9001037-4
9001037-4
    MEILHAUS
9001037-4 数据手册
Tested High Quality GPIB Cable Accessories, Software ME-GPIB Cable - Robust, Light, EMV Compliant  30°   Tested GPIB/IEEE488 bus quality cable for EMV compliant, low noise connectivity.  High noise-immunity with multiple shielding.  Reliable transmission with twisted-pair lines.  Robust and light with high quality piggy-back connectors with aluminum housing.  Multiple length available from 0.5 to 20 m.  For flexible use available with • standard connectors . • cable access at a 30° angle . • straight cable access on one side (similar to D-sub connector types) . Helps you to access GPIB connectors which are difficult to reach with standard connectors, for example interface boards in PC slots or measurement instruments in a rack cabinet.  30° cable access of the DeLuxe series  Outer jacket Isolation Shield/braiding with tracer wire Shield/plastic foil Handshake lines* with tracer Isolation foil Shield/braiding with tracer wire Isolation foil Isolation foil Data lines* with tracer  *twisted-pair Models and Ordering Codes: Length Series 900.103.7 : ME Code Series “DeLuxe” : Agilent Similar Type National Instruments Similar Type 0.5 m 900.103.7-0.5 10833D 763061-005 1m 900.103.7-1 10833A 763061-01 2m 900.103.7-2 10833B 763061-02 3m 900.103.7-3 4m 900.103.7-4 10833C 763061-03 6m 900.103.7-6 8m 900.103.7-8 763061-04 10 m 900.103.7-10 12 m 900.103.7-12 15 m 900.103.7-15 20 m 900.103.7-20 Note: Interesting discounts for orders of more than 10, 50 or 100 cables available on request! ME Code IEEE488 DeLuxe 0.5 IEEE488 DeLuxe 1 IEEE488 DeLuxe 2 IEEE488 DeLuxe 4 IEEE488 DeLuxe 8 IEEE488 DeLuxe 10 IEEE488 DeLuxe 12 IEEE488 DeLuxe 20 Series with Straight Cable Access : ME Code 12401.05 12401.1 12401.2 12401.4 - Web Link: www.meilhaus.com/e_me www.meilhaus.com MEsurement starts with ME. 73
9001037-4 价格&库存
很抱歉,暂时无法提供与“9001037-4”相匹配的价格&库存,您可以联系我们找货
