TECHNICAL DATA SHEET
900-SUN-5
Tab connector
Tab 6,3 mm
GENERAL INFORMATION
Pitch
No. of poles
5 mm
2 - 25
TECHNICAL DATA
Overvoltage Category
Pollution Severity Level
Rated Voltage
Rated Impulse Voltage
Rated Insulation Voltage
Rated Current
Hole in PCB
Other specifications
MATERIAL
III
3
320 V
4 kV
III
2
320 V
4 kV
II
2
630 V
4 kV
450 V acc. to EN 60998-1
15 A: with receptacles 6,3; wire 2,5 mm² (14 AWG)
ø 1,6 mm
Indicated rated voltages refer to applications with
insulation receptacles
APPROVALS
Current [A]
Voltage [V]
Group
15
150
B
15
10
300
300
B
D, E
AWG
[Nm]
Moulding
Comparative Tracking Index
Insulating Group
Temperature Range
Solder pin
Tab
PA, red, V-0
CTI ≥ 600
I
-40°C up to 100°C
1,0 x 0,8 mm; tin plated brass
6,3 x 0,8 mm; tin plated brass
OPTIONS / ACCESSORIES
Consecutive numbering
Special marking according to drawing
Self-adhesive marking strip BST-5,00
Insulation receptacles ISO
Insulation sockets IS0-900
Change of pitch
Component mix of tab connector versions
Tab connectors are also individually available (see single tabs GST-900)
CONFIGURATIONS
Poles Part number
2
3
4
5
6
900-SUN-5/02
900-SUN-5/03
900-SUN-5/04
900-SUN-5/05
900-SUN-5/06
Article number
45.870.902
45.870.903
45.870.904
45.870.905
45.870.906
Length (L)
8,50 mm
13,50 mm
18,50 mm
23,50 mm
28,50 mm
Packaging
PU
Box
Box
Box
Box
Box
250
250
200
100
100
further number of poles on request
07.19
WECO Electrical Connectors Inc., 18050 Trans-Canada Highway,
Kirkland, Québec, Canada, H9J 4A1
Phone: 800.724.2928 | Phone: 514.694.9136 | Fax: 514.694.0956
weco@wecoconnectors.com
© Copyright by WECO
All rights reserved. WECO® is a brand of the WECO Group.
Information provided in this document may be changed without prior notice.
Please refer to our website for the full disclaimer.
很抱歉,暂时无法提供与“900-SUN-5/02”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.51000
- 10+2.78640
- 30+2.48400
- 250+2.09520
- 500+1.92240
- 1000+1.81440
