110-M-211/05
110-M-211/05
    WECO(威克德诺)
    弯插,P=3.5mm
    对插式,母座,90°弯针,防火V0,UL,VDE认证
110-M-211/05 数据手册
TECHNICAL DATA SHEET 110-M-211 Pin strip Plug-in direction parallel to PCB, with false insertion prevention GENERAL INFORMATION Pitch No. of poles Usable with Additonal Information 3,5 mm 2 - 24 all plug connectors of series 110 For versions with connecting flanges see 110-M-215. MATERIAL Moulding Comparative Tracking Index Insulating Group Temperature Range Solder pin TECHNICAL DATA Overvoltage Category Pollution Severity Level Rated Voltage Rated Impulse Voltage Rated Insulation Voltage Rated Current Hole in PCB III 3 160 V 2,5 kV III 2 160 V 2,5 kV II 2 320 V 2,5 kV OPTIONS / ACCESSORIES 130 V acc. to EN 60998-1 8A ø 1,3 mm APPROVALS Current [A] Voltage [V] Group 8 300 B, D 8 300 B AWG PA, grey, V-0 CTI ≥ 600 I -40°C up to 100°C 0,8 x 0,8 mm; tin plated brass [Nm] • • • • • • Consecutive numbering Special marking according to drawing Self-adhesive marking strip BST-3,50 Pitch of 7 mm for larger clearance and creepage distances Coding elements 120-K With smooth side wall CONFIGURATIONS Poles Part number 2 3 4 5 6 110-M-211/02 110-M-211/03 110-M-211/04 110-M-211/05 110-M-211/06 Article number 10.841.002 10.841.003 10.841.004 10.841.005 10.841.006 Length (L) 7,60 mm 11,10 mm 14,60 mm 18,10 mm 21,60 mm Packaging PU Box Box Box Box Box 200 200 100 100 100 07.19 WECO Electrical Connectors Inc., 18050 Trans-Canada Highway, Kirkland, Québec, Canada, H9J 4A1 Phone: 800.724.2928 | Phone: 514.694.9136 | Fax: 514.694.0956 weco@wecoconnectors.com © Copyright by WECO All rights reserved. WECO® is a brand of the WECO Group. Information provided in this document may be changed without prior notice. Please refer to our website for the full disclaimer.
110-M-211/05 价格&库存
很抱歉,暂时无法提供与“110-M-211/05”相匹配的价格&库存,您可以联系我们找货
110-M-211/05
  • 1+7.95960
  • 10+6.59880
  • 30+5.85360
库存:76
