C10A10X24D
C10A10X24D
    RELECO
C10A10X24D 数据手册
Relays • Full Featured Industrial Plug-In Relays • Single Pole Interface to Four Pole Power Switching • Low Level Signal to High Power DC Switching • Latching & Low Consumption Coil Options • Plug In Timer Cube Options 38 CONTENTS Relays Selection Guide & Part No Key 40 General Information 41 General Information 42 General Information 43 MRC 8 Pin C2 Relays 44 MRC 11 Pin C3 Relays 45 MRC 11 Pin C3 Relays 46 MRC 11 Pin C3 Relays 47 MRC 14 Pin C4 Relays 48 MRC 11 Pin C5 Relays 49 MRC 11 Pin C5 Relays 50 QRC 8 Pin Miniature C7 Relays 51 QRC 8 Pin Miniature C7 Relays 52 QRC 14 Pin Miniature C9 Relays 53 IRC Single Pole Interface C10 Relays 54 Time Cubes 55 Sockets For C2 Relays 56 Sockets For C3 Relays 57 Module Sockets & Modules for C3 Relays 58 Sockets For C4 & C5 Relays 59 Sockets For C7 Relays 60 Sockets For C9 & C10 Relays 61 39 RELAYS MRC, QRC & IRC SERIES Application Types Poles General purpose C2-A20 C3-A30 C4-A40 C5-A20 C5-A30 C7-A10 C7-A20 C9-A41 C10-A10 8 pin 11 pin 14 pin flat blade 11 pin flat blade 11 pin flat blade 8 pin miniature flat blade 8 pin miniature flat blade 14 pin miniature flat blade 5 pin flat blade 2 3 4 2 3 1 2 4 1 C C C C C C C C C C2-T21 C3-T31 C7-T21 C10-T13 8 pin 11 pin 8 pin miniature flat blade 5 pin flat blade 2 3 2 1 C C C C C2-G20 C3-G30 C5-G30 C7-G20 8 pin 11 pin 11 pin flat blade 8 pin miniature flat blade 2 3 3 2 C3-X10 C4-X20 C5-X10 C7-X10 AC ratings 10A / 250V 10A / 250V 10A / 250V 16A / 500V 16A / 500V 16A / 250V 10A / 250V 3A / 250V 10A / 400V DC ratings 0,5A 0,5A 0,5A 0,5A 0,5A 0,5A 0,5A 0,5A 0,5A @ @ @ @ @ @ @ @ @ 110V 110V 110V 110V 110V 110V 110V 110V 110V Sockets Page 44 45 48 49 49 51 51 53 54 S2 S3 S4 S5 S5 S7 S7 S9 S10 56 57 59 59 59 60 60 61 61 44 45 51 54 S2 S3 S7 S10 56 57 60 61 6A 6A 6A 6A / / / / 250V 250V 250V 400V NO NO NO NO 10A 10A 16A 10A / / / / 250V 250V 500V 250V 1,2A 1,2A 1,2A 0,8A @ @ @ @ 110V 110V 110V 110V 44 45 49 52 S2 S3 S5 S7 56 57 59 60 11 pin 14 pin flat blade 11 pin flat blade 8 pin miniature flat blade 1 DM 2 DM 1 DM 1 DM 10A 10A 10A 10A / / / / 250V 250V 250V 250V 7A 7A 7A 6A @ @ @ @ 110V 110V 110V 110V 46 48 50 52 S3 S4 S5 S7 57 59 59 60 C3-M10 C5-M10 11 pin 11 pin flat blade 1 DM 1 DM 10A / 250V 16A / 500V 10A @ 220V 10A @ 220V 46 50 S3 S5 57 59 C3-R20 C4-R30 C5-R20 C9-R21 11 14 11 14 pin pin flat blade pin flat blade pin miniature flat blade 2 3 2 2 C C C C 10A / 250V 10A / 250V 10A / 250V 3A / 250V 0,5A 0,5A 0,5A 0,5A @ @ @ @ 110V 110V 110V 110V 46 48 50 53 S3 S4 S5 S9 57 59 59 61 250mW ... 800mW Flag not available LED not available C3-S14 C3-E24 C3-N34 C9-E21 11 11 11 14 pin pin pin pin miniature flat blade 1 2 3 2 C C C C 6A / 250V 6A / 250V 6A / 250V 3A / 250V 0,5A 0,5A 0,5A 0,5A @ @ @ @ 110V 110V 110V 110V 47 47 47 53 S3 S3 S3 S9 57 57 57 61 Lamp switching C7-W10 Miniature, faston 187 Time cube CT2 CT3 8 pin plug-in timer module 11 pin plug-in timer module Twin contacts Low level loads Open contacts DC load switching Flag not available Double make DC load switching Flag not available Magnet blow-out Flag not available Latching LED not available Sensitive Min. 5mA @ 5V Min. 5mA @ 5V Min. 5mA @ 5V Min. 1mA @ 5V Page 1 NO 10A / 250V 0,5A @ 110V 52 S7 60 2C 3C 10A / 250V 10A / 250V 0,5A @ 110V 0,5A @ 110V 55 55 S2 S3 56 57 PART NUMBER KEY C3 A 3 0 X 230A Coil voltage Model series C2 - MRC 8 pin C3 - MRC 11 pin C4 - MRC 14 pin flat blade C5 - MRC 11 pin flat blade C7 - QRC 8 pin miniature flat blade C9 - QRC 14 pin miniature flat blade C10 - IRC 5 pin flat blade Led indication Special executions H - Orange push only test button N - Black blanking plug i.e. no test button P - pins for printed circuit E - cover for flange panel mounting Contact Type A - standard, change-over contacts T - twin contacts (bifurcated) G - open contacts X - double make contacts M - double make, magnetic blow out R - remanence (latching) S - sensitive coil, 250 mW E - sensitive coil, 500 mW N - sensitive coil, 800 mW W - tungsten and silver contacts Additions to the coil D - free wheeling diode (DC only) F - polarity and free wheeling diodes (dc only) B - rectifying bridge for AC/DC relays R - RC suppressor (only MR-C types) Contact materials 0 - standard 9 - gold-flashed contact, 0,2µ Au 8 - gold-plated contact, 10µ Au 4 - sensitive MRC relays 2 - gold-plated 10µ Au (twin and C9 relays) 1 - flashed 0,2µ Au (twin and C9 relays) Number of contacts 40 RELAYS GENERAL INFORMATION Contact materials Silver-nickel (AgNi) and silver-tin oxide (AgSnO2) are used as standard contact materials for all models. Other contact materials are available on request. Maximum Intensity The “Max. switching current” indicated in every model, refers to the maximum stable current which should be possible in permanent conduction (ITH). Gold Flash For relays that are intended to be stored or remain unoperated for any length of time, a 0,2µ layer of gold protects the contacts from oxidisation. In the case of AC, the “Max. switchingcurrent” that the relay can support is the same for all the values of voltages ≤ of the “Max. switching voltage” specified in every model. The product of the intensity and the voltage applied should not be higher than the values specified as “Max. AC load”. Gold Plating A 10µ plate of gold increases the operational reliability. They should be used for switching low level currents. Contact Resistance Contact resistance is dependent on contact material, contact pressure and contact contamination. In the case of DC, the “Max. switching current” must be less than the current that causes the continuous arcing. The tables of “Max. DC current” show the possible values of intensity in relation to the applied voltage. High contact resistance raises the temperature of the contacts, therefore reducing their working life. Typical contact resistance of the MR-C and QR-C relays is 50 mΩ. Maximum Voltage The maximum voltage on the contacts depends on the insulation between each contact (pole to pole) and between all contacts and the coil. Contacts gap Contact gap and opening speed of the contacts have an influence on the length and the duration of the arc. The EN60947 and VDE 0110 standards set out the maximum voltage values, taking into consideration the quality of the insulation materials, pollution degree as well as the shape and dimensions of the contact barriers (creepage distance). In the case of AC, a gap of 0,5 mm is sufficient to quench the arc which occurs automatically at the “zero point” of the cycle. In the case of DC, the arc only quenches when the contact gap is sufficient for the voltage and current applied. Please see tables of “Max. DC current”. Coil Materials Coils bobbins are moulded in polybutylene with fibreglass (130° C). Enamelled wires of Class F specification are used (155° C). They are wound on automatic precision winding machines, with the number of turns and wire tension accurately regulated and monitored. Tolerances Coil resistance is measured at 20° C and is regulated within ± 10% of specified value. Standard Windings The coil voltages indicated in the catalogue refer to standard windings. Other coil voltages are available, including products for series connection and amperometric applications. Please consult your distributor for details. Contacts in series The connection of two or more contacts in series is equivalent to multiplying the contact gap by that amount. By using this method, a greater break capacity is achieved for DC switching. Minimum working voltage (pull in) This is the minimum voltage that must be supplied to the coil to ensure that the relay energises, the contacts change over and are positively held in place without any vibration. The values of voltage specified are those at or above which the relay must pull in. DC relays ≥ 80% Un AC relays ≥ 80% Un Maximum release voltage (drop out) This is the voltage at which the relay deenergises, the contacts change over and are positively held in place without any vibration. The values of voltage specified are those at or below which the relay must drop out. DC relays ≥ 10% Un AC relays ≤ 15% Un 41 Contacts in parallel The connection of two or more contacts in parallel does not mean that it is poss-ible to switch a greater load. However, the stable current and the operational reliability of the relay is increased. Double break contacts The double break contact arrangement is equivalent to two contacts connected in series. The maximum intensity supported corresponds to only one contact. This system allows for higher DC operating voltages. Bifurcated (twin) contacts The contact blade is divided into two parts, each with its own contact. Both contacts press down each on their own independent fixed contacts. This system is particularly good for reliably switching at very low levels. Contact protection The electrical life of contacts can be prolonged by components which eliminate or reduce the back EMF transients. These voltages are generated by the reactive component of the load on disconnection, which increases the duration and the temperature of the arc. For AC, RC suppressors or varistors can be connected in parallel with the load or the contacts. For DC with an inductive load, the best method is to connect a diode in parallel with the load. Ambient temperature The ambient temperature has an influence on the coil resistence and on its thermal dissipation capacity. Curve 1 represents the variations of the pull in voltage (% Un) in relation with the ambient temperature (T). Curve 2 indicates the maximum values of the voltage applied (Ub) to the coil in relation with the nominal voltage (Un) at the ambient temperature (T). Ub/Un 1,7 1,5 2 1,3 1,1 0,9 1 0,7 0,5 -20 -5 10 25 40 55 70 TºC RELAYS GENERAL INFORMATION General purpose relays They are used for most general applications, like as automation, pneumatic, heating appliances, signaling, as an input or output interface, etc. QR-C coils A Change-over contacts. Isolation between NO/NC: 1000 Vrms. Gap: 0,5 mm. Rating loads of up to 16A @ 230V AC1 16 A @ 30V DC1 0,5A @ 110V DC1 0,2A @ 220V DC1 MR-C coils Vac 24 48 115 230 400* Ω C2-A20 and C3-A30 mA 67 92 280 46 1K7 19 7K2 9,5 19K 5,5 Ω Vdc 12 110 24 443 48 1K8 110 9K 220 37K mA 110 54 27 12 6 * 400V coils only in pollution 2 MR-C coils Vac Ω mA Vdc 24 48 115 230 400* 65 280 1K6 6K8 18K 100 50 21 10 6 12 103 116 24 411 58 48 1K6 30 110 8K6 13 220 34K 6,5 Ω Ω 24 48 115 230 147 607 3K7 14K Ω 24 48 115 230 147 62 607 31 3K7 13 14K 6,5 mA Vdc Ω 12 24 48 110 140 555 2K3 9K8 mA 85 43 21 11 Relays with open contacts An open contact arrangement allows an increase in the contact gap, increasing the DC “break capacity” without altering the AC performance. G Gap: 1,5 mm (QR-C types); 1,7 mm (MR-C) Isolation of contacts NO: >2000 Vrms. Maximum load: 1,2A @ 110V DC1 16A @ 230V AC1 0,4A @ 220V DC1 Vdc Ω 62 31 13 6,5 12 24 48 110 140 555 2K3 9K8 Vac Ω mA Vdc Ω 24 48 115 230 400* 60 268 1K7 5K8 16K 100 50 21 10 6 12 24 48 110 220 90 133 360 66 1K4 34 7K5 15 30K 7,5 mA * C2-G20, C3-G30 400V only in pollution 2 C7-A20, C9-A41 mA MR-C coils C2-G20, C3-G30, C5-G30 mA * C4-A40 , 400V coils only in pollution 2 Vac Vac Relays with “mag. blow out” These versions are similar to X types, however they have the addition of a powerful magnet which “blows out” the arc generated when the contacts are opened, therefore quenching the arcing quickly and increasing the contact life. See Tables 6 and 7. On page 46 M They are able to switch DC loads of up to 10A @ 220V DC1 and 2A @ 220V DC13 MR-C coils Vac Ω 24 60 48 268 115 1K7 230 5K8 400* 16K C3-M10 and C5-M10 mA Vdc Ω mA 100 50 21 10 6 12 24 48 110 220 110 443 1K8 9K 37K 110 54 27 12 6 * C3-M10 , 400V coils only in pollution 2 C4-A40, C5-A20, C5-A30 QR-C coils C7-T21 QR-C coils mA 85 43 21 11 C7-A10, C7-G20, C7-X10 Vac Ω mA Vdc Ω mA 24 48 115 230 132 535 3K1 12K 83 42 17 8,7 12 24 48 110 96 384 1K5 8K 125 62 32 13 Remanence relays A high remanence magnetic circuit allows the relay to latch positively when the current applied flows through the coil in a direction and delatches if the current flows in the opposite direction. Electronic circuitry is added inside the relay to control this action and also protects against transient voltages. R There is one winding for AC coils and two windings for DC coils. All coils withstand permanent connection.The relay can be operated with pulses of 50 ms., minimum, at nominal voltage. A3 A1 + Relays with twin contacts These are used to switch low currents with high operational reliability. Double break relays These relays are designed to switch high DC loads at voltages of 110 and 220 Vdc. Change-over contacts. Isolation between contacts NO/NC: 1000 Vrms. Gap: 0,5 mm Gold-flashed contact 0,2µ or plated with 10µ Au (optional). They consist of one normally open contact with a gap >3 mm so that the arc length is divided by two. T Maximum load: Minimum load: MR-C coils Vac 24 48 115 230 400* 6A @ 230V AC1 5 mA @ 5V DC1 C2-T21 and C3-T31 Isolation between contacts: >2000 Vrms The max. DC load is shown in the tables. X versions are available in MR-C and QR-C type housing. MR-C coils C3-X10, C4-X20, C5-X10 Vdc Ω mA Vac Ω mA Vdc Ω mA 67 92 280 46 1K7 19 7K2 9,5 19K 5,5 12 24 48 110 220 110 443 1K8 9K3 37K 110 54 27 12 6 24 48 115 230 400* 60 268 1K7 5K8 16K 100 50 21 10 6 12 24 48 110 220 110 443 1K8 9K 37K 110 54 27 12 6 * 400V coils only in pollution 2 * C3-X10, C4-X20 400V only in pollution 2 42 A1 A3 X mA Ω + A2 – DC relays AC relays A2 MR-C coils C3-R20, C4-R30, C5-R20 Vac 24 48 115 230 ON OFF mA mA 75 38 16 8 12 6 2,5 1,3 ON Vdc 12 24 48 110 mA 24 62 32 13 30 21 10 6 QR-C coils Vac 24 48 115 230 C9-R21 ON OFF mA mA 50 25 10 5 OFF mA 8 4 2 1 ON OFF Vdc mA mA 12 24 48 60 100 50 25 20 25 12 6 5 RELAYS GENERAL INFORMATION S Sensitive relays, 250 mW One change-over contact E Sensitive relays, 500 mW Two change-over contacts N Sensitive relays, 800 mW Three change-over contacts DC relays adjusted to work at lower power, available in both MR-C and QR-C versions. Gold-flashed contacts 0,2µ or plated 10µ Au (optional). Operational voltage range: S relays: 0,8 ... 2,5 Un E relays: 0,8 ... 1,7 Un N relays: 0,8 ... 1,4 Un Coils High inrush current relay Two open contacts, one of silver nickel and one of tungsten work in parallel but are physically displaced so that the tungsten contact makes and breaks the load. The silver contact is used for carrying the stable current. W Only available in C7 type housing. Tables The tables of electrical life and the tables of maximum DC current show the typical result of exhaustive tests performed at an ambient temperature of 20° C, operating frequency of 1200 operations / hour, and under permanent connection. Maximum loads: 6A @ 230 AC5a/b (lamps) 10A @ 230V AC15; 1,5A @ 110V DC1 The switching current ratings specified in the catalogue refer to a minimum electrical life of 100.000 operations. See table of electrical life on page 52. Margin of over-voltage A maximum over-voltage of 110% Un is permissible at the coil, with rated current through the contacts at an ambient temperature of 60° C. This relay was designed to switch incandescent and fluorescent lamps, (with p.f corrected), and DC inductive loads. Relays C3-S, C3-E, C3-N, C9-E Relays S Vdc Ω 6 12 24 48 60 110 144 576 2K3 9K2 mA Relays E Ω 42 72 21 288 10 1K1 5 4K6 7K2 mA Relays N Ω 83 45 42 180 21 720 10 2K8 8,3 4K5 15K mA QR-C coils 133 66 33 17 13 7 Vac Ω mA Vdc Ω 24 48 115 230 132 535 3K1 12K 83 42 17 8,7 12 24 48 110 110 110 443 54 1K8 27 9K 12 Protection against transients When the coil is disconnected from an electromagnet, peaks of inverse voltage appear at the terminals which can reach very high values. These pulses can be transmitted down the line associated with the coil and could possibly affect other components. In the case of a relay being operated by such devices as transistors, triacs, etc; it may be necessary to protect against transients. Transients carried in the line High voltage pulses can be carried in the supply line to the relay coil. These may appear in the form of peaks or bursts and are generated by the connection and disconnection of electric motors, transformers, capacitors etc. Normally a relay is unaffected by these pulses, but if a diode is connected in association with the coil, it must be capable of withstanding an inverse voltage higher than those of the incoming peaks. Protection circuits A protection circuit must efficiently cope with pulses generated by the coil as well as incoming line pulses. EN61000 norms set levels of protection for each application. Releco relays are available with integrated protection circuits or with modules plugged into sockets S3-MP or S3-MS. Specifications The data referred to in the specifications for each model refers to typical values of “new” relays at 20° C. Relays C7-W mA Custom relays Relays with special specifications can be supplied after consultation with an official Releco distributor. X LED indication with rectifier. For DC and AC relays up to 250V Level II (1000V) up to 24V Level III (2000V) from 25 to 60V Level IV (4000V) from 61 to 250V Note: LED connected in series with the coil @ 220Vdc in QRC types. A1 X A2 D D Free wheeling diode. DX Free wheeling diode + LED Dampens transients caused by the relay coil on de-energisation. Levell III (2000V) up to 60 Vdc Level IV (4000V) from 61 to 250 Vdc (*) F Polarity and free wheeling diodes. FX Polarity + free wheeling diode + LED A diode in series with the coil protects the relay from reverse connection. Level II (1000V) up to 60 Vdc Level IV (4000V) from 61 to 250 Vdc (*) B Bridge rectifier incorporated. BX Bridge rectifier + LED indication Allows the relay to operate in both AC or DC without any polarity inconvenience. Available only in voltages up to 60V Protection level II (1000V) R Resistor and capacitor. RX Resistor and capacitor + LED Suppressor for AC coils. Level III (2000V) Available only in MRC types (*) Level III (2000V) in QRC types. 43 DX A1 A1 A2 A2 + + – – F FX A1 A1 A2 A2 + + – – BX B A1 A1 A2 A2 RX R A1 A2 A1 A2 RELAYS MRC 8 PIN STANDARD/LOW SIGNAL LEVEL/ OPEN CONTACTS • • • • • • Lockable test button Marking label on relay 2 window mechanical flag (not available on C2-G20) Colour coded test button Coil voltage marked on top of relay Label carries full technical information • CE marked C2-A20... General purpose Two change-over contacts, 10 A 10A / 250V AC1 6A / 250V AC15 10A @ 30V DC1 0,5A @ 110V DC1 C2-T21... Low level Two change-over, bifurcated contacts C2-G20... 6A / 250V AC1 6A @ 30V DC1 Min. 5mA @ DC 5V 10A / 250V AC1 1,2A @ 110V DC1 General purpose, DC Two open contacts 0,3A @ 110 V DC13 0,4A @ 220V DC1 Contacts Contacts Contacts Materials code 0 (standard); options: 8 - 9 Max. switching current 10 A Peak inrush current (20 ms) 30 A Max. switching voltage, (pollution 3) 250 V Max. switching voltage, (pollution 2) 400 V Max. AC load (Table 1) 2,5 KVA Max. DC load See Table 2 Materials code 1 (standard); option: 2 Switching current: min. 5 mA; max. 6 A Peak inrush current (5 ms) 15 A Max. switching voltage, (pollution 3) 250 V Max. switching voltage, (pollution 2) 400 V Max. AC load (Table 3, page 45) 1,2 KVA Max. DC load See Table 18, page 51 Materials code 0 (standard) Max. switching current 10 A Peak inrush current (20 ms) 30 A Max. switching voltage, (pollution 3) 250 V Max. switching voltage, (pollution 2) 400 V Max. AC load (Table 1) 2,5 KVA Max. DC load See Table 4, page 45 4 3 5 6 2 4 3 5 6 2 12 14 22 24 A1 (+) 12 14 22 24 A1(+) 11 21 A2 11 21 A2 1 8 7 1 8 7 3 6 2 A1(+) A2 gap 1,7 mm 1 8 7 Standard types (50/60 Hz and DC) AC 24, 48, 115 (110 ... 120), 230 X = LED (optional) C2-A20 X/ ... V RC suppressor C2-A20R X/ ... V Standard types (50/60 Hz and DC) Standard types (50/60 Hz and DC) AC 24, 48, 115 (110 ... 120), 230 X = LED (optional) C2-T21 X/ ... V RC suppressor C2-T21R X/ ... V AC 24, 48, 115 (110 ... 120), 230 X = LED (optional) C2-G20 X/ ... V RC suppressor C2-G20R X/ ... V DC 12, 24, 48, 110, 120/125, 220 X = LED (optional) C2-A20 Free wheeling diode C2-A20D Free wheeling and polarity C2-A20F AC/DC rectifier (60V max.) C2-A20B DC 12, 24, 48, 110, 120/125, 220 X = LED (optional) C2-T21 Free wheeling diode C2-T21D Free wheeling and polarity C2-T21F AC/DC rectifier (60V max.) C2-T21B DC 12, 24, 48, 110, 120/125, 220 X = LED (optional) C2-G20 X/ Free wheeling diode C2-G20D X/ Free wheeling and polarity C2-G20F X/ AC/DC rectifier (60V max.) C2-G20B X/ X/ X/ X/ X/ ... ... ... ... V V V V Specifications X/ X/ X/ X/ V V V V Specifications Nominal coil power: 2,2 VA (AC), 1,3 Operate time Release time Isolation: EN60947 pollution 3, Gr C Dielectric strength, contacts / coil Dielectric strength, pole / pole W (DC) 16 ms. 8 ms. 250V 2,5 KV 2,5 KV ... ... ... ... W (DC) 16 ms. 8 ms. 250V 2,5 KV 2,5 KV 10 Nominal coil power: 2,4 VA (AC), 1,6 Operate time Release time Isolation: EN60947 pollution 3, Gr C Dielectric strength, contacts / coil Dielectric strength, pole / pole W (DC) 20 ms. 10 ms. 250V 2,5 KV 2,5 KV Table 2 Max. DC load C2-A, C3-(A, R),C4-(A, R), C5-R, C7-A 10 1 8 A1 DC1 DC13 AC1 AC15 6 3 35 2 7 A2 5 4 1 Amps 1 ops 35 0,1 KVA 0,1 0,5 1 V V V V Specifications Nominal coil power: 2,2 VA (AC), 1,3 Operate time Release time Isolation: EN60947 pollution 3, Gr C Dielectric strength, contacts / coil Dielectric strength, pole / pole Table 1 Electrical life (ops x 106) C2-A, C2-G, C3-A, C3-G, C3-R, C5-R Dimensions (mm) 58.5 ... ... ... ... 1,5 44 2 2,5 Volts 25 75 125 175 225 RELAYS MRC 11 PIN STANDARD/LOW SIGNAL LEVEL/ OPEN CONTACTS • • • • • • Lockable test button Marking label on relay 2 window mechanical flag (not available on C3-G30) Colour coded test button Coil voltage marked on top of relay Label carries full technical information • CE marked C3-A30... General purpose Three change-over contacts, 10 A 10A / 250V AC1 6A / 250V AC15 10A @ 30V DC1 0,5A @ 110V DC1 C3-T31... C3-G30... General purpose, DC Low level 3 change-over, bifurcated contacts Three open contacts 6A / 250V AC1 6A @ 30V DC1 Min. 5mA @ DC 5V 10A / 250V AC1 1,2A @ 110V DC1 0,3A @ 110V DC13 0,4A @ 220V DC1 Contacts Contacts Contacts Materials code 0 (standard); options: 8 - 9 Max. switching current 10 A Peak inrush current (20 ms) 30 A Max. switching voltage, (pollution 3) 250 V Max. switching voltage, (pollution 2) 400 V Max. AC load (Table 1, page 44) 2,5 KVA Max. DC load See Table 2, page 44 Materials code 1 (standard); option: 2 Switching current: min. 5 mA, max. 6 A Peak inrush current (15 ms) 15 A Max. switching voltage, (pollution 3) 250 V Max. switching voltage, (pollution 2) 400 V Max. AC resistive load (Table 3) 1,2 KVA Max. DC load See Table 18, page 51 Materials code 0 (standard) Max. switching current 10 A Peak inrush current (20 ms) 30 A Max. switching voltage, (pollution 3) 250 V Max. switching voltage, (pollution 2) 400 V Max. AC load (Table 1, page. 44) 2,5 KVA Max. DC load See Table 4 4 3 5 7 8 9 2 4 3 5 7 8 9 2 12 14 22 24 32 34 A1(+) 12 14 22 24 32 34 A1(+) 11 21 31 A2 11 21 31 A2 1 6 11 10 1 6 11 10 Standard types (50/60 Hz and DC) 3 7 9 2 A1(+) A2 gap 1,7 mm 1 6 11 10 AC 24, 48, 115 (110 ... 120), 230 X = LED (optional) C3-A30 X/ ... V RC suppressor C3-A30R X/ ... V Standard types (50/60 Hz and DC) AC 24, 48, 115 (110 ... 120), 230 X = LED (optional) C3-T31 X/ ... V RC suppressor C3-T31R X/ ... V Standard types (50/60 Hz and DC) AC 24, 48, 115 (110 ... 120), 230 X = LED (optional) C3-G30 X/ ... V RC suppressor C3-G30R X/ ... V DC 12, 24, 48, 110, 120/125, 220 X = LED (optional) C3-A30 Free wheeling diode C3-A30D Free wheeling and polarity C3-A30F AC/DC rectifier (60V max.) C3-A30B DC 12, 24, 48, 110, 120/125, 220 X = LED (optional) C3-T31 Free wheeling diode C3-T31D Free wheeling and polarity C3-T31F AC/DC rectifier (60V max.) C3-T31B DC 12, 24, 48, 110, 120/125, 220 X = LED (optional) C3-G30 X/ Free wheeling diode C3-G30D X/ Free wheeling and polarity C3-G30F X/ AC/DC rectifier (60V max.) C3-G30B X/ X/ X/ X/ X/ ... ... ... ... V V V V Specifications ... ... ... ... V V V V Specifications Nominal coil power: 2,2 VA (AC), 1,3 Operate time Release time Isolation: EN60947 pollution 3, Gr C Dielectric strength, contacts / coil Dielectric strength, pole / pole Dimensions (mm) W (DC) 16 ms. 8 ms. 250V 2,5 KV 2,5 KV 10 1 11 W (DC) 16 ms. 8 ms. 250V 2,5 KV 2,5 KV Nominal coil power: 2,4 VA (AC), 1,6 Operate time Release time Isolation: EN60947 pollution 3, Gr C Dielectric strength, contacts / coil Dielectric strength, pole / pole 10 10 A1 9 3 DC1 DC13 8 4 AC1 7 6 5 1 1 ops Amps 35 0,1 VA 0 0,1 250 500 V V V V W (DC) 20 ms. 10 ms. 250V 2,5 KV 2,5 KV Table 4 Max. DC load Types C2-G20, C3-G30 2 35 ... ... ... ... Specifications Nominal coil power: 2,2 VA (AC), 1,3 Operate time Release time Isolation: EN60947 pollution 3, Gr C Dielectric strength, contacts / coil Dielectric strength, pole / pole Table 3 Electrical life (ops x 106) Types C2-T21, C3-T31, C7-T21 A2 58.5 X/ X/ X/ X/ 750 45 1000 1250 Volts 25 75 125 175 225 RELAYS MRC 11 PIN POWER/MAGNETIC BLOW-OUT/ LATCHING • • • • • • Lockable test button Marking label on relay 2 window mechanical flag (not available on C3X10 or C3-M10) Colour coded test button Coil voltage marked on top of relay Label carries full technical information • CE marked C3-X10... C3-M10... Power relay, DC Single pole, NO, double make 10A / 250V AC1 7A @ 110V DC1 Power relay, DC Single pole, magnetic blow out 10A / 250V AC1 3,6A @ 110V DC13 1,2A @ 220V DC1 0,3A @ 220V DC13 10A @ 220V DC1 2A @ 220V DC13 C3-R20... Latching Two change-over contacts, 10 A 10A / 250V AC1 6A / 250V AC15 10A @ 30V DC1 0,5A @ 110VDC1 Contacts Contacts Contacts Materials code 0 (standard) Max. switching current 10 A Peak inrush current (20 ms) 30 A Max. switching voltage, (pollution 3) 250 V Max. switching voltage, (pollution 2) 400 V Max. AC load (Table 5) 2,5 KVA Max. DC load See Table 10, page 48 Materials code 0 (standard) Max. switching current. 10 A Peak inrush current (20 ms) 30 A Max. switching voltage, (pollution 3) 250 V Max. switching voltage, (pollution 2) 400 V Max. AC load (Table 5) 2,5 KVA Electrical life, DC See Tables 6 and 7 Materials code 0 (standard); options: 8 - 9 Max. switching current 10 A Peak inrush current (20 ms) 30 A Max. switching voltage, (pollution 3) 250 V Max. switching voltage, (pollution 2) 400 V Max. AC load (Table 1, page 44) 2,5 KVA Max. DC load See Table 2, page 44 3 9 3 2 A1(+) Magnet (+) 9 A2 gap > 3 mm (1,7+1,7) gap > 3 mm (1,7+1,7) 10 Standard types (50/60 Hz and DC) 2 4 3 8 9 2 6 A1 (+) 12 14 22 24 A1 A3 ON (+) OFF (+) A2 11 21 A2 (-) 10 1 11 10 AC 24, 48, 115 (110 ... 120), 230 X = LED (optional) C3-X10 X/ ... V RC suppressor C3-X10R X/ ... V Standard types (50/60 Hz and DC) AC 24, 48, 115 (110 ... 120), 230 X = LED (optional) C3-M10 X/ ... V RC suppressor C3-M10R X/ ... V Standard types (50/60 Hz and DC) AC 24, 48, 115 (110 ... 120), 230 C3-R20 / ... V DC 12, 24, 48, 110, 120/125, 220 X = LED (optional) C3-X10 Free wheeling diode C3-X10D Free wheeling and polarity C3-X10F AC/DC rectifier (60V max.) C3-X10B DC 12, 24, 48, 110, 120/125, 220 X = LED (optional) C3-M10 X/ Free wheeling diode C3-M10D X/ Free wheeling and polarity C3-M10F X/ AC/DC rectifier (60V max.) C3-M10B X/ DC 12, 24, 48, 110, 125 (two windings) X/ X/ X/ X/ ... ... ... ... V V V V Specifications Nominal coil power: 2,4 VA (AC), 1,3 W (DC) Operate time 20 ms. Release time 10 ms. Isolation: EN60947 pollution 3, Gr C 250V Dielectric strength, contacts / coil 2,5 KV Note: All AC and DC coils withstand permanent connection. W (DC) 20 ms. 10 ms. 250V 2,5 KV ON pulse power 1,5 VA/ W OFF pulse power 0,5 VA/ W Min. pulse length for ON/OFF control 50 ms. Isolation: EN60947 pollution 3, Gr C 250V Dielectric strength, contacts / coil 2,5 KV Dielectric strength, pole / pole 2,5 KV Table 6 Electrical life (ops x 106) Types C3-M10 and C5-M10 10 Table 7 Electrical life (ops x 106) Types C3-M10 and C5-M10 10 DC13 110V DC13 220V DC1 110V DC1 220V 1 1 0,5 1 1,5 2 2,5 0,1 Amp 0 ops ops ops 1 C3-R20 / ... V Specifications Nominal coil power: 2,4 VA (AC), 1,3 Operate time Release time Isolation: EN60947 pollution 3, Gr C Dielectric strength, contacts / coil AC1 AC15 0,1 KVA V V V V Specifications Table 5 Electrical life (ops x106) Types C3-X10 and C3-M10 10 ... ... ... ... 2 4 6 46 8 10 0,1 Amp 0,3 0,7 1,3 2 2,6 3,3 3,6 RELAYS MRC 11 PIN SENSITIVE COIL (WIDE VOLTAGE TOLERANCE) • • • • • • Lockable test button Marking label on relay Colour coded test button Coil voltage marked on top of relay Label carries full technical information CE marked C3-S14... C3-E24... C3-N34... Operating range: 0,8 ... 2,5 x Un 6A / 250V AC1 6A @ 30V DC1 Operating range: 0,8 ... 1,7 x Un 6A / 250V AC1 6A @ 30V DC1 Operating range: 0,8 ... 1,4 x Un 6A / 250V AC1 6A @ 30V DC1 Sensitive, 250 mW One change-over contact, 6 A Sensitive, 800 mW Three change-over contacts, 6 A Sensitive, 500 mW Two change-over contacts, 6 A Contacts Contacts Contacts Materials code 4 (standard) Max. switching current 6A Peak inrush current (10 ms) 15 A Max. switching voltage, (pollution 3) 250 V Max. switching voltage, (pollution 2) 400 V Max. AC resistive load (Table 8) 1,2 KVA Max. DC load See Table 9 Materials code 4 (standard) Max. switching current 6A Peak inrush current (10 ms) 15 A Max. switching voltage, (pollution 3) 250 V Max. switching voltage, (pollution 2) 400 V Max. AC resistive load (Table 8) 1,2 KVA Max. DC load See Table 9 Materials code 4 (standard) Max. switching current 6A Peak inrush current (10 ms) 15 A Max. switching voltage, (pollution 3) 250 V Max. switching voltage, (pollution 2) 400 V Max. AC resistive load (Table 8) 1,2 KVA Max. DC load See Table 9 5 7 2 4 3 8 9 2 4 3 5 7 8 9 2 12 14 A1(+) 12 14 22 24 A1(+) 12 14 22 24 32 34 A1(+) 11 A2 11 21 A2 11 21 31 A2 6 10 1 11 10 1 6 11 10 Standard types, DC Standard types, DC DC 6, 12, 24, 48 DC 6, 12, 24, 48, 60 C3-S14 / ... V Standard types, DC DC 6, 12, 24, 48, 60, 110 C3-E24 C3-N34 / ... V / ... V Free wheeling diode C3-S14D / ... V Free wheeling and polarity C3-S14F / ... V Free wheeling diode C3-E24D / ... V Free wheeling and polarity C3-E24F / ... V Free wheeling diode C3-N34D / ... V Free wheeling and polarity C3-N34F / ... V Note: The connection of diodes to the coil will increase the initial drop-out time. LED not available Note: The connection of diodes to the coil will increase the initial drop-out time. LED not available Note: The connection of diodes to the coil will increase the initial drop-out time. LED not available Specifications Specifications Specifications Nominal coil power 250 mW Operate time 18 ms. Release time 10 ms. Isolation: EN60947 pollution 3, Gr C 250V Dielectric strength, contacts / coil 2,5 KV Dielectric strength, pole / pole 2,5 KV Nominal coil power 500 mW Operate time 18 ms. Release time 10 ms. Isolation: EN60947 pollution 3, Gr C 250V Dielectric strength, contacts / coil 2,5 KV Dielectric strength, pole / pole 2,5 KV Nominal coil power 800 mW Operate time 18 ms. Release time 10 ms. Isolation: EN60947 pollution 3, Gr C 250V Dielectric strength, contacts / coil 2,5 KV Dielectric strength, pole / pole 2,5 KV Dimensions (mm) Table 9 Max. DC load Types C3-S14, C3-E24, C3-N34 Table 8 Electrical life (ops x 106) Types C3-S14, C3-E24, C3-N34 10 1 11 9 3 AC1 4 7 6 5 1 1 Amps 35 ops 35 DC1 2 8 58.5 10 A1 10 A2 0,1 KVA 0 0,5 1 47 1,5 0,1 Volts 25 50 100 150 200 RELAYS MRC 14 PIN (FLAT BLADE) STANDARD/ POWER/LATCHING • • • • • • Lockable test button Marking label on relay 2 window mechanical flag (not available on C4-X20) Colour coded test button Coil voltage marked on top of relay Label carries full technical information • CE marked C4-A40... C4-X20... General purpose Four change-over contacts, 10 A 10A / 250V AC1 6A / 250V AC15 C4-R30... Power relay, DC Double pole, NO, double make 10 A @ 30V DC1 0,5A @ 110V DC1 10A / 250V AC1 7A @ 110V DC1 Latching relay Three change-over contacts, 10 A 10A / 250V AC1 6A / 250V AC15 1,2A @ 220V DC1 0,3A @ 220V DC13 10 A @ 30V DC1 0,5A @ 110V DC1 Contacts Contacts Contacts Materials code 0 (standard); options: 8 - 9 Max. switching current 10 A Peak inrush current (20 ms) 30 A Max. switching voltage, (pollution 3) 250 V Max. switching voltage, (pollution 2) 400 V Max. AC load (Table 11) 2 KVA Max. DC load See Table 2, page 44 Materials code 0 (standard) Max. switching current 10 A Peak inrush current (20 ms) 30 A Max. switching voltage, (pollution 3) 250 V Max. switching voltage, (pollution 2) 400 V Max. AC load (Table 11) 2 KVA Max. DC load See Table 10 Materials code 0 (standard); options: 8 - 9 Max. switching current 10 A Peak inrush current (20 ms) 30 A Max. switching voltage, (pollution 3) 250 V Max. switching voltage, (pollution 2) 400 V Max. AC load (Table 11) 2 KVA Max. DC load See Table 2, page 44 1 2 4 5 13 7 8 10 11 12 14 22 24 32 34 42 44 2 5 8 11 A1(+) 11 21 31 41 A2 3 6 9 12 14 gap > 3 mm (1,7+1,7) Standard types (50/60 Hz and DC) 4 5 7 8 13 1 2 A1 (+) 12 14 22 24 32 34 13 12 A1 A3 ON (+) OFF (+) A2 11 21 31 A2 (-) 14 3 6 9 14 Standard types (50/60 Hz and DC) AC 24, 48, 115 (110 ... 120), 230 X = LED (optional) C4-X20 X/ ... V RC suppressor C4-X20R X/ ... V Standard types (50/60 Hz and DC) AC 24, 48, 115 (110 ... 120), 230 X = LED (optional) C4-A40 X/ ... V RC suppressor C4-A40R X/ ... V DC 12, 24, 48, 110, 120/125, 220 X = LED (optional) C4-A40 Free wheeling diode C4-A40D Free wheeling and polarity C4-A40F AC/DC rectifier (60V max.) C4-A40B DC 12, 24, 48, 110, 120/125, 220 X = LED (optional) C4-X20 Free wheeling diode C4-X20D Free wheeling and polarity C4-X20F AC/DC rectifier (60V max.) C4-X20B DC 12, 24, 48, 110, 125 Two coils X/ X/ X/ X/ ... ... ... ... V V V V Specifications W (DC) 20 ms. 8 ms. 250V 2,5 KV 2,5 KV 4 W (DC) 20 ms. 8 ms. 250V 2,5 KV 2,5 KV ON pulse power 1,5 VA/ W OFF pulse power 0,5 VA/ W Min. pulse length for ON/OFF control: 50 ms. Isolation: EN60947 pollution 3, Gr C 250V Dielectric strength, contacts / coil 2,5 KV Dielectric strength, pole / pole 2,5 KV 7 5 10 10 11 8 6 9 3 12 13 14 8 7.0 6.75 6.75 4.15 1 1 8 Amps 3.85 6.5 10 DC1 DC13 AC1 AC15 35 8 Table 11 Electrical life (ops x 106) Types C4-A40, C4-X20, C4-R30 ops 52.5 35 2 C4-R30 / ... V Note: All AC and DC coils withstand permanent connection. Table 10 Máx. DC load Type C3-X10, C4-X20 1 C.I. V V V V / ... V Specifications Nominal coil power: 2,4 VA (AC), 1,3 Operate time Release time Isolation: EN60947 pollution 3, Gr C Dielectric strength, contacts / coil Dielectric strength, pole / pole Dimensions (mm) 1.2 ... ... ... ... Specifications Nominal coil power: 2,4 VA (AC), 1,4 Operate time Release time Isolation: EN60947 pollution 3, Gr C Dielectric strength, contacts / coil Dielectric strength, pole / pole 3 FASTON .110 X/ X/ X/ X/ AC 24, 48, 115 (110 ... 120), 230 C4-R30 ø1.5 0,1 Volts 25 0,1 75 125 48 175 225 KVA 0,25 0,5 1 1,5 2 2,5 RELAYS MRC 11 PIN (FLAT BLADE) STANDARD/ OPEN CONTACTS • • • • • • Lockable test button Marking label on relay and socket 2 window mechanical flag (not available on C5-G30) Colour coded test button Coil voltage marked on top of relay Label carries full technical information • CE marked C5-A20... C5-A30... General purpose Two change-over contacts, 16 A 16A / 500V AC1 8A / 500V AC15 General purpose Three change-over contacts, 16 A 16A / 500V AC1 8A / 500V AC15 16A @ 30V DC1 0,5 A @ 110V DC1 16A @ 30V DC1 0,5A @ 110V DC1 C5-G30... General purpose, DC Three open contacts 16A / 500V AC1 1,2A @ 110V DC1 0,3A @ 110V DC13 0,4A @ 220V DC1 Contacts Contacts Contacts Materials code 0 (standard); options: 8 - 9 Max. switching current 16 A Peak inrush current (20 ms) 40 A Max. switching voltage, (pollution 3) 500 Max. AC load (Table 12) 4 KVA Max. DC load See Table 13 Materials code 0 (standard); options: 8 - 9 Max. switching current 16 A Peak inrush current (20 ms) 40 A Max. switching voltage, (pollution 3) 500 Max. AC load (Table 12) 4 KVA Max. DC load See Table 13 Materials code 0 (standard) Max. switching current 16 A Peak inrush current (20 ms) 40 A Max. switching voltage, (pollution 3) 500 V Max. AC load (Table 12) 4 KVA Max. DC load See Table 14, page 50 1 4 3 6 A 1 4 2 5 3 6 A 12 14 22 24 A1(+) 12 14 22 24 32 34 A1(+) 11 21 A2 11 21 31 A2 7 9 B 7 8 9 B Standard types (50/60 Hz and DC) 5 4 6 A A1(+) A2 gap 1,7 mm 8 7 9 B AC 24, 48, 115 (110 ... 120), 230, 400 X = LED (optional) C5-A20 X/ ... V RC suppressor C5-A20R X/ ... V Standard types (50/60 Hz and DC) AC 24, 48, 115 (110 ... 120), 230, 400 X = LED (optional) C5-A30 X/ ... V RC suppressor C5-A30R X/ ... V AC 24, 48, 115 (110 ... 120), 230, 400 X = LED (optional) C5-G30 X/ ... V RC suppressor C5-G30R X/ ... V DC 12, 24, 48, 110, 120/125, 220 X = LED (optional) C5-A20 Free wheeling diode C5-A20D Free wheeling and polarity C5-A20F AC/DC rectifier (60V max.) C5-A20B DC 12, 24, 48, 110, 120/125, 220 X = LED (optional) C5-A30 Free wheeling diode C5-A30D Free wheeling and polarity C5-A30F AC/DC rectifier (60V max.) C5-A30B DC 12, 24, 48, 110, 120/125, 220 X = LED (optional) C5-G30 X/ Free wheeling diode C5-G30D X/ Free wheeling and polarity C5-G30F X/ AC/DC rectifier (60V max.) C5-G30B X/ X/ X/ X/ X/ ... ... ... ... V V V V X/ X/ X/ X/ ... ... ... ... V V V V Standard types (50/60 Hz and DC) ... ... ... ... V V V V Specifications Specifications Specifications Nominal coil power: 2,4 VA (AC), 1,4 W (DC) Operate time 20 ms. Release time 10 ms. Isolation: EN60947 pollution 3, Gr C 500 V Dielectric strength, contacts / coil 4 KV Dielectric strength, pole / pole 4 KV Nominal coil power: 2,4 VA (AC), 1,4 W (DC) Operate time 20 ms. Release time 10 ms. Isolation: EN60947 pollution 3, Gr C 500 V Dielectric strength, contacts / coil 4 KV Dielectric strength, pole / pole 4 KV Nominal coil power: 2,4 VA (AC), 1,6 W (DC) Operate time 20 ms. Release time 10 ms. Isolation: EN60947 pollution 3, Gr C 500 V Dielectric strength, contacts / coil 4 KV Dielectric strength, pole / pole 4 KV Dimensions (mm) 56 35 Table 12 Electrical life (ops x 106) Types C5- (A, G, X, M), C7-A10 1 2 3 4 7 5 8 6 9 A 10 Table 13 Max. DC load Types C5-A20, C5-A30 16 10 AC1 AC15 B 35 DC1 DC13 1 1 8.3 7.7 1.3 C.I. ops 4.75 FASTON .187 4.6 5.5 Amps 11.05 11.05 8.9 0,1 ø1.5 0,1 KVA 0 0,66 1,33 2 49 2,6 3,3 4 Volts 25 75 125 175 225 RELAYS MRC 11 PIN (FLAT BLADE) POWER/ MAGNETIC BLOW-OUT/LATCHING • • • • • • Lockable test button Marking label on relay 2 window mechanical flag (not available on C5-X10 or C5-M10) Colour coded test button Coil voltage marked on top of relay Label carries full technical information • CE marked C5-X10... Power relay, DC Single pole, NO, double make 16A / 500V AC1 7A @ 110V DC1 C5-M10... Power relay, DC SP double make. Magnetic blow out 16A / 500V AC1 3,6A @ 110V DC13 1,2A @ 220V DC1 0,3A @ 220V DC13 10A @ 220V DC1 2A @ 220V DC13 C5-R20... Latching relay Two change-over contacts, 10 A 10A / 500V AC1 6A / 500V AC15 10A @ 30V DC1 0,5A @ 110V DC1 Contacts Contacts Contacts Materials code 0 (standard) Max. switching current 16 A Peak inrush current (20 ms) 40 A Max. switching voltage, (pollution 3) 500 V Max. AC load (Table 12, page 49) 4 KVA Max. DC load See Table 15 Materials code 0 (standard) Max. switching current 16 A Peak inrush current (20 ms) 40 A Max. switching voltage, (pollution 3) 500 V Max. AC load (Table 12, page 49) 4 KVA Electrical life, DC See Tables 6 and 7, page 46 Materials code 0 (standard) Max. switching current 10 A Peak inrush current (20 ms) 30 A Max. switching voltage, (pollution 3) 500 V Max. AC load (Table 1, page 44) 2,5 KVA Max. DC load See Table 2, page 44 4 gap > 3 mm (1,7 + 1,7) Magnet (+) 6 gap > 3 mm (1,7 + 1,7) A 1 4 3 6 A1(+) 12 14 22 24 A 8 A1 A3 ON (+) OFF (+) A2 11 21 A2 (-) B 7 9 B Standard types (50/60 Hz and DC) Standard types (50/60 Hz and DC) Standard types (50/60 Hz and DC) AC 24, 48, 115 (110 ... 120), 230, 400 X = LED (optional) C5-X10 X/ ... V RC suppressor C5-X10R X/ ... V AC 24, 48, 115 (110 ... 120), 230, 400 X = LED (optional) C5-M10 X/ ... V RC suppressor C5-M10R X/ ... V AC 24, 48, 115 (110 ... 120), 230 C5-R20 / ... V DC 12, 24, 48, 110, 120/125, 220 X = LED (optional) C5-X10 Free wheeling diode C5-X10D Free wheeling and polarity C5-X10F AC/DC rectifier (60V max.) C5-X20B DC 12, 24, 48, 110, 120/125, 220 X = LED (optional) C5-M10 X/ Free wheeling diode C5-M10D X/ Free wheeling and polarity C5-M10F X/ AC/DC rectifier (60V max.) C5-M20B X/ DC 12, 24, 48, 110, 125 (two windings) X/ X/ X/ X/ ... ... ... ... V V V V Specifications ... ... ... ... V V V V Specifications Nominal coil power: 2,4 VA (AC), 1,3 Operate time Release time Isolation: EN60947 pollution 3, Gr C Dielectric strength, contacts / coil Weight avg. Table 14 Type C5-G30 W (DC) 20 ms. 10 ms. 500V 4 KV 90 grs. Table 15 Type C5-X10 W (DC) 20 ms. 10 ms. 500V 4 KV 90 grs. ON pulse power 1,5 VA/ W OFF pulse power 0,5 VA/ W Min. pulse length for ON/OFF control 50 ms. Isolation: EN60947 pollution 3, Gr C 500V Dielectric strength, contacts / coil 4 KV Dielectric strength, pole / pole 4 KV Max. DC load 16 10 16 10 Note: All AC and DC coils withstand permanent connection. Specifications Nominal coil power: 2,4 VA (AC), 1,3 Operate time Release time Isolation: EN60947 pollution 3, Gr C Dielectric strength, contacts / coil Weight avg. Max. DC load C5-R20 / ... V Table 16 Type C7-A10 Max. DC load 16 10 DC1 DC13 DC1 DC13 DC1 DC13 1 0,1 Volts 25 Amps 1 Amps Amps 1 75 125 175 225 0,1 Volts 25 75 125 50 175 225 0,1 Volts 25 75 125 175 225 RELAYS QRC 8 PIN MINIATURE STANDARD/LOW SIGNAL LEVEL • • • • • • Lockable test button Marking label on relay 2 window mechanical flag Colour coded test button Coil voltage marked on top of relay Label carries full technical information • CE marked C7-A20... General purpose Two change-over contacts, 10 A 10A / 250V AC1 6A / 250V AC15 10A @ 30V DC1 0,5A @ 110V DC1 C7-T21... Low level Two change-over, bifurcated contacts C7-A10... 6A / 250V AC1 6A @ 30V DC1 Min. 5mA @ DC 5V 16A / 250V AC1 8A / 250V AC15 General purpose One change-over contact, 16 A 16 A @ 30V DC1 0,5A @ 110V DC1 Contacts Contacts Contacts Materials code 0 (standard); options: 8 - 9 Max. switching current 10 A Peak inrush current (20 ms) 30 A Max. switching voltage, (pollution 3) 250 V Max. switching voltage, (pollution 2) 400 V Max. AC load (Table 17) 2,5 KVA Max. DC load See Table 2, page 44 Materials code 1 (standard); option: 2 Switching current: min. 5 mA; max. 6 A Peak inrush current (5 ms) 15 A Max. switching voltage, (pollution 3) 250 V Max. switching voltage, (pollution 2) 400 V Max. AC load (Table 3, page 45) 1,2 KVA Max. DC load See Table 18 Materials code 0 (standard) Max. switching current 16 A Peak inrush current (20 ms) 40 A Max. switching voltage, (pollution 3) 250 V Max. switching voltage, (pollution 2) 400 V Max. AC load (Table 12, page 49) 4 KVA Max. DC load See Table 16, page 50 1 4 1 3 2 4 7 1 3 2 4 7 12 14 22 24 A1(+) 12 14 22 24 A1(+) 11 21 A2 11 21 A2 5 6 8 5 6 8 7 A1 (+) A2 5 8 Standard types (50/60 Hz and DC) Standard types (50/60 Hz and DC) Standard types (50/60 Hz and DC) AC 24, 48, 115 (110 ... 120), 230 X = LED (optional) C7-A20 X/ ... V AC 24, 48, 115 (110 ... 120), 230 X = LED (optional) C7-T21 X/ ... V AC 24, 48, 115 (110 ... 120), 230 X = LED (optional) C7-A10 X/ ... V DC 12, 24, 48, 110, 120/125, 220 X = LED (optional) C7-A20 Free wheeling diode C7-A20D Free wheeling and polarity C7-A20F AC/DC rectifier (60V max.) C7-A20B X/ X/ X/ X/ DC 12, 24, 48, 110, 120/125, 220 X = LED (optional) C7-T21 Free wheeling diode C7-T21D Free wheeling and polarity C7-T21F AC/DC rectifier (60V max.) C7-T21B X/ X/ X/ X/ DC 12, 24, 48, 110, 120/125 X = LED (optional) C7-A10 Free wheeling diode C7-A10D Free wheeling and polarity C7-A10F AC/DC rectifier (60V max.) C7-A10B X/ X/ X/ X/ ... ... ... ... V V V V ... ... ... ... V V V V ... ... ... ... V V V V Specifications Specifications Specifications Nominal coil power: 1,5 VA (AC), 1 W (DC) Operate time 16 ms. Release time 8 ms. Isolation: EN60947 pollution 3, Gr C 250V Dielectric strength, contacts / coil 2,5 KV Dielectric strength, pole / pole 2,5 KV Weight avg. 43 grs. Nominal coil power: 1,5 VA (AC), 1 W (DC) Operate time 16 ms. Release time 8 ms. Isolation: EN60947 pollution 3, Gr C 250V Dielectric strength, contacts / coil 2,5 KV Dielectric strength, pole / pole 2,5 KV Weight avg. 43 grs. Nominal coil power: 1,8 VA (AC), 1,5 W (DC) Operate time 16 ms. Release time 8 ms. Isolation: EN60947 pollution 3, Gr C 250V Dielectric strength, contacts / coil 2,5 KV Weight avg. 43 grs. Table 17 Electrical life (ops x 106) Types C7-A20, C7-G20, C7-X, C7-W 28 37.5 Dimensions (mm) 1 2 3 5 4 6 7 A Table 18 Max. DC load Types C2-T21, C3-T31, C7-T21 10 10 DC1 AC1 AC15 8 B RELECO 21 1 FASTON .187 4.05 4.70 5.90 7.25 2 C.I. 1 ops 4.75 Amps 10 ø2.2 6.10 14.5 0,1 KVA 0,5 1 1,5 51 2 2,5 0,1 Volts 25 75 125 175 225 RELAYS QRC 8 PIN MINIATURE OPEN CONTACTS/ POWER/HIGH INRUSH CURRENT • • • • • • Lockable test button Marking label on relay 2 window mechanical flag (not available on C7-G20 or C7-X10) Colour coded test button Coil voltage marked on top of relay Label carries full technical information • CE marked C7-G20... Power relay, DC Two open contacts, gap 1,5 mm 10A / 250V AC1 0,4A @ 220V DC1 0,8 A @ 110V DC1 0,3A @ 110V DC13 C7-X10... Power relay, DC Single pole, NO, double make 10A / 250V AC1 6A @ 110V DC1 1A @ 220V DC1 0,3A @ 220V DC13 C7-W10... High inrush current Single pole, two contacts in parallel wolfram and silver 10A / 250V AC15 6A @ 250V AC5a/b Contacts Contacts Contacts Materials code 0 (standard) Max. switching current 10 A Peak inrush current (20 ms) 30 A Max. switching voltage, (pollution 3) 250 V Max. switching voltage, (pollution 2) 400 V Max. AC load (Table 17, page 51) 2,5 KVA Max. DC load See Table 19 Materials code 0 (standard) Max. switching current 10 A Peak inrush current (20 ms) 30 A Max. switching voltage, (pollution 3) 250 V Max. switching voltage, (pollution 2) 400V Max. AC load (Table 17, page 51) 2,5 KVA Max. DC load See Table 20 Materials code 0 (standard) Max. switching current 10 A Peak inrush current (2,5 ms) 500 A Max. switching voltage, (pollution 3) 250 V Max. switching voltage, (pollution 2) 400 V Max. AC load (Table 17, page 51) 2,5 KVA Electrical life, AC5 a/b (lamps) See Table 21 3 4 3 7 4 5 6 7 A1(+) A2 A2 A2 gap 1,5 mm 4 7 A1(+) A1(+) 8 5 8 gap 3 mm (1,5 + 1,5) Standard types (50/60 Hz and DC) AC 24, 48, 115 (110 ... 120), 230 X = LED (optional) C7-G20 X/ ... V AC 24, 48, 115 (110 ... 120), 230 X = LED (optional) C7-X10 X/ ... V AC 24, 48, 115 (110 ... 120), 230 X = LED (optional) C7-W10 X/ ... V DC 12, 24, 48, 110, 120/125 X = LED (optional) C7-G20 X/ ... V Free wheeling diode C7-G20D X/ ... V Free wheeling and polarity C7-G20F X/ ... V AC/DC rectifier (60V max.) C7-G20B X/ ... V DC 12, 24, 48, 110, 120/125 X = LED (optional) C7-X10 X/ ... V Free wheeling diode C7-X10D X/ ... V Free wheeling and polarity C7-X10F X/ ... V AC/DC rectifier (60V max.) C7-X10B X/ ... V DC 12, 24, 48, 110, 120/125 X = LED (optional) C7-W10 X/ ... V Free wheeling diode C7-W10D X/ ... V Free wheeling and polarity C7-W10F X/ ... V AC/DC rectifier (60V max.) C7-W10B X/ ... V Specifications Specifications Specifications Nominal coil power: 1,8 VA (AC), 1,5 Operate time Release time Isolation: EN60947 pollution 3, Gr C Dielectric strength, contacts / coil Dielectric strength, pole / pole Weight avg. Table 19 Type C7-G20 W (DC) 20 ms. 10 ms. 250V 2,5 KV 2,5 KV 43 grs. Standard types (50/60 Hz and DC) 8 Nominal coil power: 1,8 VA (AC), 1,3 Operate time Release time Isolation: EN60947 pollution 3, Gr C Dielectric strength, contacts / coil Weight avg. Max. DC load 10 Table 20 Type C7-X10 W (DC) 20 ms. 10 ms. 250V 2,5 KV 43 grs. Nominal coil power: 1,8 VA (AC), 1,3 W (DC) Operate time 20 ms. Release time 10 ms. Isolation: EN60947 pollution 3, Gr C 250V Dielectric strength, contacts / coil 2,5 KV Weight avg. 43 grs. Table 21 Electrical life (ops x 106) Type C7-W10 AC5a/b (lamps) Max. DC load 10 10 DC1 DC13 DC1 DC13 AC5 a/b 1 1 75 125 175 225 0,1 Volts 25 ops Amps 1 Amps 0,1 Volts 25 Standard types (50/60 Hz and DC) 75 125 52 175 225 0,1 VA 0 250 500 750 1000 RELAYS QRC 14 PIN MINIATURE STANDARD/ SENSITIVE COIL / LATCHING • • • • • • Lockable test button Marking label on relay 2 window mechanical flag (not available on C9-E21) Colour coded test button Coil voltage marked on top of relay Label carries full technical information • CE marked C9-A41... General purpose Four change-over contacts, 3 A 3A / 250V AC1 1A / 250V AC15 3A @ 30V DC1 0,2A @ 110V DC1 C9-E21... C9-R21... Operating range: 0,8 ... 1,7 x Un 3A / 250V AC1 3A @ 30V DC1 3A / 250V AC1 1A / 250V AC15 Sensitive, 500 mW Two change-over contacts, 3 A Latching Two change-over contacts, 3 A 3A @ 30V DC1 0,2A @ 110V DC1 Contacts Contacts Contacts Materials code 1 (standard); options: 2 - 9 Max. switching current 3A Peak inrush current (10 ms) 15 A Max. switching voltage, (pollution 2) 150 V Max. AC resistive load (Table 22) 0,7 KVA Max. DC load See Table 23 Materials code 1 (standard); options: 2 - 9 Max. switching current 3A Peak inrush current (10 ms) 15 A Max. switching voltage, (pollution 3) 250 V Max. AC resistive load (Table 22) 0,7 KVA Max. DC load See Table 23 Materials code 1 (standard) Max. switching current 3A Peak inrush current (10 ms) 15 A Max. switching voltage, (pollution 3) 250 V Max. AC resistive load (Table 22) 0,7 KVA Max. DC load See Table 23 1 5 2 6 3 7 4 8 12 14 22 24 32 34 42 44 13 1 5 4 8 13 1 5 4 8 13 10 A1(+) 12 14 22 24 A1(+) 12 14 22 24 A1 A3 ON (+) OFF (+) 11 21 31 41 A2 11 21 A2 11 21 A2 (-) 9 10 11 12 14 9 12 14 9 12 14 Standard types (50/60 Hz and DC) AC 24, 48, 115 (110 ... 120), 230 X = LED (optional) C9-A41 X/ ... V Standard types (50/60 Hz and DC) AC 24, 48, 115 (110 ... 120), 230 X = LED (optional) C9-E21 X/ ... V Standard types (50/60 Hz and DC) AC 24, 48, 115 (110 ... 120), 230 C9-R20 DC 12, 24, 48, 110, 120/125, 220 X = LED (optional) C9-A41 Free wheeling diode C9-A41D Free wheeling and polarity C9-A41F AC/DC rectifier (60V max.) C9-A41B DC 12, 24, 48, 110, 120/125, 220 X = LED (optional) C9-E21 Free wheeling diode C9-E21D Free wheeling and polarity C9-E21F AC/DC rectifier (60V max.) C9-E21B DC 12, 24, 48, 60 (two windings) X/ ... V X/ ... V X/ ... V X/ ... V X/ ... V X/ ... V X/ ... V X/ ... V / ... V C9-R20 / ... V Note: All AC and DC coils withstand permanent connection Specifications Specifications Specifications Nominal coil power: 1,5 VA (AC), 1 W (DC) Operate time 10 ms. Release time 6 ms. Isolation: EN60947 pollution 2 150V Dielectric strength, contacts / coil 2,5 KV Dielectric strength, pole / pole 1 KV Weight avg. 43 grs. Nominal coil power: 1 VA (AC), 500 mW (DC) Operate time 10 ms. Release time 6 ms. Isolation: EN60947 pollution 3, Gr C 250V Dielectric strength, contacts / coil 2,5 KV Dielectric strength, pole / pole 2,5 KV ON pulse power 1,2 VA/ W OFF pulse power 0,3 VA/ W Min. pulse length for ON/OFF control 50 ms. Isolation: EN60947 pollution 3, Gr C 250V Dielectric strength, contacts / coil 2,5 KV Dielectric strength, pole / pole 2,5 KV Weight avg. 43 grs. Note: Specifications valid without LED or diodes Table 22 Electrical life (ops x 106) Types C9-A41, C9-E21, C9-R21 Dimensions (mm) 28 37.5 1 2 3 10 4 Table 23 Max. DC load Types C9-A41, C9-E21, C9-R21 10 5 6 7 8 9 10 11 12 13 AC1 14 DC1 RELECO 21 1 1 ops FASTON .102 4.3 4.05 Amps 4.4 4.4 4.4 2.6 6.35 6.35 1.2 C.I. 6.95 ø1.5 13.2 0,1 VA 0 0,1 250 500 53 750 Volts 25 75 125 175 200 RELAYS IRC SINGLE POLE STANDARD/ LOW SIGNAL LEVEL • LED Indication as standard (except with RC suppression) • Colour coded lockable test button • Marking label on relay • 4.75mm flat blade terminals • Coil voltage marked on top of relay • Gold plate option (C10-A18X and C10-T12X) GENERAL INFORMATION C10-A10X... Electrical and Mechanical Life 100.000 operations at full rated load 20 x 106 mechanical operations measured at 6.000 ops/hour (see table 1). Temperatures Operating and storage temperatures are respectively –20°C...+60°C and –20°C...+100°C. Coil The temperature rise in the coil when permanently energised, at nominal voltage, is 45°C max. at AC and 35°C max. at DC. All coils are calculated to withstand a permanent connection at maximum ambient temperature of 60°C and 10% above the nominal voltage. The coil inrush power of AC coils is approx. 1,3 x nominal power. Vac/dc Ω ± 10% mA 24 48 773 3K5 Vdc 31 13 5 12 24 110 Ω ± 10% 45 224 773 19K9 mA Vac 111 53 31 5,5 24 115 230 Ω ± 10% ≥ 24Vdc Contacts Standard material code 3 - AgNi + 3µ Au Optional material code 2 - AgNi + 10µ Au Switching current min. 1 mA; max. 6 A Peak inrush current (5 ms) 15 A Max. switching voltage, (pollution 3) 250 V Max. switching voltage, (pollution 2) 400 V Max. AC resistive load 1,5 KVA Max. DC load @ 24 V 6A Bridge rectifier 24-48Vac/dc standard A1 BX A1 A2 A2 Polarity protected Free Wheeling Diode ≤ 12Vdc ≥ 60Vdc A1 + A1 + R FX A2 A2 A2 4 3 1 4 A1 12 14 A1 11 A2 11 A2 2 5 2 5 For lamp, see appropriate diagram For lamp, see appropriate diagram Standard types (50/60 Hz and DC) Standard types (50/60 Hz and DC) AC/DC 24, 48 AC 115, 230 DC 5, 12, 24, 48, 110 X = LED (standard) AC/DC rectifier (48V max.) FWD - polarity protected RC protection (no LED) AC/DC 24, 48 AC 115, 230 DC 5, 12, 24, 48, 110 X = LED (standard) AC/DC rectifier (48V max.) FWD - polarity protected RC protection (no LED) C10-A10 X/ ...V C10-A10B X/ ...V C10-A10F X/ ...V C10-A10R / ...V C10-T13 X/ ...V C10-T13B X/ ...V C10-T13F X/ ...V C10-T13R / ...V Specifications Specifications Coil power including LED 1,1 VA, 0,65 W Operate time + bounce time 10 + 1 ms Release time + bounce time 5 + 3 ms Isolation: EN60947 pollution 3, Gr C 250 V Dielectric strength, contact / coil 8 mm / 5 KV Weight avg. 21 grs. Coil power including LED 1,1 VA, 0,65 W Operate time + bounce time 10 + 1 ms Release time + bounce time 5 + 3 ms Isolation: EN60947 pollution 3, Gr C 250 V Dielectric strength, contact / coil 8 mm / 5 KV Weight avg. 21 grs. Table 1: C10-A10X Electrical life (ops. x 106) Table 2: C10-A10X A1 A2 RC protection 115 - 230Vac 3 1 12 14 ≥ 24Vac A1 A2 6A / 400V AC1 6A @ 30V DC1 Min. 1mA @ DC 5V Use 24Vac/dc* 7K1 8,7 28K3 4,3 Diagrams of additions to the coil ≤ 12V 10 A @ 30V DC1 0,5A @ 110V DC1 Standard material AgNi Optional material code 8 - AgNi + 10µ Au Max. switching current 10 A Peak inrush current (10 ms) 30 A Max. switching voltage, (pollution 3) 250 V Max. switching voltage, (pollution 2) 400 V Max. AC resistive load (table 1) 2,5 KVA Max. DC load (table 2) mA Pull-in voltages DC and AC/DC relays: 0,75 x UN AC relays: 0,75 x UN (at 50 and 60Hz) Drop-out voltages DC and AC/DC relays: 0,15 x UN AC relays: 0,35 x UN (at 50 and 60Hz) A1 Iow level Single pole relay, bifurcated contact Contacts All values (LED included) measured at UN with an ambient temperature of 20°C. * 24Vac and any other coil values, as well as special coils, are available upon request. Lamp circuits X C10-T13X... Single pole relay, 10A 10A / 400V AC1 6A / 400V AC15 • BX version — one type fits all! – 24VDC – 24VAC – Not polarity conscious – Free wheeling diode (VDC) – RC suppression (VAC) Suppressors increase release time approx. 3 times in DC LED & protection circuits available BX FX R ● Max. DC load ● ● 10 10 1 1 ● ● Amps X ● ● ● ● ● ● ops Voltage AC 6 … 12 AC 24 … 48 AC 115 … 230 DC 5 … 12 DC 24 … 48 DC 60 … 110 0,1 0,1 VA 250 750 1250 54 1750 2250 Volts 25 75 125 175 225 RELAYS TIME CUBES • Fits between socket and relay • Converts relay to timer relay • On delay, off delay, blinker, one shot and interval functions • Accepts standard C2 or C3 relays • Multi time range CT2A CT3A CT2B Off delay The relay blinks ON/OFF at time (t) when switch S is closed. First pulse, ON Function A 10 (7) S + 2 S S ~ t + CT2K CT3K CT2W CT3W One shot, aux. pulse One shot The relay turns ON with a pulse on the switch S and turns OFF at the time (t) R Function E 10 (7) 2 S t Function K 10 (7) ~ 10 (7) S + 2 S R S ~ + Function W S 2 R S t t t The relay turns ON as switch S is closed and turns OFF at the time (t) R R R R S ~ The timing starts when the switch S is closed. The relay pulls in at the time (t) Function B S CT3E On delay R R 2 CT2E Blinker The timing starts when S is switched off. The relay drops out at time (t) 10 (7) CT3B R S t ~ t + CT2... (8 pin) and CT3... (11 pin) types with time range from 0,2 seconds to 12 minutes (range 20) CT2-A20/S CT2-A20/L CT2-A20/M CT2-A20/U 9,5 ... 18 20 ... 65 90 ... 150 180 ... 265 CT3-A20/S CT3-A20/L CT3-A20/M CT3-A20/U 9,5 ... 18 V 20 ... 65 V 90 ... 150 V 180 ... 265 V V V V V CT2-B20/S CT2-B20/L CT2-B20/H 9,5 ... 18 V 20 ... 65 V 90 ... 265 V CT2-E20/S CT2-E20/L CT2-E20/H 9,5 ... 18 V 20 ... 65 V 90 ... 265 V CT3-B20/S CT3-B20/L CT3-B20/H 9,5 ... 18 V 20 ... 65 V 90 ... 265 V CT3-E20/S CT3-E20/L CT3-E20/H 9,5 ... 18 V 20 ... 65 V 90 ... 265 V CT2-K20/S CT2-K20/L CT2-K20/M CT2-K20/U 9,5 ... 18 20 ... 65 90 ... 150 180 ... 265 CT3-K20/S CT3-K20/L CT3-K20/M CT3-K20/U 9,5 ... 18 V 20 ... 65 V 90 ... 150 V 180 ... 265 V V V V V CT2-W20/S CT2-W20/L CT2-W20/H 9,5 ... 18 V 20 ... 65 V 90 ... 265 V CT3-W20/S CT3-W20/L CT3-W20/H 9,5 ... 18 V 20 ... 65 V 90 ...265 V CT2-W25/S CT2-W25/L CT2-W25/H 9,5 ... 18 V 20 ... 65 V 90 ... 265 V CT3-W25/S CT3-W25/L CT3-W25/H 9,5 ... 18 V 20 ... 65 V 90 ... 265 V CT2... (8 pin) and CT3... (11 pin) types with time range from 0,8 seconds to 30 minutes (range 25) CT3-A25/S CT3-A25/L CT3-A25/M CT3-A25/U 9,5 ... 18 V 20 ... 65 V 90 ... 150 V 180 ... 265 V V V V V Specifications 9,5 ... 18 V 20 ... 65 V 90 ... 265 V CT3-E25/S CT3-E25/L CT3-E25/H 9,5 ... 18 V 20 ... 65 V 90 ... 265 V Time range setting Range 20 Range 25 0,2 - 0,8 - 0,8 - 3s 12 s 0,1 -1,5 min 0,8 - 12 min 3 - CT2-K25/S CT2-K25/L CT2-K25/M CT2-K25/U 9,5 ... 18 V 20 ... 65 V 90 ... 150 V 180 ... 265 V CT3-K25/S CT3-K250/L CT3-K25/M CT3-K25/U 9,5 ... 18 V 20 ... 65 V 90 ... 150 V 180 ... 265 V Dimensions Dip - Sw 7654 32 1 Time accuracy: Repetition + 0,5% / 20 ms. Supply voltage 1 ms / volt. Ambient temperature -0,25% / K Reset time (types E, W, B) < 150 ms. Reset time (types A, K) < 200 ms. Triggering time: AC, 80 ms ; DC, 50 ms. Ambient temperature -10°C ... +60°C Transient protection IEC 255.4 Housing material: Noryl SE1 (UL94V-1) Protection class (DIN 40050) IP40 Weight avg. 35 grs. CT2-E25/S CT2-E25/L CT2-E25/H 8s 6 5 7 4 30 s 50 9,5 ... 18 20 ... 65 90 ... 150 180 ... 265 10 9 8 CT2-A25/S CT2-A25/L CT2-A25/M CT2-A25/U 8 3 0,4 - 4 min 9 2 1 3 - 30 min 35 10 A / 380 V 55 12.5 24.5 11 10 RELAYS SOCKETS FOR C2 RELAYS • Built in retaining clip • Removable label marking facility • Coding ring compatible • One or two level terminals • DIN rail, solder tag or PCB mount S2-B S2-S One level. Integrated clip and marking label Accepts the exclusive Releco coding ring for coding both the relay and base. DIN rail or panel mountable. Removable label. EN/DIN and sequencial numbering. According to EN60947 Wiring diagram S2-L Two level. Integrated clip and marking label Accepts the exclusive Releco coding ring for coding both the relay and base. DIN rail or panel mountable. Removable label. EN/DIN and sequencial numbering. According to EN60947 Wiring diagram S2-PO 8 pin, solder and printed circuit tags S2-L Flange panel mountable. S2-PO Printed circuit tags with flange. Printed circuit lay-out 45° 6 ( 24 ) 5 ( 22 ) 1 ( 11 ) 4 ( 12 ) 2 ( A1) 3 ( 14 ) Specifications 8 ( 21 ) 6 ( 24 ) ø1.3 5 ( 22 ) S2-B 3 2 ( A1) 3 ( 14 ) 1( 11 ) 4 ( 12 ) 8 1 Specifications Nominal load 10A / 300V Dielectric strength (adjacent screws) 2,5 KV Dielectric strength (screws / rail) 2,5 KV Max. screw torque 1,2 Nm Screw dimensions M3, Pozi Wire in-lets capacity: Solid wire 4 mm2 or 2 x 2,25 mm2 Multi-core 22 - 14 AWG ø8.2 S2-S Nominal load 10 A / 300 V Dielectric strength (adjacent pin) 2,5 KV Hard brass, tin-plated terminals S2-L S2-PO 6 38 7.2 24 25 3.4 ø8.2 2 7 Specifications Nominal load 10A / 300V Dielectric strength (adjacent screws) 2,5 KV Dielectric strength (screws / rail) 2,5 KV Max. screw torque 1,2 Nm Screw dimensions M3, Pozi Wire in-lets capacity: Solid wire 4 mm2 or 2 x 2,25 mm2 Multi-core 22 - 14 AWG 4 5 6 17.5 7 ( A2 ) 8 ( 21 ) 7 ( A2 ) ø5.3 ø 5.3 39 49 4 8 M3 10 M3 M3.5 ø29.5 7 L 4 2 56 4 12 3 14 1 11 2 A1 Can be used to code a specific relay to fit a specific socket up to 8 combinations. Supplied in a pack of 5 pieces. S2-PO 15 10 4.7 15 PO S2-S 3 Coding Ring 1 38 30 38 4 29.75 5 Label 5 RELECO 7 6 24 22 12 14 2 S3-B 2 80 5 22 6 24 8 21 7 A2 7 1 A2 21 11 A1 8 RELECO 7 68 S2-BC S2-L RELAYS SOCKETS FOR C3 RELAYS • Built in retaining clip • Removable label marking facility • Coding ring compatible • One or two level terminals • DIN rail, solder tag or PCB mount S3-S One level. Integrated clip and marking label Accepts the exclusive Releco coding ring for coding both the relay and base. DIN rail or panel mountable. Removable label. EN/DIN and sequencial numbering. According to EN60947 Wiring diagram S3-L Two level. Integrated clip and marking label Accepts the exclusive Releco coding ring for coding both the relay and base. DIN rail or panel mountable. Removable label. EN/DIN and sequencial numbering. According to EN60947 Wiring diagram S3-PO 8 pin, solder and printed circuit tags S3-L Flange panel mountable. S3-PO Printed circuit tags with flange. Printed circuit lay-out 32°44’ 32°44’ 9 ( 34 ) ( A2 ) 8 ( 32 ) 11 ( 31 ) 7 ( 24 ) 1 ( 11 ) 6 ( 21 ) 2 ( A1) 5 ( 22 ) 3 ( 14 ) 10 ( A2 ) 11( 31 ) 9 ( 34 ) 8 ( 32 ) 6 ( 21 ) 7 ( 24 ) 5 ( 22 ) ø1.3 7 6 5 4 8 3 9 2 ( A1) 3 ( 14 ) 1( 11 ) 2 10 4 ( 12 ) 11 4 ( 12 ) 19 S3-B 1 Specifications Specifications Specifications Nominal load 10A / 250V Dielectric strength (adjacent screws) 2,5 KV Dielectric strength (screws / rail) 2,5 KV Max. screw torque 1,2 Nm Screw dimensions M3, Pozi Wire in-lets capacity: Solid wire 4 mm2 or 2 x 2,25 mm2 Multi-core 22 - 14 AWG Nominal load 10A / 250V Dielectric strength (adjacent screws) 2,5 KV Dielectric strength (screws / rail) 2,5 KV Max. screw torque 1,2 Nm Screw dimensions M3, Pozi Wire in-lets capacity: Solid wire 4 mm2 or 2 x 2,25 mm2 Multi-core 22 - 14 AWG Nominal load 10 A / 250 V Dielectric strength (adjacent pin) 2,5 KV Hard brass, tin-plated terminals ø8.2 ø8.2 S3-S S3-L S3-PO 6 38 7.2 24 25 3.4 S3-B ø5.3 ø 5.3 39 49 8 M3 10 M3 4 M3.5 ø29.5 5 S3-S 2 5 Coding Ring Can be used to code a specific relay to fit a specific socket up to 11 combinations. Supplied in a pack of 5 pieces. 57 4 12 3 14 1 11 2 A1 4 80 S3-PO 15 10 4.7 6 PO 15 30 5 22 7 24 38 7 RELECO 38 8 32 9 34 10 6 21 7 5 68 S3-BC 11 31 10 A2 8 7 2 S3-B 3 32 24 21 22 12 10 RELECO 2 34 A2 31 11 A1 14 9 10 11 1 29.75 7 L S3-L 1 RELAYS MODULE SOCKETS & MODULES FOR C3 RELAYS • Built in retaining clip • Removable label marking facility • Logical wiring • In line single level terminals • Accepts serial and parallel modules S3-MP One level, screws in line Logic wiring and Modules Accepts the plug-in modules M3P in parallel with the relay coil. Integrated hold-down clip and removable marking label. DIN rail or panel mountable. EN/DIN and sequencial numbering. Wiring diagram S3-MS One level, screws in line Logic wiring and Modules Accepts the plug-in modules M3S in series with the coil and M3P in parallel. Integrated hold-down clip and removable marking label. DIN rail or panel mountable. EN/DIN and sequencial numbering. Wiring diagram 10 ( A2 ) 9 ( 34 ) 10 ( A2 ) 9 ( 34 ) 11( 31 ) 8 ( 32 ) 11( 31 ) 8 ( 32 ) 7 ( 24 ) 6 ( 21 ) 5 ( 22 ) 1 ( 11 ) 6 ( 21 ) 1 ( 11 ) M o d u l e 3 ( 14 ) 2 ( A1) B1 4 ( 12 ) M o d u l e 7 ( 24 ) 5 ( 22 ) M3P Plug in modules for S3-MP In parallel with the coil Signaling LED M3P-X / 24 Vac/dc M3P-X / 48 Vac/dc M3P-X / 110 ... 125 Vac/dc M3P-X / 200 ... 230 Vac/dc A1 A1 A2 A2 Free wheeling diode M3P-DL / 12 ... 60 Vdc M3P-DH / 12 ... 250 Vdc A1(+) A1+ () A2 A2- 3 ( 14 ) 2 ( A1) 4 ( 12 ) Specifications Specifications Nominal load 10 A / 250 V Dielectric strength (adjacent screws) 2,5 KV Dielectric strength (screws / rail) 2,5 KV Max. screw torque 1,2 Nm Screw dimensions M3, Pozi Wire in-lets capacity: Solid wire 4 mm2 or 2 x 2,25 mm2 Multi-core 22 - 14 AWG Nominal load 10 A / 250 V Dielectric strength (adjacent screws) 2,5 KV Dielectric strength (screws / rail) 2,5 KV Max. screw torque 1,2 Nm Screw dimensions M3, Pozi Wire in-lets capacity: Solid wire 4 mm2 or 2 x 2,25 mm2 Multi-core 22 - 14 AWG Free wheeling diode and LED M3P-DX / 24 Vdc M3P-DX / 48 Vdc M3P-DX / 110 ... 125 Vdc M3P-DX / 200 ... 230 Vdc A1(+) A1+ A2 ( ) A2- A1 A1 A2 A2 RC suppressor and LED M3P-RC / 20 ... 50 Vac M3P-RC / 110 ... 120 Vac M3P-RC / 220 ... 240 Vac M3S Plug in modules for S3-MS In series with the coil S3-MP S3-MS ø8.2 ø8.2 26 ø4.3 A1(+) A1+ () A2 A2- ø3.2 ø3.2 29.5 5 38 7 3 4 58 9 8 2 2 A1 4 75 34 32 24 22 14 12 3 RELECO S3-MS 10 1 5 21 11B1 7 10 11 6 A2 31 9 8 34 32 24 22 14 12 2 2 A1 75 Free wheeling, polarity and LED M3S-FX / 24 Vdc M3S-FX / 48 Vdc M3S-FX / 110 ... 125 Vdc M3S-FX / 200 ... 230 Vdc 38 ø4.3 RELECO S3-MP 10 1 21 11 10 11 6 A2 31 29.5 M3S-FL / 12 ... 60 Vdc M3S-FH /12 ... 250 Vdc 7.5 7.5 26 Free wheeling and polarity A1(+) A1+ () A2 A2- Rectifier bridge and LED M3S-B / 12 ... 48 Vac/dc M3S-BX / 12 Vac/dc M3S-BX / 24 Vac/dc M3S-BX / 48 Vac/dc A1 A1 A2 A2 RELAYS SOCKETS FOR C4 AND C5 RELAYS • Built in retaining clip • Removable label marking facility • Two level terminals • DIN rail, solder tag or PCB mount S4-B Two level screws Logic wiring Integrated hold-down clip and removable marking label. DIN rail or panel mountable. EN/DIN and sequencial numbering. According to EN60947 Wiring diagram S4-L S4-P S4-PO S5-S Two level screws Logic wiring 14 pin, solder and printed circuit tags S4-L Flange panel mountable. S4-P Printed circuit tags. S4-PO Printed circuit tags with flange. Printed circuit lay-out Integrated hold-down clip and removable marking label. DIN rail or panel mountable. EN/DIN and sequencial numbering. According to EN60947 Wiring diagram 24 12 ( 41 ) 14 ( A2 ) 10 ( 42 ) 11( 44 ) 9 ( 31 ) 7 ( 32 ) 8 ( 34 ) 6 ( 21 ) 4 ( 22 ) 5 ( 24 ) 8 ø1.5 9 ( 31 ) 6.5 8 ( 21 ) 7 0.2 6.75 3 ( 11 ) 13 ( A1) 1 ( 12 ) 2 ( 14 ) B(A2) 7 ( 11 ) A ( A1) 3 ( 32 ) 6 ( 34 ) 2 ( 22 ) 5 ( 24 ) 1( 12 ) 4 ( 14 ) 6.75 Specifications Specifications Specifications Nominal load 10 A / 250 V Dielectric strength (adjacent screws) 2,5 KV Dielectric strength (screws / rail) 2,5 KV Max. screw torque 1,2 Nm Screw dimensions M3, Pozi Wire in-lets capacity: Solid wire 4 mm2 or 2 x 2,25 mm2 Multi-core 22 - 14 AWG Nominal load 10 A / 250 V Dielectric strength (adjacent pin) 2,5 KV Hard brass tin-plated terminals Nominal load 16 A / 400 V Dielectric strength (adjacent screws) 2,5 KV Dielectric strength (screws / rail) 2,5 KV Max. screw torque 1,2 Nm Screw dimensions M3, Pozi Wire in-lets capacity: Solid wire 4 mm2 or 2 x 2,25 mm2 Multi-core 22 - 14 AWG S4-B S4-PO ø9 S4-L S5-S ø 6.5 35.5 6 15.5 6 7.5 ø 4.2 RELECO 47 ø5.5 S4-L M4 M4/M5 36 4 14 38 5 24 2.8 A A1 7 11 80 59 6 34 1 35.5 1 12 1.2 S5-S S4-P 2 22 RELECO 8 21 RELECO 3 32 9 31 4 6 2 3 11 44 8 34 5 24 2 14 7 5 13 S4-B 3 11 21 13 A1 10 42 7 32 4 22 1 12 10 8 14 11 9 12 RELECO 14 21 12 41 9 31 6 92 B A2 S4-P 8.3 38 57 7 11.5 32 29.4 M3 RELAYS SOCKETS FOR C7 RELAYS • • • • • • S7-M One level, screws on line 22,5 mm wide Socket offers an optimum packing density and is provided with sturdy screws terminals. DIN rail or panel mountable. Integrated clip. Removable marking label EN/DIN and sequencial numbering. Wiring diagram Built in retaining clip Removable label marking facility One level terminals & in line screws (on S7M) S7M is only 22.5mm wide S7-I0 input-output socket Bridge bar available for S7-I0 S7-L S7-P S7-PO Solder and printed circuit tags S7-L Flange panel mountable. S7-P Printed circuit tags. S7-PO Printed circuit tags with flange. Specifications Nominal load 10 A / 250 V Dielectric strength (input-output) 2,5 KV Dielectric strength (screws / rail) 2,5 KV M3, Pozi screw max. torque 1,2 Nm Wire inlet capacity multi-core 22 - 14 AWG Wire inlet solid wire 4 mm2 or 2 x 2,25 mm2 Weight avg. 48 grs. 10 4 ( 24 ) 6 ( 21 ) 2 ( 22 ) 5 ( 11 ) 3 ( 14 ) 7 ( A1) 1( 12 ) 0.6 4.7 5.9 7.25 ø 2.5 14.5 Specifications Input-Output socket for 2 pole C7 relay Bridge bar for coil (A2), Integrated clip, DIN rail or panel mounting Printed circuit lay-out 8 ( A2 ) S7-IO Specifications Nominal load 10 A / 250 V Dielectric strength (adjacent screws) 2,5 KV Dielectric strength (screws / rail) 2,5 KV Max. screw torque 1,2 Nm Screw dimensions M3, Pozi Wire in-lets capacity: Solid wire 4 mm2 or 2 x 2,25 mm2 Multi-core 22 - 14 AWG Nominal load 10 A / 250 V Dielectric strength (adjacent screws) 2,5 KV Hard brass tin-plated terminals S7-PO S7-M S7-L 22.5 5.2 13.1 7.7 5 46 36.4 26 M3 2 1 4 3 6 5 RELECO 8 7 S7-L A B 3 1 30 22.5 2 7 24 22 14 12 4 5 S7-M 6 RELECO 8 A2 21 11 A1 S7-P 75 2 1 4 3 6 5 S7BB 2 RELECO 8 7 S7-P 22.5 S7-16 3.5 Bridge bar for use with S7-IO sockets. Pack quantity 5 pieces of strips of 4. A B Bridge Bar 16A Socket Bridge bar (pack of five) S7BB 16A rated socket @ 250V specifically for use with C7-A10 16A single pole relays. All other characteristics as per S7-M 60 RELAYS SOCKETS FOR C9 & C10 RELAYS • Built in retaining clip • Removable label marking facility • • • • S9-M Two level, screws in line 22,5 mm wide Socket offers an optimum packing density and is provided with sturdy screws terminals. DIN rail or panel mountable. Integrated clip. Removable marking label. EN/DIN and sequencial numbering. Wiring diagram DIN rail, solder tag or PCB mount S9M is only 22.5mm wide Bridge bar available for S-10 S-10 is only 16.5mm wide S9-L S9-P S9-PO S9-L Flange panel mountable. S9-P Printed circuit tags. S9-PO Printed circuit tags with flange. Specifications Nominal load 10 A / 250 V Dielectric strength (input-output) 8 mm - 5 KV Dielectric strength (screws / rail) 5 KV M3, Pozi screw max. torque 1,2 Nm Wire inlet capacity multi-core 22 - 14 AWG Wire inlet solid wire 4 mm2 or 2 x 2,25 mm2 Weight avg. 28 grs. 4.4 4 ( 42 ) 8 ( 44 ) 11( 31 ) 3 ( 32 ) 7 ( 34 ) 10 ( 21 ) 2 ( 22 ) 6 ( 24 ) 1( 12 ) 5 ( 14 ) 9 ( 11 ) 13 ( A1) 4.05 0.6 6.35 6.35 ø 1.7 13.2 Specifications Input-Output socket for C10 relay Bridge bar for coil and movable contact, Integrated clip, DIN rail or panel mounting Printed circuit lay-out 12 ( 41 ) 14 ( A2 ) S-10 Solder and printed circuit tags Specifications Nominal load 6 A / 250 V Dielectric strength (adjacent screws) 2,5 KV Dielectric strength (screws / rail) 2,5 KV Max. screw torque 1,2 Nm Screw dimensions M3, Pozi Wire in-lets capacity: Solid wire 4 mm2 or 2 x 2,25 mm2 Multi-core 22 - 14 AWG Nominal load 6 A / 250 V Dielectric strength (adjacent screws) 2,5KV Hard brass tin-plated terminals S9-M S9-PO S9-L 22.5 4 12.6 7.7 5 4 3 2 8 7 6 1 5 12 11 10 9 46 26 36.4 46.5 20.5 M3 RELECO 14 S9-L 13 30 5 1 2 2 3 6 1 44 34 24 14 4 7 3 8 7 6 5 42 32 22 12 8 4 13 13 RELECO S9-M 12 11 10 9 14 14 41 31 21 11 A2 A1 12 11 10 9 22.5 S9-P 4 3 2 8 7 6 S10BB Bridge Bar 1 5 12 11 10 9 RELECO 14 S9-P 1.2 13 75 2.6 Bridge bar for use with S-10 sockets. Pack quantity 5 pieces of strips of 4. 22.5 Bridge bar (pack of five) S10BB 61
C10A10X24D 价格&库存
很抱歉,暂时无法提供与“C10A10X24D”相匹配的价格&库存,您可以联系我们找货
