110-M-111/05
110-M-111/05
    WECO(威克德诺)
    弯插,P=3.5mm
    对插式,母座,90°弯针,防火V0,UL,VDE认证
110-M-111/05 数据手册
TECHNICAL DATA SHEET 110-M-111 Pin strip Plug-in direction parallel to PCB, flat side walls 9,2 3,6 3 6,9 L 0,8 3,5 1,2 GENERAL INFORMATION Pitch No. of poles Usable with Additonal Information 3,5 mm 2 - 12 all plug connectors of series 110 For versions with connecting flanges see 110-M-215. For versions with false insertion prevention see 110-M-211. MATERIAL Moulding Comparative Tracking Index Insulating Group Temperature Range Solder pin TECHNICAL DATA Overvoltage Category Pollution Severity Level Rated Voltage Rated Impulse Voltage Rated Insulation Voltage Rated Current Hole in PCB III 3 160 V 2,5 kV III 2 160 V 2,5 kV II 2 320 V 2,5 kV PA, grey, V-0 CTI ≥ 600 I -40°C up to 100°C 0,8 x 0,8 mm; tin plated brass OPTIONS / ACCESSORIES • • • • • 130 V acc. to EN 60998-1 8A ø 1,3 mm Consecutive numbering Special marking according to drawing Self-adhesive marking strip Pitch of 7 mm for larger clearance and creepage distances Coding elements 120-K APPROVALS Current [A] Voltage [V] Group 8 300 B, D 8 300 B AWG [Nm] CONFIGURATIONS Poles Item 2 3 4 5 6 7 8 9 10 11 12 110-M-111/02 110-M-111/03 110-M-111/04 110-M-111/05 110-M-111/06 110-M-111/07 110-M-111/08 110-M-111/09 110-M-111/10 110-M-111/11 110-M-111/12 Article number 10.841.027 10.841.028 10.841.029 10.841.030 10.841.031 10.841.032 10.841.033 10.841.034 10.841.035 10.841.036 10.841.037 Length (L) 7,60 mm 11,10 mm 14,60 mm 18,10 mm 21,60 mm 25,10 mm 28,60 mm 32,10 mm 35,60 mm 39,10 mm 42,60 mm Packaging PU Box Box Box Box Box Box Box Box Box Box Box 200 200 100 100 100 50 50 50 50 50 50 further number of poles on request 08.20
110-M-111/05 价格&库存
很抱歉,暂时无法提供与“110-M-111/05”相匹配的价格&库存,您可以联系我们找货
110-M-111/05
  • 1+7.88400
  • 10+6.54480
  • 30+5.81040
库存:41
