CLA6S-24-CN
CLA6S-24-CN
    PATLITE
CLA6S-24-CN 数据手册
CLA CLA LED Light Bar CLA-1S-Y Daylight, Amber Natural White CLA-2S-CN IP66G/67G/69K CLA-3S-CD CLA-6S-CN More than a diffusion LED light bar, it can be used in places like the food-processing industry with its protection rating of "IP69K", which can endure high-pressurized hot water washing. • Bright, long lasting LED’s. • Suitable for food, beverage and pharmaceutical applications where high-pressure, 80oC high-temperature wash-downs are required. Also meets IP66/67 standards. • The radiating temperature is reduced to 40 degrees or less (34% reduction in comparison to a 20W fluorescent light), increasing environmental efficiency. • Seven lengths in the range from 100 to 1500mm to choose from, with three colors (Daylight, Natural White, Amber), and four types of attachments, including a magnet one, offering a potential for various applications. • The operating temperature range from -40oC to +60oC allows installation in sub-freezing temperatures, such as walk-in freezers. • It is constructed with strong polycarbonate resin, which is resistant to shock. • Corresponds to Europe's RoHS Directive. • Obtained certification for ECOLAB. • Conforms to CE requirements. • UL Listed (File No. E306141). LLumionous umionous C Color olor With a high-intensity Illumination, it is suitable for applications such as lighting-up processing machinery workspace or video inspection systems to help highlight more details, etc. How to Order A 6800K daylight light bar at a distance of 50 cm from the center of irradiation has measured a maximum brightness of 400lx. CLA-CN (Natural White: 4800K) CLA1S-24-CD-30 154 Light Bar Length 1 : 100mm Cable Length 2 : 200mm Blank : 0.5m 3 : 300mm Luminous Color 30 : 3.0m 6 : 600mm -CD(Daylight) 9 : 900mm -CN(Natural White) 12: 1,200mm -Y (Amber)   15: 1,500mm -Y is only available in 100mm and 300mm lengths. ※ CLA-CD (Daylight:6800K) CLA-Y (Amber) Dimensions CLA Dim A Dim B Dim D (30) 30 34 Dim E Minimum Radius: 24mm 3-φ4.2(Beveled) 25 Wiring Example Cable Exit Hole 5 10.3 19.5 22.5 φ4.9 170±5(UL508 Conformity) Cable Exit Distance of 500 or 3000 Dim A Dim B Model Name Total Length Lighting Area CLA1S 124 100 CLA2S 224 200 CLA3S 324 300 CLA6S 624 600 CLA9S 924 900 CLA12S 1,224 1,200 CLA15S 1,524 1,500 Dim D Dim E Mounting Pitch 74 — 174 — 274 574 874 290 1,174 390 1,474 490 Standard Bracket SZ-310AR 6 Cable Specification AWG22/2 wire CLA White 2 pcs. Fuse DC24V Brown Wiring Diagram 4 pcs. Options Option Standard Rear Attachment (Screw Mount) Model SZ-310AR Option Rear Attachment (Magnetic Mount) Model SZ-310ARM Option Side Attachment (Screw Mount) Model SZ-310AS Side Attachment (CLB-24N Compatible) Model SZ-310ASB Specifications Model CLA1S CLA1S CLA1S CLA2S CLA2S CLA3S CLA3S CLA3S CLA6S CLA6S CLA9S CLA9S CLA12S CLA12S CLA15S CLA15S -24 -24 -24 -24 -24 -24 -24 -24 -24 -24 -24 -24 -24 -24 -24 -24 -CD -CN -Y -CD -CN -CD -CN -Y -CD -CN -CD -CN -CD -CN -CD -CN Luminous Color Daylight Natural White Amber Daylight Natural White Daylight Natural White Amber Daylight Natural White Daylight Natural White Daylight Natural White Daylight Natural White Rated Voltage Vibration Operating Rated Current Resistance Temperature Range Consumption 104mA Center Radiation (lx/50cm) Main Body Material Protection Rating 140 Mass 80g 78 208mA 240mA DC 24V (Polarized) 2 19.6 m/s 270 400 220 -40oC - +60oC (RH 90% or less) 130g 180g Polycarbonate IP66/67/69K 480mA 650 340g 720mA 810 500g 960mA 890 660g 1,200mA 945 820g 155
CLA6S-24-CN 价格&库存
很抱歉,暂时无法提供与“CLA6S-24-CN”相匹配的价格&库存,您可以联系我们找货
