302-STB-DS/02
302-STB-DS/02
    WECO(威克德诺)
    P=8mm
    接线端子 间距P=8.00mm 2Pin(2x2P)
302-STB-DS/02 数据手册
TECHNICAL DATA SHEET 302-STB(-DS) Plug-in terminal strip Screw connection & socket GENERAL INFORMATION Pitch No. of poles Usable with Areas of application 8 mm 2 - 12 302-STS(-DS) This terminal strip is well suited for applications that require to easily open and close not energised circuits. TECHNICAL DATA Clamping Range without wire protector with wire protector Rated Cross Section Wire Stripping Length MATERIAL solid / stranded / AWG 0,5 - 4 mm² / 0,5 - 2,5 mm² / 20 - 12 AWG 0,34 - 2,5 mm² / 0,34 - 1,5 mm² / 22 - 14 AWG 1,5 mm² 6 mm ± 0,5 mm Overvoltage Category Pollution Severity Level Rated Voltage Rated Impulse Voltage Rated Insulation Voltage Rated Current Torque Other specifications III 3 200 V 4 kV III 2 320 V 4 kV II 2 630 V 4 kV 450 V acc. to EN 60998-1 6A 0,4 Nm Rated values apply to use in combination with 302-STS(-DS) and without insulated substrates. APPROVALS Current [A] Voltage [V] Group AWG [Nm] 6 300 B,D 20 - 14 0,4 10 300 B,D,E 26 - 12 0,4 [1] Moulding Comparative Tracking Index Insulating Group Temperature Range Terminal body Screw Wire protector PA, natural, V-2 CTI ≥ 600 I -40°C up to 100°C Nickel plated brass M2,6; zinc plated steel, blue passivated Tin plated tin bronze OPTIONS / ACCESSORIES • • • • • • Marking options on the screw guides Jumper 302-J Moulding made of special polyamide for e.g. household appliances Screws made out of brass Leading socket for the protective conductor pole With pegs at the base for saving assembly time [1] for 302-STB-DS: 26 - 14 AWG CONFIGURATIONS Version Standard Standard Standard Standard Standard Standard Standard Standard Standard Standard Standard Poles Item 2 3 4 5 6 7 8 9 10 11 12 302-STB/02 302-STB/03 302-STB/04 302-STB/05 302-STB/06 302-STB/07 302-STB/08 302-STB/09 302-STB/10 302-STB/11 302-STB/12 Article number Item Article number 32.820.009 33.820.009 34.820.009 35.820.009 36.820.009 37.820.009 38.820.009 39.820.009 40.820.009 41.820.009 42.820.009 302-STB-DS/02 302-STB-DS/03 302-STB-DS/04 302-STB-DS/05 302-STB-DS/06 302-STB-DS/07 302-STB-DS/08 302-STB-DS/09 302-STB-DS/10 302-STB-DS/11 302-STB-DS/12 52.820.009 53.820.009 54.820.009 55.820.009 56.820.009 57.820.009 58.820.009 59.820.009 60.820.009 61.820.009 62.820.009 Length (L) 15,00 mm 23,00 mm 31,00 mm 39,00 mm 47,00 mm 55,00 mm 63,00 mm 71,00 mm 79,00 mm 87,00 mm 94,00 mm PU 1000 1000 500 500 80 60 70 60 40 40 40 01.23 C3.11
302-STB-DS/02 价格&库存
很抱歉,暂时无法提供与“302-STB-DS/02”相匹配的价格&库存,您可以联系我们找货
302-STB-DS/02
  • 1+4.69800
  • 10+4.19040
  • 30+3.94200
  • 100+3.68280
  • 500+3.54240
库存:910
302-STB-DS/02
    • 1+5.26350
    • 10+4.69480
    • 30+4.41650
    • 100+4.12610
    • 500+3.96880
    库存:999
