930-T-DS/02
930-T-DS/02
    WECO(威克德诺)
    插件,P=3.5mm
    接线端子 1x2P 3.5mm 直插 排数:单排 每排Pin数:2
930-T-DS/02 数据手册
TECHNICAL DATA SHEET 930-T(-DS) PCB connector Screw connection, interlocking GENERAL INFORMATION Pitch No. of poles 3,5 mm 2+3 TECHNICAL DATA Clamping Range without wire protector with wire protector Rated Cross Section Wire Stripping Length Overvoltage Category Pollution Severity Level Rated Voltage Rated Impulse Voltage Rated Insulation Voltage Rated Current Hole in PCB Torque MATERIAL solid / stranded / AWG 0,75 - 1,5 mm² / 0,75 - 1,5 mm² / 18 - 16 AWG 0,34 - 1,5 mm² / 0,34 - 1 mm² / 22 - 16 AWG 1 mm² 5 mm ± 0,5 mm III 3 160 V 2,5 kV III 2 160 V 2,5 kV II 2 320 V 2,5 kV 130 V acc. to EN 60998-1 13,5 A ø 1,2 mm 0,2 Nm Moulding Comparative Tracking Index Insulating Group Temperature Range Terminal body Screw Solder pin Wire protector PA, grey, V-0 CTI ≥ 600 I -40°C up to 100°C Tin plated brass M2; zinc plated steel, blue passivated ø 0,9 mm; tin plated brass German silver OPTIONS / ACCESSORIES • • • • Consecutive numbering Special marking according to drawing Self-adhesive marking strip BST-3,50 Pitch of 7 mm for larger clearance and creepage distances APPROVALS Current [A] Voltage [V] Group AWG [Nm] 10 300 B 26 - 16 0,23 10 300 B 26 - 16 0,2 CONFIGURATIONS Poles Part number 2 3 930-T/02 930-T/03 Article number Part number Article number 30.870.002 30.870.003 930-T-DS/02 930-T-DS/03 40.870.002 40.870.003 Length (L) 7,00 mm 10,50 mm Packaging PU Box Box 250 250 02.13 WECO Electrical Connectors Inc., 18050 Trans-Canada Highway, Kirkland, Québec, Canada, H9J 4A1 Phone: 800.724.2928 | Phone: 514.694.9136 | Fax: 514.694.0956 weco@wecoconnectors.com © Copyright by WECO All rights reserved. WECO® is a brand of the WECO Group. Information provided in this document may be changed without prior notice. Please refer to our website for the full disclaimer.
930-T-DS/02 价格&库存
很抱歉,暂时无法提供与“930-T-DS/02”相匹配的价格&库存,您可以联系我们找货
