00405-4
00405-4
    KVASER
00405-4 数据手册
Kvaser PCIEcan HS/HS Kvaser PCIEcan HS/HS Kvaser PCIEcan is a CAN interface board for the PCI Express bus that is available with either one or two CAN channels. It features Galvanic Isolation for protection against voltage spikes. The Kvaser PCIEcan is a CAN interface board, with one or two CAN channels, for PCI Express bus systems. Galvanically isolated CAN bus drivers to protect the hardware. Supports PCI Express x1 Designed for standard and industrial computers Quick and easy plug and play installation Hardware compatible with the PCIcanx and PCIcan product families I/O mapped to enable quick reaction times Support CAN 2.0 A and 2.0 B (active) Detection and generation of error frames and remote frames SJA1000 CAN Controllers from Philips, with 64-byte receive FIFO Galvanically isolated CAN bus drivers Supports Silent Mode Dimensions 122 x 103 mm (approx. 4.8 x 4.0 in.) High-speed ISO 11898 compliant driver circuits Interfaces the CAN bus with DSUB CAN connectors. Pin assignment according to CiA-DS102 16 MHz CAN oscillator frequency Wide temperature range, -40°C - +85°C Supports the Kvaser Linx Patent Number: US 5,696,911, SE 501984, DE 19514696 More information see www.kvaser.com © 2014 KVASER AB Technical Data Kvaser PCIEcan HS/HS Galvanic Isolation Bitrate Silent mode Error frame generation Error frame detection Weight Timestamp resolution On board buffer Maximum message rate, send Maximum message rate, receive Sound Clock synchronization Dimensions (WxLxH) Temperature range Order number Yes 0-1000 kbit/s Yes No Yes 100g 0µs No 18000 14000 No N/A 120x95x20mm -40°C to +85°C 73-30130-00405-4 The information herein is subject to change without notice KVASER Aminogatan 25 SE-431 53 Mölndal, Sweden Telephone: +46 (0)31 88 63 44 E-mail: sales@kvaser.com www.kvaser.com © 2014 KVASER AB Powered by TCPDF (www.tcpdf.org)
00405-4 价格&库存
很抱歉,暂时无法提供与“00405-4”相匹配的价格&库存,您可以联系我们找货
