C12A21X24D
C12A21X24D
    RELECO
C12A21X24D 数据手册
IRC series C12-A2x 8-pin, Interface relays, 2-pole, plug-in faston Type C12-A2x/ ... V Standard relay 2 change-over contact Maximum contact load 5 A/250 V 5 A/30 V 1 mA/10 V 10 mA/10 V Code 1 Code 2 Rated current Switch-on current max. (20 ms) Switching voltage max. AC load DC load Coil Coil resistance Pick-up voltage Release voltage Nominal power Coil table AgNi + 0,2 µ Au AgNi + 10 µ Au 5A 15 A 250 V 1,2 kVA see fig. 2 Connection diagram Gap: 0,5 mm see table; tolerance ± 10 % ≥ 0,8 x UN ≥ 0,1 x UN 1,1 VA (AC)/0,7 W (DC) VAC Ω mA 24 290 45 48 1200 23 115 7.300 9,5 230 28.800 4,7 Insulation Contact open Contact/contact Contact/coil Insulation resistance at 500 V Insulation, IEC 61810-5 VDC Fig. 1 3 1 9 7 4 12 14 22 24 A1 11 21 A2 2 8 5 AC voltage endurance 10 6 Ω 12 224 24 742 48 3.500 110 19.900 mA 53 32 13,7 5,5 AC1 AC1 switching cycles 1 Standard Optional 0,1 Contacts Material Volt rms, 1 min 1000 V 3000 V 5 kV ≥3 G Ω 4 kV/3 VA 400 800 1200 Fig. 2 DC load limit curve 10 Recommended minimum contact load AC1 0,5 A/110 V DC1 DC1 0,2 A/220 V DC1 (with 10 µ Au) (standard contact) 0,1 100 DC 12, 24, 48, 110 LED Polarity and free wheeling diode C12-A21/DC ... V C12-A21X/DC ... V C12-A21FX/DC ... V C12-A22/DC ... V C12-A22X/DC ... V C12-A22FX/DC ... V AC/DC bridge rectifier 24 V, 48 V, 60 V C12-A21BX/UC ... V C12-A22BX/UC ... V 220 Dimensions [mm] 7 1 8 2 9 3 4 5 12.5 2.5 FASTON .098 S12, S12-P IEC 61810; EN 60947 50/0407 200 Technical approvals, conformities "..." Enter the voltage for full type designation Accessories Socket: 150 28.8 C12-A22/AC ... V C12-A22X/AC ... V C12-A22R/AC ... V 50 20 C12-A21/AC ... V C12-A21X/AC ... V C12-A21R/AC ... V Volt 35.4 Standard types AC 50 Hz/60 Hz: 24, 48, 115, (120), 230, (240) LED RC suppresor -40 (no ice).…60 ºC /-40 ... 80 °C 10 ms/≤ 1 ms 5 ms/≤ 3 ms AC: 10 Mill./DC: 20 Mill. switching cycles ≥100000 switching cycles ≤ 1200/h IP40 21 g Amps. Amp 1 1 DC1 Specifications Ambient temperature operation/storage Pick-up time/bounce time Release time/bounce time Mechanical life Rated load Switching frequency at rated load Protection class Weight
C12A21X24D 价格&库存
很抱歉,暂时无法提供与“C12A21X24D”相匹配的价格&库存,您可以联系我们找货
C12A21X24D
    • 1+118.54071
    库存:474
