323-STFB-DS/03
323-STFB-DS/03
    WECO(威克德诺)
    P=10mm
    接线端子 间距P=10.00mm 3Pin
323-STFB-DS/03 数据手册
TECHNICAL DATA SHEET 323-STFB(-DS) Plug-in terminal strip Screw connection & socket GENERAL INFORMATION Pitch No. of poles Usable with Areas of application 10 mm 2 - 12 322-STFS(-DS) Applications that require to easily open and close not energised circuits. MATERIAL TECHNICAL DATA Clamping Range without wire protector with wire protector Rated Cross Section Wire Stripping Length solid / stranded / AWG 0,75 - 6 mm² / 0,75 - 4 mm² / 18 - 10 AWG 0,5 - 4 mm² / 0,5 - 2,5 mm² / 20 - 12 AWG 2,5 mm² 6 mm ± 0,5 mm Overvoltage Category Pollution Severity Level Rated Voltage Rated Impulse Voltage Rated Insulation Voltage Rated Current Torque Other specifications III 3 400 V 6 kV III 2 630 V 6 kV II 2 630 V 6 kV 450 V acc. to EN 60998-1 [1] 16 A 0,5 Nm Rated values apply to use in combination with 322-STFS(-DS) and insulated substrates. Moulding Comparative Tracking Index Insulating Group Temperature Range Terminal body Screw Wire protector Spring PA, natural, V-2 CTI ≥ 600 I -40°C up to 100°C Nickel plated brass M3; zinc plated steel, blue passivated Tin plated tin bronze Stainless steel strip OPTIONS / ACCESSORIES • Marking options on and between the screw guides • Jumper 323-J • Leading terminal body for the protective conductor pole [1] with insulating base [2] for 323-STFB-DS: 26 - 12 AWG APPROVALS Current [A] Voltage [V] Group AWG [Nm] 15 10 300 300 B D,E 26 - 10 26 - 10 0,51 [2] 0,51 [2] CONFIGURATIONS Version Standard Standard Standard Standard Standard Standard Standard Standard Standard Standard Standard Poles Item 2 3 4 5 6 7 8 9 10 11 12 323-STFB/02 323-STFB/03 323-STFB/04 323-STFB/05 323-STFB/06 323-STFB/07 323-STFB/08 323-STFB/09 323-STFB/10 323-STFB/11 323-STFB/12 Article number Item Article number Length (L) 32.822.012 33.822.012 34.822.012 35.822.012 36.822.012 37.822.012 38.822.012 39.822.012 40.822.012 41.822.012 42.822.012 323-STFB-DS/02 323-STFB-DS/03 323-STFB-DS/04 323-STFB-DS/05 323-STFB-DS/06 323-STFB-DS/07 323-STFB-DS/08 323-STFB-DS/09 323-STFB-DS/10 323-STFB-DS/11 323-STFB-DS/12 52.822.011 53.822.011 54.822.011 55.822.011 56.822.011 57.822.011 58.822.011 59.822.011 60.822.011 61.822.011 62.822.011 18,00 mm 28,00 mm 38,00 mm 48,00 mm 58,00 mm 68,00 mm 78,00 mm 88,00 mm 98,00 mm 108,00 mm 118,00 mm PU 430 650 870 1080 1300 1500 1700 60 50 50 50 08.23 C3.11
323-STFB-DS/03 价格&库存
很抱歉,暂时无法提供与“323-STFB-DS/03”相匹配的价格&库存,您可以联系我们找货
323-STFB-DS/03
  • 1+10.56240
  • 10+9.68760
  • 30+9.13680
库存:225
