2711XG1.5
2711XG1.5
    VISUALUX
2711XG1.5 数据手册
Visualux (edge lit) Backlights Specification for the Visualux Backlight body (Light Guide) Mechanical Properties: Tensile Strength Compressive Strength Flexural Strength Impact Strength Modules of elasticity Elongation at break Indentation hardness Test Unit Values DIN 53455 DIN 53454 DIN 53452 DIN 53453 DIN 53457 DIN 53455 DIN 53456 N/mm2 N/mm2 N/mm2 kJ/m2 N/mm2 % N/mm2 65-68 125 120 12 3,000 4 175 Thermal Properties: Heat Stability - Vicat B Forming temperature Coefficient of linear thermal expansion Specific heat Thermal conductivity o DIN 53460 C C 105 150-170 mm/moC. 0.08 kJ/kgoC. W/moC. 1.46 0.19 DIN 53481 DIN 53482 DIN 53483 DIN 53483 kV/mm. ohm x cm. 40 1015 3.4 0.06 DIN 53472 at 20oC.in 24 hrs. 4500 A g/cm2 % % 1.2 0.17 92 o VDE 0304/1 Electrical Properties: Dielectric strength Volume resistively Dielectric constant, 103 Hz. Dissipation factor, 50 Hx. Other Properties: Specific gravity Water absorption Light transmission N. B. See seperate graph for light transmission Visualux Ltd Tel: +44 (0)1271 865865 Fax: +44 (0)1271 865830 E-Mail: sales@visualux.com Page 6 Grey 2711
2711XG1.5 价格&库存
很抱歉,暂时无法提供与“2711XG1.5”相匹配的价格&库存,您可以联系我们找货
