971-T(-DS)
PCB connector
Screw connection, wire entrance vertical to PCB, interlocking
General Information
Pitch
5 mm
No. of poles
2+3
Technical Data
Clamping Range
solid / flexible / AWG
without wire protector
1 - 6 mm² / 1 - 2,5 mm² / 16 - 12 AWG
with wire protector
0,75 - 4 mm² / 0,75 - 2,5 mm² / 18 - 12 AWG
Rated Cross Section
2,5 mm²
Wire Stripping Length
5,5 mm ± 0,5 mm
Overvoltage Category
III
III
Pollution Severity Level
3
2
2
250 V
320 V
630 V
4 kV
4 kV
4 kV
Rated Voltage
Rated Impulse Voltage
The PCB connector 971-T with a pitch of 5 mm is available with 2 and 3 poles.
Lateral latching elements on the housing allow to latch the PCB connector to
longer terminal strips without pole loss.
Wire protection in DS-design reliably prevents damage to stranded wires by the
screw. The wire entrance is vertical to the PCB.
The screws are secured against self-loosening. For the connection to the grid,
these PCB connectors are equipped with a M3 thread.
Part Numbers
No. of
poles
971-T
971-T-DS
Length
PU
2
3
10.872.612
10.872.613
20.872.612
20.872.613
10,00
15,00
250
250
Rated Current
24 A
Hole in PCB
ø 1,3 mm
Torque
0,5 Nm
II
Material
Moulding
PA, grey, V-0
Comparative Tracking Index
CTI ≥ 600
Insulating Group
I
Temperature Range
-40°C up to 100°C
Terminal body
Tin plated brass
Screw
M3; zinc plated steel, blue passivated
Solder pin
ø 1 mm; tin plated brass
Wire protector
Tin plated tin bronze
Approvals
Current [A]
Voltage [V]
Group
AWG
[Nm]
300
300
B
D
22-12 [1]
22-12 [1]
0,51
0,51
300
300
B
D, E
26 - 12
26 - 12
0,51
0,51
Current [A]
Voltage [V]
[mm²]
24
250
2,5 [2]
[1] Min No. 26 AWG for factory-wiring only
[2] Acc. to IEC 60947-7-4 und IEC 60947-1
Options / Accessories
• Consecutive numbering
• Special marking according to drawing
• Self-adhesive marking strip BST-5,00
• Pitch of 10 mm for larger clearance and creepage distances
• Version with extended wire entrance
• Double wire protector as bridge
• With test holes, see 971-THM(-DS)
WECO | www.wecogroup.com
''no flame'' after glow-wire test according to
Household Appliance DIN EN/IEC 60335-1
11.17
很抱歉,暂时无法提供与“971-T-DS/03”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+8.26200
- 10+6.90120
- 30+6.15600
- 250+5.30280
