930-D-SMD-DS/03
930-D-SMD-DS/03
    WECO(威克德诺)
    SMD,P=3.5mm,卧贴
    接线端子 1x3P 3.5mm 卧贴 排数:单排 每排Pin数:3
930-D-SMD-DS/03 数据手册
TECHNICAL DATA SHEET 930-D-SMD(-DS) PCB connector for SMD Screw connection, floating terminal bodies GENERAL INFORMATION Pitch No. of poles 3,5 mm 2 - 12 * = Height without -DS: 10,2 mm L = No. of poles x pitch + 0,3 mm TECHNICAL DATA Clamping Range without wire protector with wire protector Rated Cross Section Wire Stripping Length Overvoltage Category Pollution Severity Level Rated Voltage Rated Impulse Voltage Rated Insulation Voltage Rated Current Soldering process Torque Other specifications solid / stranded / AWG 0,75 - 1,5 mm² / 0,75 - 1,5 mm² / 18 - 16 AWG 0,25 - 1 mm² / 0,25 - 1 mm² / 24 - 18 AWG 1 mm² 5 mm ± 0,5 mm III 3 125 V 2,5 kV III 2 160 V 2,5 kV II 2 320 V 2,5 kV 130 V acc. to EN 60998-1 13,5 A Reflow solder 0,2 Nm Recommended screwdriver: blade 0,4 x 2,0 mm APPROVALS PCB LAYOUT Solder paste thickness: 0,15 - 0,2 mm MATERIAL Moulding Comparative Tracking Index Insulating Group Temperature Range Terminal body Screw Wire protector PA HT, black, V-0 CTI ≥ 600 I -40°C up to 120°C; reflow solder temperature peak max. 255°C acc. to DIN EN 61760-1 Tin plated brass M2; tin plated brass German silver Current [A] Voltage [V] Group AWG [Nm] 10 150 B 26 - 16 0,23 OPTIONS / ACCESSORIES 10 150 B 26 - 16 0,2 • Special marking according to drawing • Self-adhesive marking strip BST-3,50 [1] • White housing colour on request [1] To be fitted after reflow soldering process CONFIGURATIONS Poles Part number 2 3 4 5 6 2 3 4 5 6 930-D-SMD/02 930-D-SMD/03 930-D-SMD/04 930-D-SMD/05 930-D-SMD/06 930-D-SMD/02-T&R 930-D-SMD/03-T&R 930-D-SMD/04-T&R 930-D-SMD/05-T&R 930-D-SMD/06-T&R Article number Part number Article number 10.870.602 10.870.603 10.870.604 10.870.605 10.870.606 10.870.602.A00 10.870.603.A00 10.870.604.A00 10.870.605.A00 10.870.606.A00 930-D-SMD-DS/02 930-D-SMD-DS/03 930-D-SMD-DS/04 930-D-SMD-DS/05 930-D-SMD-DS/06 930-D-SMD-DS/02-T&R 930-D-SMD-DS/03-T&R 930-D-SMD-DS/04-T&R 930-D-SMD-DS/05-T&R 930-D-SMD-DS/06-T&R 20.870.602 20.870.603 20.870.604 20.870.605 20.870.606 20.870.602.A00 20.870.603.A00 20.870.604.A00 20.870.605.A00 20.870.606.A00 Length (L) 7,30 mm 10,80 mm 14,30 mm 17,80 mm 21,30 mm 7,30 mm 10,80 mm 14,30 mm 17,80 mm 21,30 mm Packaging PU Box Box Box Box Box Tape-on-Reel Tape-on-Reel Tape-on-Reel Tape-on-Reel Tape-on-Reel 250 250 250 200 200 500 500 500 500 500 Tape Width Tape Height 24 mm 24 mm 24 mm 32 mm 44 mm 11,3 mm 11,3 mm 11,3 mm 11,3 mm 11,3 mm further number of poles on request 11.17 WECO Electrical Connectors Inc., 18050 Trans-Canada Highway, Kirkland, Québec, Canada, H9J 4A1 Phone: 800.724.2928 | Phone: 514.694.9136 | Fax: 514.694.0956 weco@wecoconnectors.com © Copyright by WECO All rights reserved. WECO® is a brand of the WECO Group. Information provided in this document may be changed without prior notice. Please refer to our website for the full disclaimer.
930-D-SMD-DS/03 价格&库存
很抱歉,暂时无法提供与“930-D-SMD-DS/03”相匹配的价格&库存,您可以联系我们找货
930-D-SMD-DS/03
  • 1+8.41320
  • 10+6.98760
  • 30+6.19920
库存:1
