900-SUN-10/03
900-SUN-10/03
    WECO(威克德诺)
    插件,P=10mm
900-SUN-10/03 数据手册
TECHNICAL DATA SHEET 900-SUN-10 Tab connector Tab 6,3 mm GENERAL INFORMATION Pitch No. of poles 10 mm 2 - 13 TECHNICAL DATA Overvoltage Category Pollution Severity Level Rated Voltage Rated Impulse Voltage Rated Insulation Voltage Rated Current Hole in PCB Other specifications MATERIAL III 3 630 V 6 kV III 2 630 V 6 kV II 2 1000 V 6 kV 750 V acc. to EN 60998-1 15 A: with receptacles 6,3; wire 2,5 mm² (14 AWG) ø 1,6 mm Indicated rated voltages refer to applications with insulation receptacles APPROVALS Current [A] Voltage [V] Group 15 15 300 150 B C 15 10 300 300 B D, E AWG [Nm] Moulding Comparative Tracking Index Insulating Group Temperature Range Solder pin Tab PA, red, V-0 CTI ≥ 600 I -40°C up to 100°C 1,0 x 0,8 mm; tin plated brass 6,3 x 0,8 mm; tin plated brass OPTIONS / ACCESSORIES • • • • • • • • Consecutive numbering Special marking according to drawing Self-adhesive marking strip BST-10,00 Insulation receptacles ISO Insulation sockets ISO-900 Change of pitch Component mix of tab connector versions Tab connectors are also individually available (see single tabs GST-900) CONFIGURATIONS Poles Part number 2 3 4 5 6 900-SUN-10/02 900-SUN-10/03 900-SUN-10/04 900-SUN-10/05 900-SUN-10/06 Article number 49.870.903 49.870.905 49.870.907 49.870.909 49.870.911 Length (L) 13,50 mm 23,50 mm 33,50 mm 43,50 mm 53,50 mm Packaging PU Box Box Box Box Box 250 100 100 100 100 further number of poles on request 07.19 WECO Electrical Connectors Inc., 18050 Trans-Canada Highway, Kirkland, Québec, Canada, H9J 4A1 Phone: 800.724.2928 | Phone: 514.694.9136 | Fax: 514.694.0956 weco@wecoconnectors.com © Copyright by WECO All rights reserved. WECO® is a brand of the WECO Group. Information provided in this document may be changed without prior notice. Please refer to our website for the full disclaimer.
900-SUN-10/03 价格&库存
很抱歉,暂时无法提供与“900-SUN-10/03”相匹配的价格&库存,您可以联系我们找货
