E1YU400V01
E1YU400V01
    TELE
E1YU400V01 数据手册
Voltage monitoring in 3-phase mains E1YF, E1YU Monitoring relays - ENYA series Undervoltage monitoring Supply voltage = measured voltage 1 change over contact Width 17.5 mm Installation design Technical data 1. Functions Undervoltage monitoring in 3-phase mains (each phase against the neutral wire) with fixed or variable threshold voltage US and fixed hysteresis. 2. Time range Adjustment range Tripping delay: fixed, approx. 200ms 3. Indicators Type E1YF400V01 0.70 / 0.85: Yellow LED ON/OFF: indication of relay output Type E1YU400V01, E1YF400VT01 0.85: Green LED L1 ON/OFF: indication of supply voltage L1-N Green LED L2 ON/OFF: indication of supply voltage L2-N Green LED L3 ON/OFF: indication of supply voltage L3-N Yellow LED ON/OFF: indication of relay output 4. Mechanical design Self-extinguishing plastic housing, IP rating IP40 Mounted on DIN-rail TS 35 according to EN 60715 Mounting position: any Shockproof terminal connection according to VBG 4 (PZ1 required), IP rating IP20 Tightening torque: max. 1Nm Terminal capacity: 1 x 0.5 to 2.5mm² with/without multicore cable end 1 x 4mm² without multicore cable end 2 x 0.5 to 1.5mm² with/without multicore cable end 2 x 2.5mm² flexible without multicore cable end 5. Input circuit Supply voltage: Terminals: Rated voltage UN: Tolerance: Rated consumption: E1YF: E1YU: Rated frequency: Duty cycle: Reset time: Hold-up time: Drop out voltage: Overvoltage category: Rated surge voltage: (= measured voltage) N-L1-L2-L3 see table ordering information or printing on the unit -30% to +10% of UN 5VA (0,6W) 8VA (0,8W) AC 48 to 63Hz 100% 500ms determined by undervoltage detection (see measured circuit) III (in accordance with IEC 60664-1) 4kV Electrical life: Switching frequency: Overvoltage category: Rated surge voltage: 2 x 105 operations at 1000VA resistive load max. 6/min at 1000VA resistive load (in accordance with IEC 60947-5-1) III (in accordance with IEC 60664-1) 4kV 7. Measuring circuit Measuring variable: Measuring input: Terminals: Overload capacity: Input resistance: Switching threshold US: Hysteresis H: Overvoltage category: Rated surge voltage: AC sinus, 48 to 63Hz (= supply voltage) N-L1-L2-L3 determined by tolerance specified for supply voltage see table ordering information or printing on the unit approx. 5% III (in accordance with IEC 60664-1) 4kV 8. Accuracy Base accuracy: Adjustment accuracy: Repetition accuracy: Voltage influence: Temperature influence: ≤5% (E1YU) of nominal value ≤2% ≤0,05% /°C 9. Ambient conditions Ambient conditions: Storage temperatur: Transport temperature: Relative humidity: Pollution degree: -25 to +55°C -25 to +70°C -25 to +70°C 15% to 85% (in accordance with IEC 60721-3-3 class 3K3) 2, if built-in 3 (in accordance with IEC 60664-1) 10. Weight Single packing: Packing of 10pcs: 72g 670g per Package 6. Output circuit 1 potential free change over contact Rated voltage: 250V AC Switching capacity: 1250VA (5A / 250V) Fusing: 5A fast acting Mechanical life: 20 x 106 operations www.tele-online.com E1YF, E1YU Functions Connections Undervoltage monitoring for 3-phase AC mains with fixed (E1YF) or variable (E1YU) threshold voltage US and fixed hysteresis. All measuring inputs (L1, L2 and L3) must be connected to phase voltage. If single or 2-phase monitoring is required, unused input terminals (L) must be connected to mains voltage to have proper L-N voltage on the terminals L1, L2 and L3. A phase failure can not be detected, if the reverse voltage coming from the load exceeds the threshold US. L1 L2 3N~ L3 L N N Test function (optional) The test function enables a manually disconnection of the output relay. Undervoltage monitoring The output relay R switches into on-position (yellow LED illuminated), when the measuring voltage of all connected phases exeeds the fixed threshold US by more than the fixed hysteresis H. When the voltage of one of the connected phases (L1, L2 or L3) falls below the fixed threshold, the output relay R switches into off-position again (yellow LED not illuminated). 1~ N L3 L1 L2 N L3 L1 L2 11 R 11 R 12 14 12 14 11 12 14 11 12 14 Dimensions Us R 5mm 44mm 60mm 87mm 45mm H 17,5mm Ordering information Types Rated voltage UN Switching threshold Us Options LEDs Part. No. (PQ 1) Part. No. (PQ 10) E1YF400V01 0.85 3N-400/230V in accord. with VDE 0108 fixed 195,5V (L-N) - Rel. 1340402 1340402A E1YF400V01 0.70 3(N)-400/230V fixed 161V (L-N) - Rel. 1340403 E1YU400V01 0.85 3(N)-400/230V 160V-240V (L-N) - L1, L2, L3, Rel. 1340403 E1YF400VT01 0.85 3N-400/230V in accord. with VDE 0108 fixed 195,5V (L-N) Test function L1, L2, L3, Rel. 1340406 RELEASE 2009/07 Subject to alterations and errors www.tele-online.com
E1YU400V01 价格&库存
很抱歉,暂时无法提供与“E1YU400V01”相匹配的价格&库存,您可以联系我们找货
