302-STS(-DS)
Plug-in terminal strip
Screw connection & pin
General Information
Pitch
8 mm
No. of poles
2 - 12
Usable with
302-STB(-DS)
Areas of application
Applications that require to easily open and close
not energised circuits.
Technical Data
Clamping Range
The plug-in terminal strip 302-STS is available in 8 mm pitch with 1 to 12 poles.
It has one screw connection per pole and one vertical pin for the connection to the
socket of the female counterpart.
The slotted pins and slotted sockets of plug-in terminal strip 302-STB create
appropriate contact pressure. Due to the small 8 mm pitch, this version is well
suited for applications where space is limited.
The wire protector of the “DS”-version reliably prevents damage to multi-wire
flexible conductors by the turning screw. These terminals strips can be
screw-mounted on a substrate.
Part Numbers
No. of
poles
302-STS
302-STS-DS
Length
PU
2
3
4
12.820.009
13.820.009
14.820.009
72.820.009
73.820.009
74.820.009
15,00
23,00
31,00
1000
1000
500
5
6
7
8
15.820.009
16.820.009
17.820.009
18.820.009
75.820.009
76.820.009
77.820.009
78.820.009
39,00
47,00
55,00
63,00
500
80
60
70
9
10
11
12
19.820.009
20.820.009
21.820.009
22.820.009
79.820.009
80.820.009
81.820.009
82.820.009
71,00
79,00
87,00
94,00
60
40
40
40
solid / flexible / AWG
without wire protector
0,5 - 4 mm² / 0,5 - 2,5 mm² / 20 - 12 AWG
with wire protector
0,34 - 2,5 mm² / 0,34 - 1,5 mm² / 22 - 14 AWG
Rated Cross Section
1,5 mm²
Wire Stripping Length
6 mm ± 0,5 mm
Overvoltage Category
III
III
II
Pollution Severity Level
3
2
2
Rated Voltage
200 V
320 V
630 V
Rated Impulse Voltage
4 kV
4 kV
4 kV
Rated Insulation Voltage
450 V acc. to EN 60998-1
Rated Current
6A
Torque
0,4 Nm
Other specifications
Rated values apply to use in combination with
302-STB(-DS) and without insulated substrates.
Material
Moulding
PA, natural, V-2
Comparative Tracking Index
CTI ≥ 600
Insulating Group
I
Temperature Range
-40°C up to 100°C
Terminal Body
Nickel plated brass
Screw
M2,6; zinc plated steel, blue passivated
Wire protector
Tin plated tin bronze
Plug
Nickel plated brass
Approvals
Current [A]
Voltage [V]
Group
AWG
[Nm]
6
300
B,D
20 - 14
0,4
10
300
B,D,E
26 - 12
0,4 [1]
[1] for 302-STS-DS: 26 - 14 AWG
Options / Accessories
• Marking options on the screw guides
• Jumper 302-J
• Moulding made of special polyamide for e.g. household appliances
• Screws made out of brass
• With pegs at the base for saving assembly time
WECO | www.wecogroup.com
05.18
很抱歉,暂时无法提供与“302-STS-DS/02”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+8.13240
- 10+6.76080
- 30+6.00480
- 250+5.15160
- 500+4.76280
- 1000+4.60080
