59-H60.01-R02F
59-H60.01-R02F
    EUROTEC
59-H60.01-R02F 数据手册
www.eurotec-intl.co.uk 59-H60.01-R02F 60mm Tweeter 8 Ohm 1150Hz RoHS Compliant 89dB Rated Power (RMS) 3W After the following tests the speaker operates normally. Thermal Shock Test -30˚C±2˚C/2Hrs +80˚C/2Hrs 20 Cycles Humidity Test +40˚C 95%RH 96Hrs High Temperature Test +85˚C 240 Hrs Low Temperature Test -40˚C 72 Hrs A (mm) Output S P L 1W @ 1m FS 1233.31 Hz RE 7.07 Ohm RES 5.48 Ohm 89 Nominal impedance Ω 8 Rated Power input (W) QMS 6.35 QES 8.2 3 Speaker weight (g) 134 Voice coil dia (mm) 10 Specification QTS 3.58 MMs 0.313 grams CMs 53 µm/Newton BL 1.44 Tesla-m Thiele small Magnet Dia (mm) 66.5 45 B (mm) Gasket thickness (mm) 56.5 0.6 C (mm) Mounting holes in pitch 24 4
59-H60.01-R02F 价格&库存
很抱歉,暂时无法提供与“59-H60.01-R02F”相匹配的价格&库存,您可以联系我们找货
