90/00308880
90/00308880
    JUMO
90/00308880 数据手册
M. K. JUCHHEIM GmbH & Co JUMO Instrument Co. Ltd. JUMO PROCESS CONTROL INC. Delivery address:Mackenrodtstraße 14, 36039 Fulda, Germany Postal address: 36035 Fulda, Germany Phone: +49 661 6003-0 Fax: +49 661 6003-607 E-mail: mail@jumo.net Internet: www.jumo.net JUMO House Temple Bank, Riverway Harlow, Essex CM 20 2TT, UK Phone: +44 1279 635533 Fax: +44 1279 635262 E-mail: sales@jumo.co.uk Internet: www.jumo.co.uk 885 Fox Chase, Suite 103 Coatesville PA 19320, USA Phone: 610-380-8002 1-800-554-JUMO Fax: 610-380-8009 E-mail: info@JumoUSA.com Internet: www.JumoUSA.com Data Sheet 90.2004 Page 1/7 Screw-in resistance thermometers with plug connector ■ for temperatures from -50 to +300°C ■ highly resistant to shock and vibration ■ connector locked in for reliable contact, IP65 or IP69K protection ■ available with transmitter Shockproof screw-in resistance thermometers enable temperature measurement under pressure in motors, compressors, plant engineering and in ship building. The connection between the protection fitting and the connecting cable incorporates a locking system and has IP65 or IP69K protection rating when assembled. The measuring insert is normally fitted with a Pt100 temperature sensor to EN 60 751, Class B in 2-wire circuit. Versions with Pt500 or Pt1000 as well as semiconductor or NTC temperature sensors (only on Types 902004/10 and .../15) can also be supplied. With Types 902004/20 and .../21, there is a choice between 2-wire and 4-wire circuit connections. Types 902004/25 to .../29 are available with transmitter (output 4 – 20mA). Technical data Connection Process connection Protection tube Measuring insert Protection Response times Vibration strength Approvals Accessories Type 902004/10 plug connector with gold-plated contacts, IP65 when assembled Type 902004/15 connector DIN 72 585, IP69K when assembled Types 902004/20, ... /25 and .../28, connector EN 175301-803, Pg9 Types 902004/21, ... /26 and .../29, connector EN 175301-803, Pg11 max. conductor cross-section 1.5mm2, IP65, ambient temperature -40 to +125°C, version with transmitter: ambient temperature -40 to +85°C thread, stainless steel 1.4301 / 1.4571 stainless steel 1.4301, 6mm and 7.5mm dia. stepped down to 4mm brass 2.0401, 7.5mm dia. stepped down to 4mm stainless steel 1.4571, 8mm and 6mm dia. stepped down to 3.3mm, pressure loading 50bar max. at 200°C (Types 902004/20 and .../21) Pt100 temperature sensor, EN 60 751, Class B in 2-wire circuit (replaceable on Types 902004/20 and .../21)* IP65, IP69K when assembled (Type 902004/15) Type 902004/10: t0.5 = 1.2sec, t0.9 = 6sec, in water with 0.2m/sec, 4mm dia. Type 902004/15: t0.5 = 1.2sec, t0.9 = 6sec, in water with 0.2m/sec, 4mm dia. Types 902004/20 and .../21: t0.5 = 15sec, t0.9 = 45sec, in water with 0.2m/sec, 8mm dia. t0.5 = 23sec, t0.9 = 59sec, in oil with 0.2m/sec, 8mm dia. Types 902004/25 to .../29: t0.5 =
90/00308880 价格&库存
很抱歉,暂时无法提供与“90/00308880”相匹配的价格&库存,您可以联系我们找货
