140-A-126-SMD/02
140-A-126-SMD/02
    WECO(威克德诺)
    SMD,P=5mm
    接线端子 1x2P 5mm 立贴 排数:单排 每排Pin数:2
140-A-126-SMD/02 数据手册
TECHNICAL DATA SHEET 140-A-126-SMD PCB connector for SMD Screw connection, with solder flanges GENERAL INFORMATION Pitch No. of poles Areas of application 5 mm 2-8 Systems for measurement and control PCB LAYOUT TECHNICAL DATA Clamping Range Rated Cross Section Wire Stripping Length Overvoltage Category Pollution Severity Level Rated Voltage Rated Impulse Voltage solid / stranded / AWG 0,14 - 2,5 mm² / 0,14 - 1,5 mm² / 26 - 16 AWG 1,5 mm² 6 mm ± 0,5 mm III 3 200 V 4 kV III 2 320 V 4 kV II 2 500 V 4 kV Solder paste thickness: 0,2 mm MATERIAL 250 V acc. to EN 60998-1 16 A Reflow solder 0,5 Nm Moulding Comparative Tracking Index Insulating Group Temperature Range Current [A] Voltage [V] Group AWG [Nm] 10 [1] 300 B, D 30 - 14 0,51 Terminal body Pressure clamp Screw Solder pin Solder cylinder 15 300 B 30 - 14 0,51 Rated Insulation Voltage Rated Current Soldering process Torque APPROVALS PA HT, black, V-0 CTI ≥ 600 I -40°C up to 120°C; reflow solder temperature peak max. 255°C acc. to DIN EN 61760-1 Nickel plated brass Tin plated tin bronze M3; zinc plated steel, blue passivated 0,9 x 0,5 mm; tin plated tin bronze Tin plated brass OPTIONS / ACCESSORIES • Consecutive numbering • Special marking according to drawing • Self-adhesive marking strip BST-5,00 [2] [1] 20 A max for factory-wiring applications only [2] To be fitted after reflow soldering process CONFIGURATIONS Poles Part number 2 3 4 5 6 2 3 4 5 6 140-A-126-SMD/02 140-A-126-SMD/03 140-A-126-SMD/04 140-A-126-SMD/05 140-A-126-SMD/06 140-A-126-SMD/02-T&R 140-A-126-SMD/03-T&R 140-A-126-SMD/04-T&R 140-A-126-SMD/05-T&R 140-A-126-SMD/06-T&R Article number 20.801.632 20.801.633 20.801.634 20.801.635 20.801.636 20.801.632.A00 20.801.633.A00 20.801.634.A00 20.801.635.A00 20.801.636.A00 Length (L) 10,00 mm 15,00 mm 20,00 mm 25,00 mm 30,00 mm 10,00 mm 15,00 mm 20,00 mm 25,00 mm 30,00 mm Packaging PU Box Box Box Box Box Tape-on-Reel Tape-on-Reel Tape-on-Reel Tape-on-Reel Tape-on-Reel 784 616 504 420 364 375 375 375 375 375 Tape Width Tape Height 32 mm 56 mm 56 mm 56 mm 56 mm 13 mm 13 mm 13 mm 13 mm 13 mm further number of poles on request 11.17 WECO Electrical Connectors Inc., 18050 Trans-Canada Highway, Kirkland, Québec, Canada, H9J 4A1 Phone: 800.724.2928 | Phone: 514.694.9136 | Fax: 514.694.0956 weco@wecoconnectors.com © Copyright by WECO All rights reserved. WECO® is a brand of the WECO Group. Information provided in this document may be changed without prior notice. Please refer to our website for the full disclaimer.
140-A-126-SMD/02 价格&库存
很抱歉,暂时无法提供与“140-A-126-SMD/02”相匹配的价格&库存,您可以联系我们找货
