Plug connector
950-FL-DS
Screw connection
General Information
Pitch
5 mm
No. of poles
2 - 24
Usable with
pin strips of series 971
Technical Data
Clamping Range
solid / flexible / AWG
0,34 - 2,5 mm² / 0,34 - 1,5 mm² / 22 - 14 AWG
The plug connector 950-FL-DS is designed to be joined with pin strips of the series
971 from either the top or the bottom side. Through the use of oversized pins
(available upon request) a parallel connection can be made with stacked
connectors.
Among other things these plug connector, which produced with a nominal centre to
centre spacing can be placed adjacently on pin strips without pole loss.
The use of these components provides also a number of other advantages such as
ease of isolation for service, the decentralized production of components or the
ease of connection in confined space.
Part Numbers
No. of
poles
950-FL-DS
Length
Pcs
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20.871.733
20.871.734
20.871.735
20.871.736
20.871.737
20.871.738
20.871.739
20.871.740
20.871.741
20.871.742
20.871.743
20.871.744
20.871.745
20.871.746
20.871.747
20.871.748
20.871.749
20.871.750
10,00
15,00
20,00
25,00
30,00
35,00
40,00
45,00
50,00
55,00
60,00
65,00
70,00
75,00
80,00
85,00
90,00
95,00
100,00
250
250
250
100
100
100
100
100
50
50
50
50
50
50
50
50
50
25
25
21
20.871.751
105,00
25
22
23
24
20.871.752
20.871.753
20.871.754
110,00
115,00
120,00
25
25
25
Rated Cross Section
1,5 mm²
Wire Stripping Length
6 mm ± 0,5 mm
Overvoltage Category
III
III
II
Pollution Severity Level
3
2
2
Rated Voltage
320 V
320 V
630 V
Rated Impulse Voltage
4 kV
4 kV
4 kV
Rated Insulation Voltage
250 V acc. to EN 60998-1
Rated Current
6A
Torque
0,4 Nm
Other specifications
2-12 poles types are "no-flame" acc. to glow-wire
test.
Material
Moulding
PA, grey, V-0
Comparative Tracking Index
2-12 poles: CTI ≥ 600; 13-2 4 poles: CTI 400
Insulating Group
2-12 poles: I; 13-24 poles: II
Temperature Range
-40°C up to 100°C
Terminal body
Nickel plated brass
Screw
M2,6; zinc plated steel, blue passivated
Wire protector
Tin plated tin bronze
Spring
Approvals
WECO Contact GmbH - www.wecogroup.com
''no flame'' after glow-wire test according to
Household Appliance DIN EN/IEC 60335-1
Current
Voltage
Group
AWG
Nm
10
300
B
26 - 14
0,4
10
300
B
26 - 14
0,4
Options / Accessories
Consecutive numbering
Special marking according to drawing
Self-adhesive marking strip BST-5,00
Pitch of 10 mm for larger clearance and creepage distances
06.11
很抱歉,暂时无法提供与“950-FL-DS/05”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+13.59720
- 10+11.53440
- 30+10.24920
- 100+8.93160
- 500+8.33760
- 1000+8.07840
