Telephone +44 (0)1493 602602
Fax +44 (0)1493 665111
Email:sales@midassensors.com
www.midassensors.com
Electra House, 32 Southtown Road
Great Yarmouth, Norfolk
NR31 0DU, England
PROWAVE
Air Ultrasonic Ceramic Transducers
400EP14D
Dimensions: dimensions are in mm
Asymmetric Beam Patterns
Impedance/Phase Angle vs. Frequency
400EP14D
Transceiver
Center Frequency
40.0±1.0Khz
Bandwidth (-6dB)
1.5Khz
Transmitting Sound Pressure
Level
at resonant frequency; 0dB re
0.0002µbar per 10Vrms at 30cm
Receiving Sensitivity
at resonant frequency 0dB = 1
volt/µbar
Nominal Impedance (Ohm)
103dB min.
±20%
1000
1250 pF
20Vrms
2% Duty (Bursts)
100Vpp
Total Beam Angle Wide
125° typ.
Narrow
-6dB
Operation Temperature
65° typ.
Storage Temperature
-40 to 85°C
-30 to 80°C
All specification taken typical at 25°C
Both lead pins and lead wires output are
available
Models available:
400EP14D
400EP14D0
35
36
37
38
39
40
41
42
43
44
45
Black Al. Housing
Natural Al. Housing
Sensitivity/Sound Pressure Level
Tested under 10Vrms @30cm
-70
110
-75
105
-80
100
-85
95
-90
90
-95
85
-100
80
35
36
37
38
39
40
41
42
43
44
45
Frequency (KHz)
Beam Angle: Tested at 40.0Khz frequency
Wide Angle
Narrow Angle
SPL (dB)
-78dB min.
Max. Driving Voltage (cont.)
1
2
1000
100
Sensitivity (dB)
Capacitance at 1KHz
90
75
60
45
30
15
-30
-45
-60
-75
-90
Frequency (KHz)
1.2 max.
Ringing (ms)
Impedance (Ohm)
10000
Phase Angle (Degree)
Tested under 1Vrms Oscillation Level
Specification
很抱歉,暂时无法提供与“400EP14D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+126.86137
- 10+114.16690
- 100+105.29431
