121-A-111/05
121-A-111/05
    WECO(威克德诺)
    P=5.08mm
    接线端子 1x5P 间距:5.08mm 排数:1 每排Pin数:5
121-A-111/05 数据手册
TECHNICAL DATA SHEET 121-A-111 Plug connector Screw connection GENERAL INFORMATION Pitch No. of poles Usable with 5,08 mm 2 - 24 all pin strips of series 121 TECHNICAL DATA Clamping Range Rated Cross Section Wire Stripping Length Overvoltage Category Pollution Severity Level Rated Voltage Rated Impulse Voltage Rated Insulation Voltage Rated Current Torque solid / stranded / AWG 0,2 - 4 mm² / 0,2 - 2,5 mm² / 26 - 12 AWG 2,5 mm² 7 mm ± 0,5 mm III 3 250 V 4 kV III 2 320 V 4 kV MATERIAL II 2 630 V 4 kV Moulding Comparative Tracking Index Insulating Group Temperature Range Terminal body Pressure clamp Screw Spring 250 V acc. to EN 60998-1 12 A 0,5 Nm PA, grey, V-0 CTI ≥ 600 I -40°C up to 100°C Nickel plated brass Tin plated tin bronze M3; zinc plated steel, blue passivated Tin plated tin bronze APPROVALS Current [A] Voltage [V] Group AWG [Nm] OPTIONS / ACCESSORIES 15 10 300 300 B D 26 - 12 26 - 12 0,51 0,51 15 10 300 300 B D, E 26 - 12 26 - 12 0,51 0,51 • • • • • • • Consecutive numbering Special marking according to drawing Self-adhesive marking strip BST-5,08 Pitch of 10,16 mm for larger clearance and creepage distances Coding elements 120-K Connectors equipped with coding elements on request Strain relief CONFIGURATIONS Poles Part number 2 3 4 5 6 121-A-111/02 121-A-111/03 121-A-111/04 121-A-111/05 121-A-111/06 Article number 10.808.102 10.808.103 10.808.104 10.808.105 10.808.106 Length (L) 10,16 mm 15,24 mm 20,32 mm 25,40 mm 30,48 mm Packaging PU Box Box Box Box Box 200 200 100 100 100 07.19 WECO Electrical Connectors Inc., 18050 Trans-Canada Highway, Kirkland, Québec, Canada, H9J 4A1 Phone: 800.724.2928 | Phone: 514.694.9136 | Fax: 514.694.0956 weco@wecoconnectors.com © Copyright by WECO All rights reserved. WECO® is a brand of the WECO Group. Information provided in this document may be changed without prior notice. Please refer to our website for the full disclaimer.
121-A-111/05 价格&库存
很抱歉,暂时无法提供与“121-A-111/05”相匹配的价格&库存,您可以联系我们找货
121-A-111/05
  • 1+16.47000
  • 10+14.02920
  • 30+12.50640
  • 100+10.94040
库存:96
