TDG1026A-8C
TDG1026A-8C
    L-COM(诺通)
    面板安装耦合器,RJ45 (8X8)
TDG1026A-8C 数据手册
8 6 7 4 5 3 1 REPLACES TDG1026A-8C-OD1 A APPROVED DATE DESCRIPTION REV .635 16.1 D 2 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. 6/24/14 D. CASTRO . . . . . . . . D .545 13.8 .63 16 RECOMMENDED PANEL CUT-OUT 1.24 31.5 .54 13.7 C C RJ45 JACK (8X8) PIN 8 PIN 1 RJ45 JACK (8X8) SPECIFICATIONS; MEETS REQUIREMENTS OF FCC PART 68.5 UL94V-0 COMPLIANT CSA CERTIFIED: CUL CATEGORY 3 RATED B MATERIALS; HOUSING: ABS COLOR: IVORY CONTACTS: PHOSPHOR BRONZE CONTACT PLATING: 30 μINCHES GOLD OVER NICKEL B TDG1026A-8CBK RETAINER ELECTRICAL; CURRENT RATING: 1.5 AMP MAX VOLTAGE RATING: 1000 VOLTS ENVIRONMENTAL; OPERATING TEMPERATURE RANGE: 0°C TO 60°C APPLICATION: FEED THROUGH COUPLER RETAINER CLIP (P/N TDG1026A-8CBK, ORDERED SEPARATELY) REQUIRED FOR PANEL MOUNTING. USE TABLE TO DETERMINE HOW MANY CLIPS ARE NEEDED. A UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% MISCELLANEOUS: COUPLER SHALL BE TESTED FOR CONTINUITY. COUPLER SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM SPECIFICATION PS-0031. ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 [5.08] .XX = ± .02 [.51] .XXX = ±.005 [.13] REGULATORY COMPLIANCE: CE2011/65/EU(RoHS DIRECTIVE) PROJECTION APPROVALS 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE DRAWN BY 10/6/01 TJC CHECKED BY 10/12/01 DFP TELECOM/MODULAR 10/12/01 CM CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY COLOR VARIATIONS MAY OCCUR PRODUCT DESCRIPTION RJ45 (8x8) PANEL MNT COUPLER SIZE A FSCM NO. 43321 SCALE: NONE 8 7 6 5 4 3 A CATEGORY APPROVED BY DWG. NO. CAD FILE: 2 TDG1026A-8C TDG1026A-8C.SLDDRW REV. A SHEET 1 OF 1 1
TDG1026A-8C 价格&库存
很抱歉,暂时无法提供与“TDG1026A-8C”相匹配的价格&库存,您可以联系我们找货
