971-T-DS/02
971-T-DS/02
    WECO(威克德诺)
    弯插,P=5mm
    接线端子 1x2P 5mm 弯插 排数:单排 每排Pin数:2
971-T-DS/02 数据手册
971-T(-DS) PCB connector Screw connection, wire entrance vertical to PCB, interlocking General Information Pitch 5 mm No. of poles 2+3 Technical Data Clamping Range solid / flexible / AWG without wire protector 1 - 6 mm² / 1 - 2,5 mm² / 16 - 12 AWG with wire protector 0,75 - 4 mm² / 0,75 - 2,5 mm² / 18 - 12 AWG Rated Cross Section 2,5 mm² Wire Stripping Length 5,5 mm ± 0,5 mm Overvoltage Category III III Pollution Severity Level 3 2 2 250 V 320 V 630 V 4 kV 4 kV 4 kV Rated Voltage Rated Impulse Voltage The PCB connector 971-T with a pitch of 5 mm is available with 2 and 3 poles. Lateral latching elements on the housing allow to latch the PCB connector to longer terminal strips without pole loss. Wire protection in DS-design reliably prevents damage to stranded wires by the screw. The wire entrance is vertical to the PCB. The screws are secured against self-loosening. For the connection to the grid, these PCB connectors are equipped with a M3 thread. Part Numbers No. of poles 971-T 971-T-DS Length PU 2 3 10.872.612 10.872.613 20.872.612 20.872.613 10,00 15,00 250 250 Rated Current 24 A Hole in PCB ø 1,3 mm Torque 0,5 Nm II Material Moulding PA, grey, V-0 Comparative Tracking Index CTI ≥ 600 Insulating Group I Temperature Range -40°C up to 100°C Terminal body Tin plated brass Screw M3; zinc plated steel, blue passivated Solder pin ø 1 mm; tin plated brass Wire protector Tin plated tin bronze Approvals Current [A] Voltage [V] Group AWG [Nm] 20 10 300 300 B D 22-12 [1] 22-12 [1] 0,51 0,51 20 10 300 300 B D, E 26 - 12 26 - 12 0,51 0,51 Current [A] Voltage [V] [mm²] 24 250 2,5 [2] [1] Min No. 26 AWG for factory-wiring only [2] Acc. to IEC 60947-7-4 und IEC 60947-1 Options / Accessories • Consecutive numbering • Special marking according to drawing • Self-adhesive marking strip BST-5,00 • Pitch of 10 mm for larger clearance and creepage distances • Version with extended wire entrance • Double wire protector as bridge • With test holes, see 971-THM(-DS) WECO | www.wecogroup.com ''no flame'' after glow-wire test according to Household Appliance DIN EN/IEC 60335-1 11.17
971-T-DS/02 价格&库存
很抱歉,暂时无法提供与“971-T-DS/02”相匹配的价格&库存,您可以联系我们找货
