09.03201.02
09.03201.02
    EOZ
    SIP
09.03201.02 数据手册
1K2 A1 COMPONENTS Recommended for all PCB applications as the most compact changeover switch on the market, the 1K2 is ideal as a jumper replacement. A standard (red) or extended (black) slide actuator gives instant recognition of switch position. Electrical life 1 000 operations • Resistance to wave soldering at 250° C, 5 sec. • Choice of straight or right angle PCB mounting • Saline mist 24 hours, 96 hours (tropicalised version), • Damp heat 4 days, 21 days (tropicalised version), • Electrical life 1 000 operations • Cursor position TECHNICAL SPECIFICATIONS ELECTRICAL SPECIFICATIONS Nominal Curent 500 mA Minimum Curent 1 mA Nominal Voltage 12 V Maximum Voltage 24 V Minimum Voltage 10 mV DIMENSIONS Electrostatic breakdown value 5 kV Isolation resistance ≥10000 MΩ at 100Vdc Contact resistance ≤22 Ω Electrical life 1000 actuations Electric strength as per EN IEC 60512-2 250 Vrms, 50 Hz, 1 min Pins axial (standard version), Red plastic slider Right-angles bented pins (standard version) Red plastic slider Pins axial (standard version), Black raised plastic Right-angles bented pins (standard version) Black raised plastic slider MECHANICAL CHARACTERISTICS Switching action Maintained Actuating travel 1.6 mm Operating temperature Shock resistance as per IEC 60512-4-6c -40°C ... +85°C Environnemental resistance - Damp heat as per EN IEC 60512-11f Standard «Gold cont.» Tropical «Gold cont.» 4 days 21 days 24 hours 96 hours - Saline mist as per EN IEC 60512-11f 50 g, 11 ms Manual spot welding guideline The 1K2 is designed for machine wave flow soldering. If manual soldering needs to be done, the following guidelines have to be adhered to (in accordance to IEC 60068-2-20): Size of tip of soldering iron: 3mm dia. • Type of solder: Sn/Ag/Cu • Soldering temperature: 350°C at 370°C • Soldering time: 1s at 5s max • In order to avoid overheating, a small break has to be observed between each solder-application • The soldering iron has to be kept clean at all times. • It is mandatory to tin the tip of the soldering iron before the soldering can take place. • When soldering, the tip of the iron has to first pre-heat the «intersection» between pin and circuit, before applying the solder. STANDARD PART NUMBERS Change-over slide switch 1-pole Part Numbers 09.03290.01 Pins axial (standard version), plastic black raised slider 09.03201.02 Pins axial (standard version), plastic red slider Pins axial (3 mm), plastic black raised slider 09.03290.01X116 Pins axial (3 mm), plastic red slider 09.03201.02X115 Pins axial (tropicalised version), plastic red slider 19.03201.01 Pins bent at right-angles (standard version) plastic black raised slider 09.10290.01 Pins bent at right-angles (standard version) plastic red slider 09.10201.02 Further options and information available: www.eozonline.com CONNEXIONS MOUNTING
09.03201.02 价格&库存
很抱歉,暂时无法提供与“09.03201.02”相匹配的价格&库存,您可以联系我们找货
