H320BL
H320BL
    HUBBELL(哈伯尔公司)
H320BL 数据手册
Straight Blade Devices Straight Blade Devices 16 Ampere, 250 Volts AC International 2 Pole, 3 Wire Grounding 20 Ampere, 250 Volts AC North American Rated IEC 320 Appliance Couplers 1.52" (38.6) 2.75" (69.9) IP20 1.36" (34.5) SUITABILITY Plug IEC 320 Compatible Description 20/16A 250V AC IEC straight blade. Catalog Numbers H320P H320P .22" (5.6) 1.47" (37.3) 1.19" (30.2) 1.28" (32.5) 1.64" (41.7) Inlets Description 20/16A 250V AC IEC straight blade. 20/16A 250V AC IEC straight blade with retention clamp. H320B Catalog Numbers H320B H320BL 1.28" (32.5) 1.47" 1.19" (37.3) (30.2) .22" (5.6) Connector H320BL Description 20/16A 250V AC IEC straight blade. SUITABILITY Catalog Numbers H320C 1.42" (36.1) 1.95" (49.5) 16 Ampere, 250 Volts AC International IP20 1.64" (41.7) .41" (10.4) H320C Receptacle IEC 320 Compatible 1.55" (39.4) 1.41" (35.8) 1.52" (38.6) Description 20/16A 250V AC IEC straight blade. For Ring Terminal connection. Note: See page A-59 for technical information. †Not UL Listed. Catalog Numbers H320R H320RRT† 1.89" (48.0) H320R A-34 www.hubbell-wiring.com Dimensions in Inches (mm)
H320BL 价格&库存
很抱歉,暂时无法提供与“H320BL”相匹配的价格&库存,您可以联系我们找货
