121-M-221/03
121-M-221/03
    WECO(威克德诺)
    插件,P=5.08mm
    对插式,母座,带两边护栏,防火V0,UL,VDE
121-M-221/03 数据手册
TECHNICAL DATA SHEET 121-M-121/-221 Pin strip Plug-in direction vertical to PCB GENERAL INFORMATION Pitch No. of poles Usable with Additonal Information 5,08 mm 2 - 12 all plug connectors of series 121 Ordering information: ..-M-121: without side walls ..-M-221: with side walls 121-M-121 TECHNICAL DATA Overvoltage Category Pollution Severity Level Rated Voltage Rated Impulse Voltage Rated Insulation Voltage Rated Current Hole in PCB III 3 250 V 4 kV III 2 320 V 4 kV II 2 630 V 4 kV 250 V acc. to EN 60998-1 12 A ø 1,4 mm MATERIAL APPROVALS Current [A] Voltage [V] Group 15 10 300 300 B D 15 10 300 300 B D, E 121-M-221 AWG [Nm] Moulding Comparative Tracking Index Insulating Group Temperature Range Solder pin PA, grey, V-0 CTI ≥ 600 I -40°C up to 100°C 1,0 x 1,0 mm; tin plated brass OPTIONS / ACCESSORIES • • • • • • • Consecutive numbering Special marking according to drawing Self-adhesive marking strip BST-5,08 Pitch of 10,16 mm for larger clearance and creepage distances Other solder pin lengths on request Coding elements 120-K Connectors equipped with coding elements on request CONFIGURATIONS Poles Part number 2 3 4 5 6 121-M-121/02 121-M-121/03 121-M-121/04 121-M-121/05 121-M-121/06 Article number Part number Article number 20.806.102 20.806.103 20.806.104 20.806.105 20.806.106 121-M-221/02 121-M-221/03 121-M-221/04 121-M-221/05 121-M-221/06 20.806.126 20.806.127 20.806.128 20.806.129 20.806.130 Length (L) 10,16 mm 15,24 mm 20,32 mm 25,40 mm 30,48 mm Packaging PU Box Box Box Box Box 200 200 100 100 100 further number of poles on request 07.19 WECO Electrical Connectors Inc., 18050 Trans-Canada Highway, Kirkland, Québec, Canada, H9J 4A1 Phone: 800.724.2928 | Phone: 514.694.9136 | Fax: 514.694.0956 weco@wecoconnectors.com © Copyright by WECO All rights reserved. WECO® is a brand of the WECO Group. Information provided in this document may be changed without prior notice. Please refer to our website for the full disclaimer.
121-M-221/03 价格&库存
很抱歉,暂时无法提供与“121-M-221/03”相匹配的价格&库存,您可以联系我们找货
121-M-221/03
  • 1+4.93560
  • 10+4.01760
  • 30+3.56400
库存:156
