ARP120A3R
ARP120A3R
    MACROMATIC
    SOCKETABLE
    ARP120A3R
ARP120A3R 数据手册
www.macromatic.com  800.238.7474 ARP120A3R Family: ALTERNATING RELAY Function: DPDT CROSS­WIRED Input: 120 VAC Output: 10A DPDT X WIRED Distributor Stock Status: Use socket: 70169­D Image may not be exact product—for reference only. Allied: Distributor part #70175250 Newark: Distributor part #04M5443 Grainger: Distributor part #6MPN9 Galco: Distributor part #ARP120A3R­MCRM   Description of function:  Function Chart:  In the off state, both the Lead Control Switch and the Lag Control Switch are open, the Alternating Relay is in the LOAD A position, and both loads are off. When the Lead Control Switch closes, it energizes the first load (M1). The red LED marked "LOAD A" ? glows. As long as the Lead Control Switch remains closed, M1 remains energized. If the Lag Control Switch closes, it energizes the second load (M2). When the Lag Control Switch opens, the second load (M2) is turned off. When the Lead Control Switch opens, the first load (M1) is turned off and the Alternating Relay toggles to the LOAD B position. When the Lead Control Switch closes, it turns on the second load (M2). The red LED marked "LOAD B" glows. If the Lag Control Switch closes, it will energize the first load (M1). When the Lag Control Switch opens, the first load (M1) is turned off. When the Lead Control Switch opens, the second load (M2) is turned off, the Alternating Relay toggles back to the LOAD A position, and the process can be repeated again. NOTE: if the Lag Control Switch does not close while the Lead Control Switch is closed, the Alternating Relay will act as a normal unit. Voltage Tolerance: AC Operation: +10/­15% of nominal at 50/60 Hz. Load (Burden): Less than 3 VA Indicator LEDs: Two LEDs marked LOAD A and LOAD B Output Contacts: 10A @ 240V AC/30V DC, 1/2HP @ 120/240V AC (N.O.), 1/3HP @ 120/240V AC (N.C.) Life: Mechanical: 10,000,000 operations; Full Load: 100,000 operations Temperature: ­28o to 65o C (­18o to 149o F) Insulated Voltage: 2,000 volts Approvals:     Dimensions
ARP120A3R 价格&库存
很抱歉,暂时无法提供与“ARP120A3R”相匹配的价格&库存,您可以联系我们找货
