111-507
111-507
    SPELSBERG
111-507 数据手册
EMPTY ENCLOSURE TK PS 1818-11-to TK PS 1818-11-to Empty enclosure CUSTOMIZABLE 182 x 180 x 111 mm Article number: 11150701 Empty enclosure, base: polystyrene, grey, similar to RAL 7035, cover: polycarbonate, transparent without knockouts Technical data Accessory ASS-gro - External hinge set Measures HBA - Mounting material Width: 182 mm MPS-KRI - Mounting plate Length: 180 mm NS 35-144 - Mounting rail Height: 111 mm TK ABL - External fixing lugs kit 97 mm TK MPI-1818 - Mounting plate Inner height: Material Base: Cover: Sealing: Cover screw: Environmental attributes Polystyrene, grey, similar to RAL 7035 Polycarbonate, transparent Polyurethane Polyamide 6, fiberglass reinforced Ambient temperature (min.): -25 °C Ambient temperature (max.): 40 °C Ambient temperature (24 h): 35 °C Max. rel. humidity at 25° C (short Therm): 95% Max. rel. humidity at 40° C: 50% Created on 2015-01-26. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved. Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299 Page 1 of 2 Powered by TCPDF (www.tcpdf.org) EMPTY ENCLOSURE TK PS 1818-11-to Other attributes Ingress protection: IP66 - acc. EN 60529 / DIN VDE 0470-1 Impact resistance: IK07 acc. DIN EN 5012 / VDE 0470 Part 100 Protection class: II - isolate protection acc. VDE 0106 Rated insulation voltage AC: 690V V Rated insulation voltage DC: 1000 V Heavy metals-free: Yes PVC-free: Yes Silicone-free: Yes Fitted for outdoor application: No Combustion behaviour to UL: Combustion behaviour to VDE: HB acc. UL94 650°C acc. VDE 0471/ EN 60695 sealable: Yes Weatherproof: No Knockouts: No Created on 2015-01-26. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved. Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299 Page 2 of 2
111-507 价格&库存
很抱歉,暂时无法提供与“111-507”相匹配的价格&库存,您可以联系我们找货
