8
6
7
4
5
3
D
2
1
REVISIONS
THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE
PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE
WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED.
APPROVED
DATE
DESCRIPTION
REV
C
ECN 4740: CN RELEASE
5/13/10
D
ECN 6716: CN RELEASE ON SNAP-ON COVER
3/5/13
D.FRISIELLO
E
ECN 8409: UPDATE TEMPERATURE RATING TO -10~70°C
7/15/16
S.LI
D. CASTRO
5.0 METERS
[16.4 FEET]
D
CUT END
"J1"
.125
.75
3.2
MOLDED STRAIN RELIEF
COLOR: LIGHT GRAY
(PANTONE 400C)
19.1
PIN 1
C
1.142
1.40
29
35.6
ONE 28AWG TWISTED PAIR (DATA)
PLUS TWO 20 AWG POWER CONDUCTORS
OVERALL ALUMINIZED POLYESTER SHIELD WITH
DRAIN WIRE PLUS TINNED COPPER BRAID SHIELD.
PVC OUTER JACKET: LIGHT GRAY (PANTONE 400C).
USB TYPE "A" JACK
BULKHEAD ADAPTER
SHIELDED
WIRING DIAGRAM
2X #4-40 UNC-2B
"J1"
B
1
.905
23
VCC (CABLE POWER) RED
2 - DATA WHITE
4 GND (CABLE GROUND) BLACK
MATERIAL:
TYPE "A" JACK:
COUPLER HOUSING: ABS, UL94V-0, FINISH: CHROME.
CONNECTOR PLASTIC: PBT WITH GLASS FIBER.
CONTACTS: PHOSPHOR BRONZE, FINISH: 30µ GOLD.
CONNECTOR SHELL: BRASS, NICKEL PLATED.
PCB: EPOXY GLASS FP-4, 94V-0 FLAMMABILITY RATING.
E
.675
17.1
DRAIN WIRE
HOUSING
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES [mm]
MISCELLANEOUS:
MUST BE USB 2.0 COMPLIANT.
OPERATING TEMPERATURE: -10°C TO +70°C.
CABLE ASSEMBLY SHALL BE TESTED FOR CONTINUITY.
CABLE ASSEMBLY SHALL BE INDIVIDUALLY PACKAGED IN
ACCORDANCE WITH L-COM PACKAGING SPEC PS-0031.
OVERALL CABLE LENGTH TOLERANCE:
≤12 [305] = +1 [25] / -0
>12 [305] ≤60 [1524] = +2 [51] / -0
>60 [1524] ≤120 [3048] = +4 [102] / -0
>120 [3048] ≤300 [7620] = +6 [152] / -0
>300 [7620] = +5% / -0%
ALL OTHER DIMENSIONAL TOLERANCES:
.X = ± .2 [5.08]
.XX = ± .02 [.51]
.XXX = ±.005 [.13]
REGULATORY COMPLIANCE:
CE2011/65/EU(RoHS DIRECTIVE)
PROJECTION
RECOMMENDED
PANEL CUT OUT
APPROVALS
50 HIGH STREET
NORTH ANDOVER, MA
01845
DATE
DRAWN BY
7/20/04
C.MCCORMICK
CHECKED BY
7/20/04
D.PARHAM
USB
7/20/04
R.CARRICK
CONFIGURATION DETAILS OF
UNDIMENSIONED FEATURES
MAY VARY
COLOR VARIATIONS
MAY OCCUR
7
6
5
4
3
A
CATEGORY
APPROVED BY
PRODUCT DESCRIPTION
USB A-F PNL MNT/CUT END
SIZE
A
FSCM NO.
43321
SCALE: NONE
8
B
1.142
29
3 + DATA GREEN
NOTES:
A
C
DWG. NO.
CAD FILE:
2
ECF504-5M
ECF504-5M.SLDDRW
REV.
E
SHEET 1 OF 1
1
很抱歉,暂时无法提供与“ECF504-5M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+177.69131
- 10+172.35942
- 国内价格 香港价格
- 1+269.173011+34.72401
- 10+228.7730610+29.51231
- 25+214.4481025+27.66436
- 50+204.2154950+26.34432
- 100+194.47689100+25.08802
- 250+182.31495250+23.51910
- 500+173.62548500+22.39813
