox® concept enables highly accurate testing to be done whilst reducing the risk of board damage. This is due to the unique ball and socket arrangement which provides 8 points of low resistance contact through a 60° connection angle. [Technical Information Pin Brass with Gold Finish (option Tin Lead, Palladium) Socket Copper Alloy with Silver Finish & High Dispersion Grade PTFE Solderability Exceeds Requirements of BS2011 (IEC 68) Test T Maximum Contact Resistance (with socket) 2 milliOhms Socket Insulation Resistance 10,000 MegaOhms minimum Typical Retention Force 2kg (Angles 30° or perpendicular) Assembly Tools Socket Assembly - Line Plug AT2/05 or ATS3/05, AT1/09 (Line Plug) Assembly Tools Pin to PCB AT1/09 Telephone: +44 (0)1229 483226 • sales@oxleygroup.com • www.oxleygroup.com INTERCONNECT Printed t Point Snale Snaplox Series [Series Information [Key Characteristics Type No. Mounting Hole Diameter Shoulder diameter 0A PCB Thickness 030/SO/B2 or BF 0.81 mm (0.032") - 0.92 mm (0.036") 1.65 mm (0.065") - 1.85 mm (0.073") 1.6 mm (0.063") ® Printed Point x: 050/- 030/SO/BF 0.81 mm (0.032") - 0.92 mm (0.036") 1.65 mm (0.065") - 1.85 mm (0.073") 1.6 mm (0.063") 030/SO/BCS/- 0.81 mm (0.032") - 0.92 mm (0.036") 1.65 mm (0.065") - 1.85 mm (0.073") 1.6 mm (0.063") Snale Snaplox (Self Retaining Fit for Single and Double sided pcbs) ng Hole Diameter: m (0.048") - 1.37 mm (0.054") hickness: Snale Snaplox 050/- min. (0.055") (Self Retaining Fit for Single and Double sided pcbs) gerHole Diameter: Diameter A: (0.048") (0.094")- 1.37 mm (0.054") ckness: bly Tool: 0.055") min. SNAPLOX® Printed P2 Diameter A: Circuit Test Point 0.094") 050/SO/B2 050/SO/BST x: 060/y Tool: ng Hole Diameter: m (0.060") - 1.62 mm (0.064") Snale Snaplox Prefix: 050/ickness: (Self Retaining Fit for Single and Double sided pcbs) 050/SO/B2 050/SO/BST 060/(0.055") min. Mounting Hole Diameter: Diameter: 050/SOX/B2 1.21 mm (0.048") - 1.37 mm (0.054") erHole Diameter A: 0.060") - 1.62 mm (0.064") PCB Thickness: (0.094") ® Printed kness: 1.4 mm (0.055") min. bly Tool: .055") min. P2 st Point Shoulder Diameter A: 050/SOX/B2 Diameter A: 2.4 mm (0.094") x:.094") 050/-(Snales) Assembly Tool: y Tool: AT 1/KP2 ng Hole Diameter: 050/- 1.25 mm (0.049") - 1.40 mm (0.055") 1.4 mm (0.055") min 2.4 mm (0.094") 050/B2/RS 1.25 mm (0.049") - 1.37 mm (0.054") N/A 2.4 mm (0.094") [Part & Ordering Information SNAPLOX Printed m (0.049") - 1.40 mm (0.055") Snale Snaplox x: 050/Circuit Test Point ickness: (Self Retaining Fit for Single and Double sided pcbs) 050/LT/BST 050/SO/B2 Prefix: 060/ting Hole Diameter: 050/-(Snales) (0.055") min. mm (0.048") - 1.37 mm (0.054") Mounting Hole Diameter: Diameter: erHole Diameter A: Thickness: 0.049") - 1.40 mm (0.055") 1.52 mm (0.060") - 1.62 mm (0.064") (0.094") m (0.055") min. PCB Thickness: kness: bly Tool: Prefix: 050/-050/LT/BST 1.4 mm (0.055") min. der Diameter .055") min. A: m (0.094") Shoulder Diameter A: Mounting Hole Diameter: Diameter A: 2.4 mm (0.094") 1.21 mm (0.048") - 1.37 mm (0.054") mbly Tool: .094") P2 Assembly Tool: PCB Thickness: y Tool: Number: 030/SO/B2 AT 1/KP2 1.4 mm (0.055") min. ng Hole Diameter: Shoulder Diameter A: 050/LT/B2 050/SO/B2 050/SO/BST 060/-- 0.92 mm (0.036") Prefix: 050/-(Snales) Snale Snaplox mx: (0.032") 2.4 mm (0.094") Part Number: 030/SO/BF ing Hole Diameter: ickness: Assembly Tool: Mounting Hole Diameter: umber: m(0.065") (0.060")030/SO/B2 - 1.62MM mm(0.073") (0.064") Mounting Hole Diameter: M - 1.85 AT 1/KP2 1.25 mm (0.049") - 1.40 mm (0.055") 0.81 mm (0.032") - 0.92 mm (0.036") hickness: Hole Diameter: er Diameter A: 050/LT/B2 PCB Thickness: m(0.063") (0.055") min.mm (0.036") 0.032") - 0.92 PCB(0.055") Thickness: 1.4 mm min. Prefix: 060/- 050/SOX/B2 1.65 MM (0.065") - 1.85 MM (0.073") der Diameter A: kness: bly Tool: Shoulder Diameter A: m0.065") (0.094") - 1.85 MM (0.073") Shoulder Diameter A: Mounting Hole Diameter: 2.4 mm (0.094") 1.6 mm (0.063") 1.52 mm (0.060") - 1.62 mm (0.064") mbly Tool: A: Diameter Assembly Tool: P2 .063") Assembly Tool: PCB Thickness: AT 1/09 AT 1/09 1.4 mm (0.055") min. 030/SO/B2 y Tool: x: 050/-(Snales) Shoulder Diameter A: 2.4 mm (0.094") ing Hole Diameter: Part Number: 030/SO/B2 Assembly Tool: m (0.049") - 1.40 mm (0.055") Mounting Hole Diameter: 030/SO/B2 hickness: Part Number: 030/SO/BCS/- AT 1/KP2 050/LT/BST 0.81 mm (0.032") - 0.92 mm (0.036") m (0.055") min. Mounting Hole Diameter: PCB Thickness: Prefix: 050/-(Snales) der Diameter A: 0.81 mm (0.032") - 0.92 mm (0.036") 1.65 MM (0.065") - 1.85 MM (0.073") m (0.094") Mounting Hole Diameter: PCB Thickness: Shoulder DiameterOxley A: Group Australia Pty Ltd 1.25 evelopments Company Oxley Inc. www.oxleygroup.com mm (0.049") - 1.40 mm (0.055") opments Company Ltd LtdOxley Inc. www.oxleygroup.com/interconnect mbly Tool: 1.65 MM (0.065") - 1.85 MM (0.073") ales@oxley.co.uk Email: 1.6sales@oxleyinc.com mm (0.063") @oxley.co.uk Email: sales@oxleyinc.com Email: sales@oxleygroup.com 9(0)1229 483226 PCB Thickness: Shoulder +1 (203) 488 ODC:SM:40566/5/2009 229 840607 Tel: Tel: +1 (203) 488 10331033Diameter Tel +61A: (2) 9967 9193 ODCSM:40566/4/2006 030/SO/BCS/F Assembly Tool: 1.4 mm (0.055") min. 1.6 mm (0.063") AT 1/09 Shoulder Diameter A: Assembly Tool: elopments Company Oxley www.oxleygroup.com ments Company Ltd LtdOxley Inc. Inc. Oxley Group Australia Pty Ltd 2.4 www.oxleygroup.com/interconnect mm (0.094") AT 1/09 or AT 1/KP2 Number: 030/SO/B2 s@oxley.co.uk Email: sales@oxleyinc.com Email: sales@oxleygroup.com xley.co.uk Email: sales@oxleyinc.com Assembly Tool: 483226 +1 (203) ODC:SM:40566/5/2009 91229 840607 +1 (203) 488 488 10331033 Tel +61 (2) 9967 9193 ODCSM:40566/4/2006 ing Hole Diameter: Tel: Tel: 050/LT/B2 AT 1/09 m (0.032") - 0.92 mm (0.036") ® 050/SO/BST 050/SOX/B2 050/LT/B2 050/LT/BST 050/SO/BST Snale Snaplox SNAPLOX® Printed (Self Retaining Fit for Single and Double sided pcbs) 050/SOX/B2 Circuit Test Point Continued 050/LT/BST 050/SO/B2 030/SO/BF 050/SO/B2 050/SO/BST 050/SOX/B2 050/LT/B2 030/SO/BCS/P 050/LT/BST 030/SO/BCS/P hickness: M (0.065") - 1.85 MM (0.073") Part Number: 050/B2/RS Mounting Hole Diameter: Part Number: 030/SO/B2 der Diameter A: 1.25 mm (0.049") - 1.37 mm (0.054") m (0.063") Telephone: +44 (0)1229 483226 • sales@oxleygroup.com • www.oxleygroup.com Mounting Hole Diameter: PCB Thickness: 0.81 mm (0.032") - 0.92 mm (0.036") mbly Tool: N/A 9 PCB Thickness: 030/SO/B2 050/B2/RS INTERCONNECT 050/LT/B2 1.25 mm (0.049") - 1.40 mm (0.055") PCB Thickness: 1.4 mm (0.055") min. Shoulder Diameter A: 2.4 mm (0.094") Assembly Tool: AT 1/09 Snale Snaplox Continued 050/LT/BST Part Number: 030/SO/BF Snale Snaplox Series Part Number: 030/SO/BF Snale Snaplox Continued Mounting Hole Diameter: 0.81 mm (0.032") - 0.92 mm (0.036") PCB Thickness: Mounting Hole Diameter: MM (0.065") MM (0.073") 0.81 1.65 mm (0.032") - 0.92- 1.85 mm (0.036") Diameter A: PCBShoulder Thickness: 050/LT/B2 (0.063") 1.65 1.6 MMmm (0.065") - 1.85 MM (0.073") Assembly Tool:A: Shoulder Diameter AT (0.063") 1/09 1.6 mm [Part & Ordering Information Part Number: 030/SO/B2 Mounting Hole Diameter: 0.81 mm (0.032") - 0.92 mm (0.036") PCB Thickness: 1.65 MM (0.065") - 1.85 MM (0.073") Shoulder Diameter A: 1.6 mm (0.063") Assembly Tool: AT 1/09 030/SO/BF 030/SO/BF Assembly Tool: AT 1/09 Part Number: 030/SO/BCS/030/SO/B2 Part Number: 030/SO/BF Mounting Hole Diameter: 0.81 mm (0.032") - 0.92 mm (0.036") PCB Thickness: ® 1.65 MM (0.065") - 1.85 MM (0.073") Shoulder Diameter A: 1.6 mm (0.063") Assembly Tool: AT 1/09 PLOX Printed it Test Point Number: LS/B2/156 Part Number: 030/SO/BCS/- Mounting mbly Tool:Hole Diameter: 0.81 mm (0.032") - 0.92 mm (0.036") 5& ATS 3/05 PCB Thickness: 1.65 MM (0.065") - 1.85 MM (0.073") Shoulder Diameter A: 1.6 mm (0.063") Assembly Tool: AT 1/09 or AT 1/KP2 Part Number: 050/B2/RS Mounting Hole Diameter: 1.25 mm (0.049") - 1.37 mm (0.054") PCB Thickness: N/A Shoulder Diameter A: 2.4 mm (0.094") mbly Tool:Tool: Assembly 9 AT 1/09 Number: LP/B2/156 Part Number: 156/LP/B2 Mounting Hole Diameter: 3.95 mm (0.155") - 4.05 mm (0.159") Chassis Thickness: 1.2mm (0.047") - 1.6 mm (0.063") Assembly Tool: AT 1/09 030/SO/BCS/F 030/SO/BCS/F 030/SO/BCS/P 030/SO/BCS/F 030/SO/BCS/P Assembly Tool: Continued Snale Snaplox AT 1/09 or AT 1/KP2 050/B2/RS Part Number: 050/B2/RS Mounting Hole Diameter: 050/B2/RS 030/SO/BF mm (0.049") - 1.37 mm (0.054") Part1.25 Number: 050/B2/RS PCB Thickness: Mounting Hole Diameter: 1.25 N/A mm (0.049") - 1.37 mm (0.054") Diameter A: PCBShoulder Thickness: N/A 2.4 mm (0.094") 030/SO/BF Assembly Tool:A: Shoulder Diameter (Connects with AT 1/09 2.4Socket mm (0.094") Assembly Tool: AT 1/09 030/SO/BCS/F Insulated Terminals Snaplox 050/B2/RS Insulated Terminals Snaplox all 2 mm Snaplox) 030/SO/BCS/P Part Number: 156/LP/B2 156/LP/B2 Mounting Hole Diameter: mm (0.155") - 4.05 mm (0.159") Part3.95 Number: 156/LP/B2 Chassis Thickness: Mounting Hole Diameter: 050/B2/RS (0.047") - 1.6mm mm (0.063") 3.95 1.2mm mm (0.155") - 4.05 (0.159") Assembly Tool: Chassis Thickness: AT(0.047") 1/09 1.2mm - 1.6 mmLS/B2/156 (0.063") LS/B2/156 Assemblywire Tool: shown for illustration purposes only AT 1/09 Terminals Snaplox Insulated 156/LP/B2 Line Plug (Connects with LS/B2/156) O 2 mm (0.079") 062/B1 Connecting Wire Maximum Diameters Insulation O 1.55mm (0.061")062/B1 Conductor O 1.4mm (0.055") 16 mm (0.630") 1 1 19 19 www.oxleygroup.com Oxley Inc.Inc. Oxley Developments Company LtdLtd www.oxleygroup.com/interconnect Oxley Developments Company Oxley 156/LP/B2 Oxley Group Australia Pty Ltd sales@oxleyinc.com sales@oxley.co.uk Email: sales@oxley.co.uk Email: sales@oxleygroup.com Email: Email: sales@oxleyinc.com Email: ODC:SM:40566/5/2009 Tel:Tel: +1 (203) 488488 1033 Tel:Tel: +44+44 (0)1229 483226 (0)1229 840519 Tel +61 (2) 9967 9193 +1 (203) 1033 ODCSM:40566/4/2007 www.oxleygroup.com Inc.Inc. Oxley Developments Company LtdLtd www.oxleygroup.com/interconnect Oxley Group Australia Pty LtdOxley Oxley Developments Company Oxley sales@oxleyinc.com sales@oxley.co.uk Email: sales@oxley.co.uk Email: sales@oxleygroup.com Email: Email: sales@oxleyinc.com Email: ODC:SM:40566/5/2009 Tel:Tel: +1 (203) 488488 1033 Tel:Tel: +44+44 (0)1229 483226 (0)1229 840519 +1 (203) 1033 ODCSM:40566/4/2007 O 5 mmTel +61 (2) 9967 9193 O 2 mm (0.079") 88 Oxley Developments Company Oxley Oxley Developments Company Ltd LtdOxley Inc. Inc. Email: sales@oxley.co.uk Email: sales@oxleyinc.com Email:sales@oxley.co.uk Email: sales@oxleyinc.com Tel: +44 (0)1229 483226 +1 (203) Tel: +44 (0)1229 840607 Tel: Tel: +1 (203) 488 488 10331033 Mounting Hole Diameter: mm (0.032") - 0.92 mm (0.036") Part0.81 Number: 030/SO/BCS/PCB Thickness: Mounting Hole Diameter: MM (0.065") MM (0.073") 0.81 1.65 mm (0.032") - 0.92- 1.85 mm (0.036") ® Diameter A: PCBShoulder Thickness: SNAPLOX Printed 030/SO/B2 (0.063") Test Point 1.65 1.6 MMmm (0.065") - 1.85 Circuit MM (0.073") www.oxleygroup.com Oxley Group Australia Pty Ltd www.oxleygroup.com/interconnect Assembly Tool:A: Email: Shoulder sales@oxleygroup.com Diameter ODC:SM:40566/5/2009 Tel +61 (2) 9967 9193 ODCSM:40566/4/2006 AT 1/09 or AT 1/KP2 1.6 mm (0.063") (0.197") max LP/B2/156 062/B1wire shown for illustration purposes only www.oxleygroup.com www.oxleygroup.com/interconnect ODC:SM:40566/5/2009 ODCSM:40566/4/2007 Inc.Inc. Oxley Group Australia Pty LtdOxley Oxley sales@oxleyinc.com Email: sales@oxleygroup.com Email: Email: sales@oxleyinc.com Tel:Tel: +1 (203) 488488 1033 Tel +61 (2) 9967 9193 +1 (203) 1033 LP/B2/156 (To suit LS/B2/156)) Oxley Developments Company LtdLtd Oxley Developments Company Email: sales@oxley.co.uk Email: sales@oxley.co.uk Tel:Tel: +44+44 (0)1229 483226 (0)1229 840519 19 19 Wires shown for illustration purposes only. Distributed by Telephone: +44 (0)1229 483226 • sales@oxleygroup.com • www.oxleygroup.com INTERCONNECT ODC:SM:40809/2
050/LT/B2 价格&库存
很抱歉,暂时无法提供与“050/LT/B2”相匹配的价格&库存,您可以联系我们找货
