DD-25664BE-3A
DD-25664BE-3A
    DENSITRON
DD-25664BE-3A 数据手册
OLED DISPLAY MODULE Product Specification CUSTOMER Standard PRODUCT NUMBER DD-25664BE-3A Date CUSTOMER APPROVAL INTERNAL APPROVALS Product Mgr Doc. Control Electr. Eng Bazile Peter Anthony Perkins Rekha Mani Date: 11/06/08 Date: 11/06/08 Date: 11/06/08 Approval for Specification only Approval for Specification and Sample Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data FORM No. DT-029 TABLE OF CONTENTS 1 MAIN FEATURES ..................................................................................................... 4 2 MECHANICAL SPECIFICATION.......................................................................... 5 2.1 2.2 3 ELECTRICAL SPECIFICATION............................................................................ 7 3.1 3.2 3.3 3.4 3.5 4 CONFORMITY .................................................................................................. 20 DELIVERY ASSURANCE ................................................................................ 20 DEALING WITH CUSTOMER COMPLAINTS ............................................... 25 RELIABILITY SPECIFICATION ......................................................................... 26 8.1 8.2 9 LABELLING AND MARKING ......................................................................... 19 QUALITY ASSURANCE SPECIFICATION ........................................................ 20 7.1 7.2 7.3 8 COMMANDS ..................................................................................................... 17 POWER DOWN AND UP SEQUENCE............................................................. 17 RESET CIRCUIT................................................................................................ 17 ACTUAL APPLICATION EXAMPLE .............................................................. 18 PACKAGING ............................................................................................................ 19 6.1 7 OPTICAL CHARACTERISTICS....................................................................... 16 FUNCTIONAL SPECIFICATION ......................................................................... 17 5.1 5.2 5.3 5.4 6 ABSOLUTE MAXIMUM RATINGS .................................................................. 7 ELECTRICAL CHARACTERISTICS ................................................................. 8 INTERFACE PIN ASSIGNMENT ....................................................................... 9 BLOCK DIAGRAM ........................................................................................... 11 TIMING CHARACTERISTICS ......................................................................... 12 OPTICAL SPECIFICATION.................................................................................. 16 4.1 5 MECHANICAL CHARACTERISTICS ............................................................... 5 MECHANICAL DRAWING ................................................................................ 6 RELIABILITY TESTS ....................................................................................... 26 LIFE TIME.......................................................................................................... 26 HANDLING PRECAUTIONS................................................................................. 27 Product No. DD-25664BE-3A REV. B Page 2 / 27 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data REVISION RECORD Rev. Date Page Chapt. A 27/05/08 -- -- B 11/06/08 10 Product No. DD-25664BE-3A Comment ECR no. Initial Release Change in pin no 29, VCC description REV. B Page 3 / 27 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 1 MAIN FEATURES ITEM CONTENTS Display Format 256 x 64 Dots Colour Light Blue Monochrome Overall Dimensions 88.00 (W) × 27.80 (H) × 2.00 (D) mm Viewing Area 78.78 (W) x 21.18 (H) mm Screen Size 3.12” Mode Passive Matrix Duty ratio 1/64 Driver IC SSD1322 Operating temperature -30°C ~ +85°C Storage temperature -40°C ~ +90°C Product No. DD-25664BE-3A REV. B Page 4 / 27 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 2 MECHANICAL SPECIFICATION 2.1 MECHANICAL CHARACTERISTICS ITEM CHARACTERISTIC UNIT 256 x 64 Dots 88.00 (W) × 27.80 (H) × 2.00 (D) mm 78.78 (W) x 21.18 (H) mm mm 76.78 (W) x 19.18 (H) mm Dot Size 0.28 (W) 0.28 (H) Mm Dot Pitch 0.30 (W) x 0.30 (H) Mm 9.95 G Display Format Overall Dimensions Viewing Area Active Area Weight IC Controller/Driver Product No. SSD1322 DD-25664BE-3A REV. B Page 5 / 27 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 2.2 MECHANICAL DRAWING Product No. DD-25664BE-3A REV. B Page 6 / 27 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 3 ELECTRICAL SPECIFICATION 3.1 ABSOLUTE MAXIMUM RATINGS Item Symbol Min Max Unit Note VCI -0.3 4 V 1, 2 Supply Voltage for Operation Supply Voltage for Logic Supply Voltage for I/O pins Supply Voltage for Display Operating Current for VCC VDD -0.5 2.75 V 1, 2 VDDIO -0.5 VCI V 1, 2 VCC -0.5 16 V 1, 2 ICC - 55 mA 1,2 Operating Temperature TOP -30 +85 °C Storage Temperature TSTG -40 +90 °C Static Electricity Be sure that you are grounded when handling displays. Note 1: All the above voltages are on the basis of “VSS = 0V”. Note 2: When this module is used beyond the above absolute maximum ratings, permanent breakage of the module may occur. Also, for normal operations, it is desirable to use this module under the conditions according to Section 3.2 “Electrical Characteristics”. If this module is used beyond these conditions, malfunctioning of the module can occur and the reliability of the module may deteriorate. Product No. DD-25664BE-3A REV. B Page 7 / 27 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 3.2 ELECTRICAL CHARACTERISTICS Item Symbol Supply Voltage for Operation Supply Voltage for Logic Supply Voltage for I/O Pins Supply Voltage for Display Min Typ Max Unit VCI 2.4 2.8 3.5 V VDD 2.4 2.5 2.6 V VDDIO 1.65 1.8 VCI V 11.5 12 12.5 V VCC Condition Note 3 High Level Input VIH 0.8xVDDIO -- VDDIO V Low Level Input VIL 0 -- 0.2xVDDIO V High Level Output VOH 0.9xVDDIO -- VDDIO V Low Level Output VOL 0 -- 0.1xVDDIO V Note 4 - 1.8 2.25 mA Note 5 - 1.8 2.25 mA Note 4 - 26.3 32.9 mA Note 5 - 41.1 51.4 mA ICI,SLEEP - 1 5 µA ICC,SLEEP - 1 5 µA Operating Current for VCI ICI Operating Current for VCC ICC Sleep Mode Current for VCI Sleep Mode Current for VCC IOUT=100µA, 3.3MHz IOUT=100µA, 3.3MHz Note 3: Brightness (Lbr) and Supply Voltage for Display (VCC) are subject to the change of panel characteristics and the customer’s request. Note 4: VCI = 2.8V, VCC = 12V, 50% Display Area Turn on. Note 5: VCI = 2.8V, VCC = 12V, 100% Display Area Turn on. Product No. DD-25664BE-3A REV. B Page 8 / 27 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 3.3 INTERFACE PIN ASSIGNMENT No. Symbol I/O 1 N.C. (GND) -- 2 VSS P 3 VCC P Function Reserved Pin (Supporting Pin). The supporting pins can reduce the influences from stresses on the function pins. This pin must be connected to external ground. Ground of Logic Circuit This is a ground pin. It also acts as a reference for the logic pins. It must be connected to external ground Power Supply for OEL Panel This is the most positive supply pin of the chip. They must be connected to external source. Voltage Output High Level for COM Signal 4 VCOMH P 5 VLSS P This pin is the input pin for the voltage output high level for COM signals. A tantalum capacitor should be connected between this pin and VSS. Ground of Analog Circuit This is analog ground pin. It should be connected to VSS externally Host Data Input/Output Bus 6~13 D7~D0 I/O These pins are 8-bit bi-directional data bus to be connected to the microprocessors data bus. When serial mode is selected, D1 will be the serial data input SDIN and D0 will be the serial clock input SCLK. Unused pins must be connected to VSS except for D2 in serial mode. Read/Write Enable or Read 14 E/RD# I This pin is MCU interface input. When interfacing to a 68XX-series microprocessor, this pin will be used as the Enable (E) signal. Read/write operation is initiated when this pin is pulled high and the CS# is pulled low. When connecting to an 80XX-microprocessor, this pin receives the Read (RD#) signal. Data read operation is initiated when this pin is low and CS# is pulled low. When serial mode is selected, this pin must be connected to VSS. Read/Write Select or Write 15 R/W# I This pin is MCU interface input. When interfacing to a 68XX-series microprocessor, this pin will be used as Read/Write (R/W#) selection input. Pull this pin to “High” for read mode and pull it “Low” for write mode. When 80XX interface mode is selected, this pin will be the Write (WR#) input. Data write operation is initiated when this pin is pulled low and the CS# is pulled low. When serial mode is selected, this pin must be connected to VSS. Communicating Protocol Select 16 17 Product No. BS0 BS1 I These pins are MCU interface selection input. See the following table: BS0 BS1 3-wire SPI 1 0 4-wire SPI 0 0 8-bit 68XX Parallel 1 1 8-bit 80XX Parallel 0 1 DD-25664BE-3A REV. B Page 9 / 27 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data Data/Command Control 18 D/C# I 19 CS# I 20 RES# I 21 FR O This pin is Data/Command control pin. When the pin is pulled high, the input at D7~D0 is treated as display data. When the pin is pulled low, the input at D7~D0 will be transferred to the command register. For detailed relationship to MCU interface signals, please refer to the Timing Characteristics Diagrams Chip Select This pin is the chip select input. When the pin is enabled for MCU communication only when CS# is pulled low.. Power Reset for Controller and Driver This pin is reset signal input. When the pin is low, initialization of the chip is executed. Cascade Application Connection Pin This pin is No Connection pins. Nothing should be connected to this pin. It should be left open individually. Current Reference for Brightness Adjustment 22 IREF I This pin is segment current reference pin. A resistor should be connected between this pin and VSS. Set the current lower than 10µA 23 N.C. - The N.C. pin between function pins are reserved for compatible and flexible design. Reserved Pin Power Supply for I/O Pin 24 VDDIO P This pin is a power supply pin of I/O buffer. It should be connected to VDD or external source. All I/O signals should have VIH reference to VDDIO. When I/O signal pins (BS0~BS1, D0~D7, control signals…) pull high, they should be connected to VDDIO. Power Supply for Core Logic Circuit 25 VDD P 26 VCI P This is a voltage supply pin. It can be supplied externally (within the range of 2.4~2.6V) or regulated internally from VCI. A capacitor should be connected between this pin & VSS under all circumstances. Power Supply for Operation This is a voltage supply pin. It must be connected to external source & always be equal or higher than VDD & VDDIO. Voltage Output Low Level for SEG Signal This is segment voltage reference pin. When external VSL is not used, this pin should be left open. When external VSL is used, this pin should connect with resistor and diode to ground. 27 VSL P 28 VLSS P This is the analog ground pin. It should be connected to VSS externally 29 VCC I This is the most positive supply pin of the chip. This should be connected to external source. 30 N.C. (GND) - Product No. Ground of Analog Circuit Power Supply for OEL Panel Reserved Pin (Supporting Pin). The supporting pins can reduce the influences from stresses on the function pins. This pin must be connected to external ground. DD-25664BE-3A REV. B Page 10 / 27 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 3.4 BLOCK DIAGRAM MCU Interface Selection: BS0 and BS1 Pins connected to MCU interface: D7~D0, E/RD#, R/W#, D/C#, CS#, and RES# C1, C3, C5: 0.1μF C2, C4: 4.7μF C6: 10μF C7: 1μF C8: 4.7uF / 25V Tantalum Capacitor R1: 680kΩ, R1 = 680kΩ, R1= (Voltage at IREF – VSS) / IREF R2: 50Ω, 1/4W D1: ≤1.4V, 0.5W Product No. DD-25664BE-3A REV. B Page 11 / 27 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 3.5 TIMING CHARACTERISTICS 3.5.1 68XX-Series MPU Parallel Interface Timing Characteristics: Symbol Description Min Max Unit tcycle 300 10 - ns tAS Clock Cycle Time Address Setup Time - ns tAH Address Hold Time 0 - ns tDSW Write Data Setup Time 40 - ns tDHW Write Data Hold Time 7 - ns tDHR Read Data Hold Time 20 - ns tOH Output Disable Time - 70 ns tACC Access Time - 140 ns PWCSL Chip Select Low Pulse Width (Read) Chip Select Low Pulse Width (Write) 120 60 - ns PWCSH Chip Select High Pulse Width (Read) Chip Select High Pulse Width (Write) 60 60 - ns tR Rise Time - 15 ns tF Fall Time - 15 ns (VDD-VSS = 2.4V to 2.6V, VDDIO = 1.6V, VCI = 2.8V, Ta = 25°C) Product No. DD-25664BE-3A REV. B Page 12 / 27 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 3.5.2 80XX-Series MPU Parallel Interface Timing Characteristics: Symbol Description Min Max Unit 300 10 - ns tAS Clock Cycle Time Address Setup Time - ns tAH Address Hold Time 0 - ns tDSW Write Data Setup Time 40 - ns tDHW Write Data Hold Time 7 - ns tDHR Read Data Hold Time 20 - ns tOH - 70 140 ns tACC Output Disable Time Access Time ns tPWLR Read Low Time 150 - ns tPWLW Write Low Time 60 - ns tPWHR Read High Time Write High Time 60 60 - ns - ns Chip Select Setup Time 0 - ns Chip Select Hold Time to Read Signal Chip Select Hold Time 0 - ns 20 - ns tcycle tPWHW tCS tCSH tCSF tR Rise Time - 15 ns tF Fall Time - 15 ns (VDD-VSS = 2.4V to 2.6V, VDDIO = 1.6V, VCI = 2.8V, Ta = 25°C) Product No. DD-25664BE-3A REV. B Page 13 / 27 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 3.5.3 Serial Interface Timing Characteristics: (4-wire SPI) Symbol Description Min Max Unit 100 15 - ns tAS Clock Cycle Time Address Setup Time - ns tAH Address Hold Time 15 - ns tCSS 20 10 - ns tCSH Chip Select Setup Time Chip Select Hold Time - ns tDSW Write Data Setup Time 15 - ns tDHW Write Data Hold Time 15 - ns tCLKL Clock Low Time 20 - ns tCLKH Clock High Time 20 - ns tcycle tR Rise Time - 15 ns tF Fall Time - 15 ns (VDD-VSS = 2.4V to 2.6V, VDDIO = 1.6V, VCI = 2.8V, Ta = 25°C) Product No. DD-25664BE-3A REV. B Page 14 / 27 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 3.5.4 Serial Interface Timing Characteristics: (3-wire SPI) Symbol Description Min Max Unit 100 15 - ns tAS Clock Cycle Time Address Setup Time - ns tAH Address Hold Time 15 - ns tCSS 20 10 - ns tCSH Chip Select Setup Time Chip Select Hold Time - ns tDSW Write Data Setup Time 15 - ns tDHW Write Data Hold Time 15 - ns tCLKL Clock Low Time 20 - ns tCLKH Clock High Time 20 - ns tcycle tR Rise Time - 15 ns tF Fall Time - 15 ns (VDD-VSS = 2.4V to 2.6V, VDDIO = 1.6V, VCI = 2.8V, Ta = 25°C) Product No. DD-25664BE-3A REV. B Page 15 / 27 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 4 OPTICAL SPECIFICATION 4.1 OPTICAL CHARACTERISTICS Characteristics Symbol Conditions Min Typ Brightness Lbr With Polarizer (Note 3) 60 80 - C.I.E. (Yellow) (x) (y) Without Polarizer 0.12 0.22 0.16 0.26 0.20 0.30 Dark Room Contrast CR - >2000:1 - >160 - - View Angle Max Unit cd/m2 degree Note 3: Optical measurement taken at VCI = 2.8V, VCC = 12V Product No. DD-25664BE-3A REV. B Page 16 / 27 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 5 FUNCTIONAL SPECIFICATION 5.1 COMMANDS Refer to the Technical Manual for the SSD1322 5.2 POWER DOWN AND UP SEQUENCE To protect the panel and extend the panel life time, the driver IC power up/down routine should include a delay period between high voltage and low voltage power sources during turn on/off. Such that panel has enough time to charge and discharge before/after operation. 5.2.1 Power up Sequence: 1. Power up VCI & VDDIO 2. Send Display off command 3. Initialization 4. Clear Screen 5. Power up VCC 6. Delay 100ms (when VCC is stable) 7. Send Display on command 5.2.2 Power down Sequence: 1. Send Display off command 2. Power down VCC 3. Delay 100ms (when VCC is reach 0 and panel is completely discharges) 4. Power down VCI & VDDIO 5.3 RESET CIRCUIT When RES# input is low, the chip initialized with the following status: 1. Display is OFF 2. 480x128 Display Mode 3. Normal segment and display data column and row address mapping (SEG0 mapped to column address 00h and COM0 mapped to row address 00h) 4. Display start line is set at display RAM address 0 5. Column address counter is set at 0 6. Normal scan direction of the COM outputs 7. Contrast control registers is set at 7Fh Product No. DD-25664BE-3A REV. B Page 17 / 27 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 5.4 ACTUAL APPLICATION EXAMPLE Command usage and explanation of an actual example If the noise is accidentally occurred at the displaying window during the operation, please reset the display in order to recover the display function. Product No. DD-25664BE-3A REV. B Page 18 / 27 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 6 PACKAGING 6.1 LABELLING AND MARKING DENSITRON DD-25664BE-3A TW YYMM Product No. DD-25664BE-3A REV. B Page 19 / 27 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 7 QUALITY ASSURANCE SPECIFICATION 7.1 CONFORMITY The performance, function and reliability of the shipped products conform to the Product Specification. 7.2 DELIVERY ASSURANCE 7.2.1 Delivery inspection standards • IPC-AA610 rev. C, class 2 electronic assemblies standard 7.2.2 Zone definition A Viewing area B Outside viewing area Product No. DD-25664BE-3A REV. B Page 20 / 27 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 7.2.3 Visual inspection • • • • Inspect under 30W fluorescent lamp leaving 50 cm between the module and the lamp and 30 cm between the module and the eye (measuring position). Appearance is inspected at the best contrast voltage (best contrast is adjusted considering clearness and crosstalk on screen). Inspect the module at 45° right and left, top and bottom. Use the optimum viewing angle during the contrast inspection. eye 45° Product No. DD-25664BE-3A 45° REV. B Page 21 / 27 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 7.2.3.1 Standard of appearance inspection Units: mm Class Item Criteria Minor Critical Packing & Label Major Dimension Outside & inside package Presence of product no., lot no., quantity Product must not be mixed with others and quantity must not be different from that indicated on the label Product dimensions must be according to specification and drawing Major Electrical Product electrical characteristics must be according to specification Critical LCD Display Black spot, white spot, dust Minor Missing lines or wrong patterns on LCD display are not allowed Round type: as per following drawing ∅ = (X+Y)/2 Y X Size ∅
DD-25664BE-3A 价格&库存
很抱歉,暂时无法提供与“DD-25664BE-3A”相匹配的价格&库存,您可以联系我们找货
