24DP.1-60C
24DP.1-60C
    AMPERITE
24DP.1-60C 数据手册
Solving your relay requirements since 1922 C10 Series TDR Amperite Co. 567 52nd Street P.O. Box 329 West New York, NJ 07093 (800) 752-2329 www.Amperite.com … Solid state analog circuitry … Delay on operate timing mode … DPDT (2 form C) isolated 10 ampere relay contacts … Timing selection: Knob adjustable or Fixed … Numerous models timing from 0.1 secs. to 480 secs. … UL File #E96739 (M) … CSA File # LR62586-3 Specifications Timing Mode: Delay on operate timing cycle begins upon application of input power. The relay contacts transfer at the end of the delay period and will remain transferred until input voltage is removed. Reset occurs when input voltage is removed. Timing Diagram: Contact Information: Arrangement: 2 form C (DPDT) - Diagram C Contact Material: Silver - Cadmium Oxide Rating (Resistive): 10A @ 240V AC Resistive 15A @ 30V DC Resistive 15A @ 120V AC Resistive 1/3 HP @ 120V AC 1/2 HP @ 250V AC Expected Life @ 25°C: 10 Million operations, Mechanical 100,000 operations minimum at rated loads Solving your relay requirements since 1922 Amperite Co. 567 52nd Street P.O. Box 329 West New York, NJ 07093 (800) 752-2329 www.Amperite.com Environmental Information: Temperature Range: Storage: -60°C to +105°C (-76°F to +221°F) Operating: -45°C to +70°C (-49°F to +158°F) Mechanical Information: Termination: 8 Pin Octal Style Plug or 11-Pin Spade Terminals (Dia. C&D) Enclosure: White plastic case. Knob adjustable models have a dial scale for reference only. "LC" version has a black case. Weight: 4 on (114g) approx. Outline Dimension: Timing Specifications: Timing - Fixed: 0.1 through 480 sees. Timing Ranges: 0.1 - 60, 60 - 120, 120 - 180, 180 - 240, 240 - 300, 300 - 480 secs. Custom timing is available. Timing Adjustment: Knob adjustable potentiometer. Timing Tolerance: Fixed Units: ±5%. Adjustable Units: -0 to +25% of maximum specified delay time. Minimum specified value or less at low end. Repeatability: +/-5% Release Time: 60 ms typical, 100 ms maximum Timing Cycle Interrupt Transfer: None Initial Dielectric Strength: Between open contacts: 1000V RMS, Between adjacent contact: 1500V RMS Between contacts & coil: 1500V RMS Input Information: Voltage: AC units- 12V, 24V, and 120V. Other voltages are available. DC units- 12V, 24V, 48V and 110V. Other voltages are available. Solving your relay requirements since 1922 Amperite Co. 567 52nd Street P.O. Box 329 West New York, NJ 07093 (800) 752-2329 www.Amperite.com Power Requirement: AC units: 3 VA or less, DC units 3 Watts or less Transient Protection: 1 JOULE MOV Polarity Protection: On DC units - Yes Input Voltages & Limits: Nominal Minimum Maximum 12V AC 10V 14V 24V AC 20V 28V 120V AC 105V 130V 12V DC 11V 14V 24V DC 20V 32V 48V DC 41V 55V 110V DC 95V 125V Wiring Diagrams: Ordering Information: Definition of a part number for the Amperite C10 Series Time Delay Relay. Example: Solving your relay requirements since 1922 Amperite Co. 567 52nd Street P.O. Box 329 West New York, NJ 07093 (800) 752-2329 www.Amperite.com A: Denotes nominal input voltage. Voltages Available: 12, 24 & 120V AC; 12, 24, 48 & 110V DC. Custom Voltages are available. B: Denotes type of input current required for operation: A = AC - Alternating Current D = DC - Direct Current C: Denotes contact form: P= DPDT - 2 form C. D & E: Denotes range of knob adjustability for timing (in seconds) where: D= Minimum time delay. E= Maximum time delay for adjustable TDR's. Note: 1.) Ranges Available: 0.1 - 60, 60 - 120, 120 - 180, 180 - 240, 240 - 300 & 300 - 480 secs. Custom timing is available. 2.) Both values (D & E) can be replaced by a single value for a factory preset time delay in seconds from 0.1 through 480 secs. F: Enter "L" if optional 11-pin spade terminals are required (Dia. B & D). G: Denotes use of solid-state analog circuitry of C10 series. Solving Your Relay Requirements Since 1922
24DP.1-60C 价格&库存
很抱歉,暂时无法提供与“24DP.1-60C”相匹配的价格&库存,您可以联系我们找货
