158-A-111/02
158-A-111/02
    WECO(威克德诺)
    弯插,P=10.16mm
    接线端子 1x2P 10.16mm 弯插 排数:单排 每排Pin数:2
158-A-111/02 数据手册
TECHNICAL DATA SHEET 158-A-111 PCB connector Screw connection GENERAL INFORMATION Pitch No. of poles Usable with Areas of application Additonal Information 10,16 mm 2 - 12 158-A-211, 159-A-111 and 159-A-211, mountable side-by-side to any series connector Power electronics, in particular for drives with frequency converters, and also for power supplies and charging units. Hole for ø 2 mm test plug TECHNICAL DATA Clamping Range Rated Cross Section Wire Stripping Length Overvoltage Category Pollution Severity Level Rated Voltage Rated Impulse Voltage Rated Current Hole in PCB Torque Other specifications solid / stranded / AWG 0,5 - 16 mm² / 0,5 - 10 mm² / 20 - 6 AWG 10 mm² 10,5 mm ± 1 mm III 3 690 V 8 kV III 2 1000 V 8 kV II 2 1000 V 6 kV MATERIAL Moulding Comparative Tracking Index Insulating Group Temperature Range Terminal body Pressure clamp Screw Solder pin 57 A ø 1,5 mm 1,2 Nm Maximum current/cross-section 76 A / 16 mm², stranded wire APPROVALS Current [A] Voltage [V] Group AWG [Nm] 60 10 300 300 B, C D 20 - 6 20 - 6 1,3 1,3 Current [A] Voltage [V] mm² 57 690 - 1000 [1] 2,5 - 10 PA, grey, V-0 CTI ≥ 600 I -40°C up to 100°C Nickel plated brass Tin plated copper Plus-minus, M4; zinc plated steel, blue passivated Tin plated copper OPTIONS / ACCESSORIES • Consecutive numbering • Special marking according to drawing • Self-adhesive marking strip BST-10,16 [1] Marks approval acc. to DIN EN 60947-7-4 CONFIGURATIONS Poles Part number 2 3 4 5 158-A-111/02 158-A-111/03 158-A-111/04 158-A-111/05 Article number 12.801.901 13.801.901 14.801.901 15.801.901 Length (L) 20,32 mm 30,48 mm 40,64 mm 50,80 mm Packaging PU Box Box Box Box 50 50 50 50 further number of poles on request 06.17 WECO Electrical Connectors Inc., 18050 Trans-Canada Highway, Kirkland, Québec, Canada, H9J 4A1 Phone: 800.724.2928 | Phone: 514.694.9136 | Fax: 514.694.0956 weco@wecoconnectors.com © Copyright by WECO All rights reserved. WECO® is a brand of the WECO Group. Information provided in this document may be changed without prior notice. Please refer to our website for the full disclaimer.
158-A-111/02 价格&库存
很抱歉,暂时无法提供与“158-A-111/02”相匹配的价格&库存,您可以联系我们找货
158-A-111/02
  • 1+19.47240
  • 10+18.50040
  • 30+17.92800
库存:103
