ECJ504B-UA
ECJ504B-UA
    L-COM(诺通)
ECJ504B-UA 数据手册
8 6 7 4 5 3 1 .125 DATE DESCRIPTION REV 2X, APPROVED F ECN 5200: CN RELEASE 12/9/10 G ECN 6692: REVISED MODEL TO SNAP-ON COVERS 2/20/13 D.FRISIELLO H ECN 8409: UPDATE TEMPERATURE RATING TO -10~70°C 7/18/16 S.LI D. CASTRO 3.18 1.142 D 2 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. 29.00 1.48 D 10.00±.75 254.0±19.1 37.7 BLACK GREEN "J1" .75 WHITE 19.1 RED GRAY PIN 1 .43 SHIELDED DRAIN WIRE 10.8 1.40 .10 2.5 35.6 C C USB TYPE "A" JACK 2X #4-40 UNC-2B NOTES: B MATERIAL: COUPLER HOUSING: ABS, UL94V-0. CONNECTOR INSULATOR: WHITE, PBT WITH GLASS FIBER. CONNECTOR CONTACTS: PHOSPHOR BRONZE. CONNECTOR SHELL: BRASS. PCB: EPOXY GLASS FP-4, 94V-0 FLAMMABILITY RATING. FINISH: COUPLER HOUSING: COLOR, BLACK. CONNECTOR CONTACTS: GOLD, 30µ INCHES. CONNECTOR SHELLS: NICKEL. "J1" .905 22.99 WIRING MAP 1 POWER (RED, 20AWG) 2 - DATA (WHITE, 24AWG) 3 + DATA (GREEN, 24AWG) 1.142 29.00 .675 17.15 POWER GND (BLACK, 20AWG) 4 GND DRAIN (GRAY, 24AWG) ELECTRICAL: CURRENT RATING: 2 AMP MAX. VOLTAGE RATING: 140 VDC. RECOMMENDED PANEL CUTOUT UNLESS OTHERWISE SPECIFIED, A ENVIRONMENTAL: OPERATING TEMPERATURE: -10 C TO +70 C. DIMENSIONS ARE IN INCHES [mm] H OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% MISCELLANEOUS: COUPLER SHALL BE TESTED FOR CONTINUITY. COUPLER SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM PACKAGING SPEC PS-0031. ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 [5.08] .XX = ± .02 [.51] .XXX = ±.005 [.13] PROJECTION REGULATORY COMPLIANCE: CE2011/65/EU(RoHS DIRECTIVE) 8 7 B APPROVALS 50 HIGH STREET NORTH ANDOVER, MA 01845 DATE DRAWN BY 5/4/2001 C. MCCORMICK CHECKED BY 5/4/2001 D. PARHAM USB 5/4/2001 R. CARRICK CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY COLOR VARIATIONS MAY OCCUR PRODUCT DESCRIPTION JK PNL MNT USB A, 10" WIRE LDS SIZE A FSCM NO. 43321 SCALE: NONE 6 5 4 3 A CATEGORY APPROVED BY DWG. NO. CAD FILE: 2 ECJ504B-UA ECJ504B-UA.SLDDRW REV. H SHEET 1 OF 1 1
ECJ504B-UA 价格&库存
很抱歉,暂时无法提供与“ECJ504B-UA”相匹配的价格&库存,您可以联系我们找货
ECJ504B-UA
  • 1+125.085791+16.13639
  • 10+106.2652810+13.70850
  • 25+99.6130425+12.85034
  • 50+94.8570450+12.23680
  • 100+90.33024100+11.65284
  • 250+84.67883250+10.92379
  • 500+80.64150500+10.40296
  • 1000+76.797471000+9.90707
库存:603
