TECHNICAL DATA SHEET
110-M-211
Pin strip
Plug-in direction parallel to PCB, with false insertion prevention
GENERAL INFORMATION
Pitch
No. of poles
Usable with
Additonal Information
3,5 mm
2 - 24
all plug connectors of series 110
For versions with connecting flanges see
110-M-215.
MATERIAL
Moulding
Comparative Tracking Index
Insulating Group
Temperature Range
Solder pin
TECHNICAL DATA
Overvoltage Category
Pollution Severity Level
Rated Voltage
Rated Impulse Voltage
Rated Insulation Voltage
Rated Current
Hole in PCB
III
3
160 V
2,5 kV
III
2
160 V
2,5 kV
II
2
320 V
2,5 kV
OPTIONS / ACCESSORIES
130 V acc. to EN 60998-1
8A
ø 1,3 mm
APPROVALS
Current [A]
Voltage [V]
Group
8
300
B, D
8
300
B
AWG
PA, grey, V-0
CTI ≥ 600
I
-40°C up to 100°C
0,8 x 0,8 mm; tin plated brass
[Nm]
Consecutive numbering
Special marking according to drawing
Self-adhesive marking strip BST-3,50
Pitch of 7 mm for larger clearance and creepage distances
Coding elements 120-K
With smooth side wall
CONFIGURATIONS
Poles Part number
2
3
4
5
6
110-M-211/02
110-M-211/03
110-M-211/04
110-M-211/05
110-M-211/06
Article number
10.841.002
10.841.003
10.841.004
10.841.005
10.841.006
Length (L)
7,60 mm
11,10 mm
14,60 mm
18,10 mm
21,60 mm
Packaging
PU
Box
Box
Box
Box
Box
200
200
100
100
100
07.19
WECO Electrical Connectors Inc., 18050 Trans-Canada Highway,
Kirkland, Québec, Canada, H9J 4A1
Phone: 800.724.2928 | Phone: 514.694.9136 | Fax: 514.694.0956
weco@wecoconnectors.com
© Copyright by WECO
All rights reserved. WECO® is a brand of the WECO Group.
Information provided in this document may be changed without prior notice.
Please refer to our website for the full disclaimer.
很抱歉,暂时无法提供与“110-M-211/06”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+9.46080
- 10+7.90560
- 30+7.04160
- 100+6.06960
