AA1281LB-AT
AA1281LB-AT
    ADDA(協禧電機)
AA1281LB-AT 数据手册
ADDA USA AC FAN SPECIFICATIONS Frame Size Model Part No. Bearing Type 80 X 80 X 25 AA8251MB-AT(AW) B,S,or X 80 X 80 X 25 AA8252MX-AT(AW) B,S,or X 80 X 80 X 38 AA8381HS-AT(AW) B,S,or X 80 X 80 X 38 AA8381MS-AT(AW) B,S,or X 80 X 80 X 38 AA8382HS-AT(AW) B,S,or X 80 X 80 X 38 AA8382MS-AT(AW) B,S,or X 92 X 92 X 25 AA9251MS-AT(AW) B,S,or X 92 X 92 X 25 AA9252MB-AT(AW) B,S,or X 120 X 120 X 25 AA1251MS-AT(AW) B,S,or X 120 X 120 X 25 AA1252MS-AT(AW) B,S,or X 120 X 120 X 38 AA1281UX-AW(AW) B,S,or X 120 X 120 X 38 AA1281HB-AT(AW) B,S,or X 120 X 120 X 38 AA1282UX-AT(AW) B,S,or X 120 X 120 X 38 AA1282HB-AT(AW) B,S,or X 120 X 120 X 38 AA1281HX-AT(AW) B,S,or X 120 X 120 X 38 AA1281MX-AT(AW) B,S,or X 120 X 120 X 38 AA1281LX-AT(AW) B,S,or X 120 X 120 X 38 AA1281DX-AT(AW) B,S,or X 120 X 120 X 38 AA1282HX-AT(AW) B,S,or X 120 X 120 X 38 AA1282MX-AT(AW) B,S,or X 120 X 120 X 38 AA1282LX-AT(AW) B,S,or X 120 X 120 X 38 AA1282DX-AT(AW) B,S,or X 172 X 150 X 50 AA1751HB-AT(AW) B,S,or X 172 X 150 X 50 AA1751MB-AT(AW) B,S,or X 172 X 150 X 50 AA1752HB-AT(AW) B,S,or X 172 X 150 X 50 AA1752MB-AT(AW) B,S,or X Input Volt. / Freq (V/Hz) Current (A) Power (W) Speed (RPM) Air Flow (CFM) Pressure (mmAq) 115/50 115/60 230/50 230/60 115/50 115/60 115/50 115/60 230/50 230/60 230/50 230/60 115/50 115/60 230/50 230/60 115/50 115/60 230/50 230/60 115/50 115/60 115/50 115/60 230/50 230/60 230/50 230/60 115/50 115/60 115/50 115/60 115/50 115/60 115/50 115/60 230/50 230/60 230/50 230/60 230/50 230/60 230/50 230/60 115/50 115/60 115/50 115/60 230/50 230/60 230/50 230/60 0.15 0.13 0.07 0.06 0.13 0.1 0.08 0.07 0.07 0.06 0.05 0.05 0.15 0.13 0.07 0.06 0.22 0.19 0.11 0.1 0.33 0.27 0.25 0.2 0.17 0.13 0.12 0.1 0.25 0.2 0.25 0.21 0.14 0.13 0.12 0.11 0.12 0.1 0.1 0.09 0.07 0.07 0.06 0.06 0.48 0.43 0.35 0.34 0.27 0.23 0.19 0.19 17.3 14.9 16.1 13.8 8.98 6.75 5.42 4.61 8.8 6.8 6.8 5.7 17.3 14.9 16.1 13.8 23 19.6 20.7 18.4 25.82 21.43 16.3 14.2 25.61 20.96 16 14 16.28 14.21 15.76 13.74 9.21 8.86 8.24 7.89 16 14 13.7 12.6 9.9 9.4 8 7.6 59.6 39.3 29.8 29.3 47.9 38.4 32.6 29.9 1900 2500 1850 2450 2300 2800 2300 2400 2300 2800 2300 2400 1650 2150 1650 2150 2050 2400 2050 2400 2500 2800 2400 2500 2500 2800 2400 2500 2600 2900 2500 2700 2400 2100 2300 1650 2600 2900 2500 2700 2400 2100 2300 1650 2700 3000 2600 2500 2700 3000 2600 2500 14.6 18.9 14.6 18.9 24 29.6 24 25.1 24 29.6 24 25.1 22.8 29.1 22.8 29.1 61 69.4 61 69.4 100.2 110 92.6 100.2 100.2 110 92.6 100.2 83 93 81.5 86.4 75.9 63.8 73.5 51.4 83 93 81.5 86.4 75.9 63.8 73.5 51.4 194.6 218.2 186 177.4 196 217.7 185.3 178.6 1.5 2.75 1.5 2.75 2.73 4.17 2.73 3.04 2.73 4.17 2.73 3.04 1.15 1.83 1.15 1.83 3.23 3.85 3.23 3.85 0.24 0.21 4.8 4.55 0.24 0.21 4.8 4.55 0.28 0.25 0.24 0.15 0.17 0.08 0.14 0.06 0.28 0.25 0.24 0.15 0.17 0.08 0.14 0.06 12.75 7.75 9.25 3.5 12.25 7.25 9 3.25 NOTE B=Ball S=Sleeve X= Hypro AT= Terminals AW= Wires ADDA USA ALL RIGHTS RESERVED Noise Weight (dB/A) (g) 18.3 24 18.3 24 25.3 31.6 25.3 26.2 25.3 31.6 25.3 25.3 21.1 26.8 21.1 26.8 38.7 44.1 38.7 44.1 45.8 48.3 43.5 44.9 45.8 48.3 43.5 44.9 42.2 44.5 40 41 40.1 37.9 39.2 30.5 42.2 44.5 40 41 40.1 37.9 39.2 30.5 52.3 54.7 50.5 48.8 51.3 53.9 50.4 48.9 191 191 309 309 309 309 220 220 339 339 545 545 545 545 547 547 547 547 547 547 547 547 922 922 922 922 Connection Type Terminal or Lead Wires Terminal or Lead Wires Terminal or Lead Wires Terminal or Lead Wires Terminal or Lead Wires Terminal or Lead Wires Terminal or Lead Wires Terminal or Lead Wires Terminal or Lead Wires Terminal or Lead Wires Terminal or Lead Wires Terminal or Lead Wires Terminal or Lead Wires Terminal or Lead Wires Terminal or Lead Wires Terminal or Lead Wires Terminal or Lead Wires Terminal or Lead Wires Terminal or Lead Wires Terminal or Lead Wires Terminal or Lead Wires Terminal or Lead Wires Terminal or Lead Wires Terminal or Lead Wires Terminal or Lead Wires Terminal or Lead Wires Safety Approvals Units Per Box Wt Box (LBS.) CE 200 91 CE 200 91 UL,CUL,TUV,CE 60 55 UL,CUL,TUV,CE 60 55 UL,CUL,TUV,CE 60 55 UL,CUL,TUV,CE 60 55 CE 200 55 CE 200 55 UL,CUL,CE 90 75 UL,CUL,CE 90 75 CE 40 55 CE 40 55 CE 40 55 CE 40 55 UL,CUL,TUV,CE 40 55 UL,CUL,TUV,CE 40 55 UL,CUL,TUV,CE 40 55 UL,CUL,TUV,CE 40 55 UL,CUL,TUV,CE 40 55 UL,CUL,TUV,CE 40 55 UL,CUL,TUV,CE 40 55 UL,CUL,TUV,CE 40 55 UL,CUL,CE 20 47.3 UL,CUL,CE 20 47.3 UL,CUL,CE 20 47.3 UL,CUL,CE 20 47.3 All specifications subject to change without notice.
AA1281LB-AT 价格&库存
很抱歉,暂时无法提供与“AA1281LB-AT”相匹配的价格&库存,您可以联系我们找货
